Reads LTE and 5G signal values from a ZTE MC888 router and exposes them as ioBroker states.
Supported device
ZTE MC888 5G FWA (indoor router) — product page at ZTE Devices.
The adapter talks to the router's local goform HTTP API, so no cloud account and no
internet connection are required.
States
All states are read-only. …Dec states are the decimal representation of the raw
hexadecimal value next to them (that is what the router web interface shows).
general
| State | Type | Unit | Description |
networkType | string | Current network type, e.g. ENDC or LTE | |
cellId | string | Cell ID as delivered by the router (hex) | |
cellIdDec | number | Cell ID as decimal number |
lte — LTE primary cell
rsrp | number | dBm | Reference signal received power |
rsrq | number | dB | Reference signal received quality |
sinr | number | dB | Signal to interference plus noise ratio |
rssi | number | dBm | Received signal strength |
band | string | Band of the primary carrier, e.g. 3 | |
bandName | string | Band as reported in the cell info, e.g. LTE BAND 3 | |
arfcn | string | Downlink EARFCN (channel number) | |
bandwidth | string | Bandwidth of the primary carrier | |
pci | string | Physical cell ID (hex) | |
pciDec | number | Physical cell ID as decimal number | |
carrierAggregation | string | Carrier aggregation state reported by the router |
lte.scc0 … lte.scc3 — LTE secondary carriers
One channel per secondary carrier cell (up to four), each with the same states:
active | boolean | true while this secondary carrier is in use | |
pci | number | Physical cell ID | |
band | number | Band | |
arfcn | number | Channel number | |
bandwidth | number | MHz | Bandwidth |
nr5g — 5G NR primary cell
band | string | Band, e.g. 78 | |
bandName | string | Band as reported in the cell info | |
arfcn | string | NR-ARFCN (channel number) | |
bandwidth | string | Bandwidth | |
info
connection | boolean | true while the last poll succeeded |
Without a login the router only delivers the network type and the primary RSRP/RSSI values; all other states stay empty. See Login, sessions and the web UI.
Configuration
- Router IP — usually
192.168.0.1, some firmwares use192.168.254.1. - Poll interval — seconds between reads (5 to 86400).
- Login required — enable if the API only answers after authentication.
- Username / Password — the router admin credentials (username defaults to
admin). - Web UI has priority (only with login) — when the router web interface logs in with the same user, the adapter pauses instead of logging back in and kicking it out. See below.
- Back-off after web UI login (minutes) (only with login) — how long the
adapter stays logged out (keeping the last values) after the web UI took over the
session. Default 5. Set to
0to re-login on the very next poll.
The MC888 only serves a handful of fields (network type + primary RSRP/RSSI) without authentication; RSRQ, SINR, bands, PCI, carrier aggregation and the secondary cells require a login. The router also allows only one session per user, and a second login silently kicks the first.
To avoid fighting the router web interface (same admin user), the adapter:
- logs in once and keeps the session across polls (full field set),
- detects when another login (the web UI) takes over its session,
- then backs off for the configured time instead of immediately logging back in — during that window the last values are kept and only the public fields keep updating, so your web-UI session is not disturbed,
- re-acquires the session once the back-off elapses.
If you would rather always have the full data and don't mind the web UI being logged
out, disable Web UI has priority (or set the back-off to 0).
Firmware differences
The router's raw field names vary between firmware versions, so on some firmwares
individual states can stay empty. If that happens, please
open an issue and attach a debug
log (instance log level debug, which logs the raw router response) plus your firmware
version — support for the differing field names can then be added to the adapter.
Contributing
Notes on building, testing and extending the adapter are in DEVELOPMENT.md.
0.0.5 (2026-08-13)
- (Adapterman) Adapter requires admin >= 7.8.23 now.
- (Adapterman) The poll interval is now capped at 24 h so a huge value cannot overflow the timer
- (Adapterman) The web UI back-off is now capped at 24 h and both limits are enforced in the admin config
- (Adapterman) New adapter icon, delivered only in the admin directory as in the ioBroker template
- (Adapterman) Corrected and completed the list of adapter states in the README
- (Adapterman) Removed the install section from the README and moved the development notes to DEVELOPMENT.md
0.0.4 (2026-07-29)
- (Adapterman) Added the supported device section with a link to the ZTE MC888 product page
- (Adapterman) Corrected the required Node.js version in the development section
- (Adapterman) Added the readme link to io-package.json so Admin can link the documentation
- (Adapterman) Completed the author information in package.json, io-package.json and LICENSE
0.0.3 (2026-07-25)
- (Adapterman) Added ESLint (@iobroker/eslint-config) and prettier config plus a
lintscript - (Adapterman) Added a tsconfig.json and a
checkscript to type check the JavaScript sources via JSDoc - (Adapterman) Fixed a crash in the poll loop when the router did not answer and no login is configured
- (Adapterman) Admin config is now translated into all 11 ioBroker languages (jsonConfig i18n)
- (Adapterman) Added dependabot configuration and VS Code JSON schema settings
- (Adapterman) Lint and type checking are now enforced in CI
0.0.2 (2026-07-25)
- (Adapterman) Normalized the repository URL in package.json
- (Adapterman) Release is published via npm trusted publishing and signed with provenance
0.0.1 (2026-07-25)
- (Adapterman) Initial release
Copyright (c) 2026 Adapterman adapterman@proton.me
