weather Widgets
general flot-based weather Widgets to be used with daswetter or weatherundergrund adapter
Current Release
2.5.13
René G.
If you like it, please consider a donation:
paypal
This vis-widget shows weather forecast data from DasWetter.com or weatherunderground You need DasWetter-Adpater or weatherunderground-Adapter running as well...
In weatherunderground you need forecast of next 36 hours enabled. In DasWetter.com you need one of four forecast data structures enabled. You can select the one you want to display.
compatibility with vis-2
This widget is NOT compatible with vis-2. A new version under the name vis-2-widgets-weather is under preparation.
Notes / wiki
Define Forecast hours
By default the forecast diagram shows 40 hours (DasWetter) or 36 hours (wunderground). If you prefer to only show e.g. 10 hours forecast, simply delete the unnecessary OIDs under oid_groups in vis-edit.
OID's are not created automatically when using DasWetter
Normally OID's will be created automatically when you select instance or data structure. When you get "no OID's available" then check whether you use "NextDaysDetailed" in DasWetter. You might need to enable "NextDaysDetailed".
known issues
  • please create issues at github if you find bugs or whish new features
2.5.13 (2025-10-22)
  • (René) changes based on adapter checker suggestions
2.5.12 (2025-06-02)
  • (René) bug fix: widget was not shown at all sometimes
2.5.11 (2025-02-28)
  • (René) changes requested by adapter checker
  • (René) dependencies updated
2.5.10 (2024-05-28)
  • (René) suggested changes by adapter checker
2.5.9 (2024-01-13)
2.5.6 (2022-08-18)
  • (René) tooltip with value added as an option
  • (René) flot update
2.5.5 (2021-11-07)
  • (René) bug fix color of labels in widget
2.5.4 (2021-10-30)
  • (René) see issue #37: avoid endless loop
  • (René) update flot to 4.2.2
2.5.3 (2021-03-21)
2.5.2 (2019-12-12)
  • (René) some changes to make it compatible with widgets in sbfspot and ebus
2.5.1 (2019-12-08)
  • (René) alignment of bars with marking
  • (René) position of tick labels of Y axis changed
2.5.0 (2019-12-07)
  • (René) see issue #20: scaling problem solved
  • (René) see issue #22: bugfix colors for axis labeling
  • (René) color adjustment for axis and tick lables
  • (René) more adjustments for ticks on Y axis
  • (René) see issue #23: names for legend adjustable
2.4.0 (2019-10-31)
  • (René) legend added
2.3.2 (2019-10-24)
  • (René) add logs for issue #20
  • (René) update flot to version 3.0
2.3.1 (2019-07-13)
  • (René) bug fix: missing timer added
2.3.0 (2019-03-25)
  • (René) markings added
2.2.2 (2018-12-30)
  • (René) bug fix: If oid_date is not set when using weatherunderground, an unnecessary error message was issued and the plot was not shown
2.2.1 (2018-12-23)
  • (René) bug fix issue #12: unnecessary code removed
2.2.0 (2018-08-25)
  • (René) OID's for different data structures (only DasWetter 2.x)
2.1.1 (2018-08-24)
  • (René) bug fixes
2.1.0 (2018-08-18)
  • (René) support of 2.x of weatherundergruond
2.0.0
  • (René) support of 2.x of daswetter.com
1.2.0
  • (René) background color and border
1.1.2
  • (René) Support of admin3
1.1.1
  • (René) Y axis with units
1.1.0
  • (René) logs auskommentiert
  • (René) Berechnung min / max für Temperaturgraph optimiert
  • (René) Y-Achse automatisch ausblenden, wenn Graph nicht dargestellt wird
  • (gitbock) konfigurierbare Y-Achsen je Graph (anzeigen/nicht anzeigen)
  • (gitbock) Y-Achsen Beschriftung in der Farbe des Graphen
  • (gitbock) Max.-/Min Werte für Temperatur Y-Achse
  • (gitbock) konfigurierbares Datumsformat für X-Achse
1.0.0
  • (René) first stable version
0.0.7
  • (René) bug fix for android app > 1.0.6
  • (René) color adjustment for ticks and tick lable (from sbfspot)
0.0.6
  • (René) css removed
0.0.5
  • (René) number of labels on X axis adjustable
0.0.4
  • (René) bug fixes
0.0.3
  • (René) support of DasWetter.com and weatherunderground
0.0.2
  • (René) bug fixes
    • in live mode nothing was shown
0.0.1
  • (René) initial release
Copyright (c) 2017-2026 René G. info@rg-engineering.eu
