Monitors availability and account metadata of user-configured Xtream-compatible API endpoints.
The adapter is a monitoring tool only. It does not provide, discover, proxy, play, or distribute media streams. Users are responsible for the endpoints and services they configure.
Features
- Monitor multiple endpoints in one adapter instance
- Online/offline and account status
- Response time
- Active and maximum connection counts
- Expiration date and days remaining
- Last check, last online and offline-since timestamps
- Error classification for timeout, DNS, HTTP, invalid response and inactive accounts
- Optional logging only when the online/offline state actually changes
- Summary states for VIS, Grafana and other ioBroker visualizations
Requirements
- Node.js 22 or newer
- js-controller 7.0.7 or newer
- Admin 7.6.20 or newer
Configuration
Add one or more endpoints in the adapter settings. Each row contains:
- Enabled - include the endpoint in monitoring
- Name - a user-friendly label
- Host / Server URL - base URL of the Xtream-compatible endpoint
- Username - account name
- Password - account password; the table configuration requests encrypted storage for this column
You can also configure the polling interval, request timeout and optional status-change logging.
Technical server IDs (server1, server2, ...) are managed internally and are not shown in the Admin UI.
Object structure
xtream-monitor.0
├── info
│ ├── connection
│ ├── allOnline
│ ├── enabledCount
│ ├── onlineCount
│ ├── offlineCount
│ └── lastCheck
└── servers
├── server1
│ ├── online
│ ├── status
│ ├── responseMs
│ ├── activeConnections
│ ├── maxConnections
│ ├── expiration
│ ├── expirationText
│ ├── daysRemaining
│ ├── lastCheck
│ ├── lastOnline
│ ├── offlineSince
│ └── errorType
Privacy and security
- The adapter contacts only endpoints explicitly configured by the user.
- Credentials are never intentionally written to the ioBroker log.
- Password columns are configured for encrypted storage in the Admin table.
- The complete server configuration is protected from access by other adapters via
protectedNative. - No media content is fetched for monitoring; the adapter queries account/status metadata via the compatible API endpoint.
Development
npm install
npm run build
npm run check
npm run lint
npm run test:package
npm run test:integration
Repository checks can be run with:
npx @iobroker/repochecker https://github.com/chrvidal/ioBroker.xtream-monitor main
0.2.11 (2026-09-11)
- Prevented request error states from exposing credentials.
- Added regression coverage for credential-safe request errors.
- Added Node.js 26 to the GitHub Actions test matrix.
0.2.10 (2026-09-02)
- Added a compatibility fallback for passwords affected by the ioBroker JSON Config table-encryption regression.
- Automatically remove stale server objects after the corresponding server is deleted from the configuration.
- Added regression tests for password compatibility and deleted-server cleanup.
0.2.9 (2026-09-01)
- Fixed startup handling during persistent server ID migration.
- Added regression coverage for password preservation and scheduled multi-server polling.
- Corrected protected configuration metadata for multi-server credentials.
0.2.8 (2026-08-31)
- Changed polling to schedule the next check only after the current cycle has finished, preventing overlapping API requests.
- Abort active HTTP requests during adapter unload for clean Compact Mode shutdown.
- Preserve
offlineSinceacross adapter restarts while an endpoint remains offline. - Added the explicit
infochannel and corrected per-server ioBroker state roles. - Changed
expirationTextto a language-neutral ISO timestamp. - Protected the configured server table from access by other adapters.
- Added integration tests with local mock API endpoints, including clean-shutdown behavior.
0.2.7 (2026-08-30)
- Fixed repository metadata reported by the ioBroker repository checker.
- Added valid
common.newsmetadata for the current release. - Relaxed the
@iobroker/testingdevDependency to a compatible semver range. - Added Dependabot cooldown configuration.
- Added the required license copyright line.
0.2.6 (2026-08-30)
- Prepared repository metadata for ioBroker public repository review.
- Added all required metadata translations and Admin translations.
- Added a responsive Admin layout and table-level password encryption configuration.
- Added package and integration test scaffolding plus GitHub Actions CI.
- Replaced unmanaged JavaScript timers with ioBroker adapter-managed timers.
- Added adapter icon, Dependabot configuration and editor JSON schemas.
0.2.5 (2026-08-30)
- Removed the technical server ID column from the Admin UI while keeping persistent internal IDs.
0.2.4 (2026-08-30)
- Improved persistent internal server-ID assignment and Admin compatibility.
0.2.3 (2026-08-30)
- Fixed GitHub installation by including the compiled adapter entry point.
0.2.2 (2026-08-30)
- Simplified server-ID handling in the Admin UI.
0.2.1 (2026-08-30)
- Added automatic technical server IDs.
0.2.0 (2026-08-30)
- Added monitoring of multiple endpoints in one adapter instance.
MIT License. See LICENSE.
Copyright (c) 2026 chrvidal
