wlanthermo-nano adapter for ioBroker
WLANThermo Nano, the digital advantage for your barbecue sport
Sentry
Configuration
The adapter can be installed and configured within the admin interface. Please enter IP-address, username and password in the instance configuration.
To-Do
- Implement auto device detect
- Optimize pitmaster settings, make states only writable in related modus otherwise read only
Join the Discord server to discuss everything about ioBroker-WlanThermo integration!
Support me
If you like my work, please feel free to provide a personal donation
(this is an personal Donate link for DutchmanNL, no relation to the ioBroker Project !)
- (DutchmanNL) Dependencies updated to current versions
- (DutchmanNL) Maintenance: raise Node.js to 22, modernise CI and release tooling, update dependencies, resolve repository checker findings
- (DutchmanNL) Admin settings are translated again: added the missing admin/i18n files for all 11 supported languages, including Ukrainian, and the device table column headers are now translated too
0.2.1 (2022-06-08) - Initialization error for Nano V1 solved
- (DutchmanNL) Initialization error for Nano V1 solved
- (DutchmanNL) Error logging and reporting improved
0.2.0 (2022-06-04) - PitMaster Control & ESP32 support
- (DutchmanNL) Support multiple devices
- (DutchmanNL) Refactor code to TypeScript
- (DutchmanNL) Error/debug logging Improved
- (DutchmanNL) Added data points for features
- (DutchmanNL) Test & Release workflow updated
- (DutchmanNL) Added indicator for connection status
- (DutchmanNL) Reconnecting to offline devices improved
- (DutchmanNL) Allow alarm to be activated / disabled #6
- (DutchmanNL) Allow control of pitmaster & system settings
- (DutchmanNL) Ensure support of all WLANThermo-Nano Devices
- (DutchmanNL) Implemented dropdown menu for Pitmaster to select available profiles
- (DutchmanNL) Added data points for PID profiles including capability to change profile settings
0.1.2
0.1.1
- (DutchmanNL) Code optimisation
- (DutchmanNL) Implement state_attr.js to handle state options outside of source code
- (DutchmanNL) Optimised state creation in 1 function
- (DutchmanNL) Small cleanups
0.1.0
- (DutchmanNL) remove color settngs from pitmaster
0.0.9
- (DutchmanNL) optimize pid profile setting
0.0.8
- (DutchmanNL) fix post command for pitmaster
0.0.7
- (DutchmanNL) State unit fixes
- (DutchmanNL) start integration of pidmaster
- (DutchmanNL) rename type to modus for pitmaster
0.0.6
- (DutchmanNL) make type and alarm selectable with dropdown
0.0.5
- (DutchmanNL) add capability to change sensors
0.0.4
- (DutchmanNL) Fix issue with password set
- (DutchmanNL) Implemented new states for config (reboot/update/checkupdate)
- (DutchmanNL) Change configuration (way of ip-adress, also dyndns now supported)
0.0.3
- (DutchmanNL) implement secure storage of login credentials (required to enable setting changes later)
0.0.2
- (DutchmanNL) initial release
Copyright (c) 2019-2026 DutchmanNL oss@DrozmotiX.eu
