Material Advanced
This Adapter provides standardized Widgets for vis in ioBroker. Lots of different predifined widgets
Current Release
1.7.4
EdgarM73
vis-material-advanced adapter for ioBroker
This Adapter provides standardized Widgets for vis in ioBroker. Lots of different predefined widgets
the basics of this adapter has been created by:
but rewritten in 90%
Several bugfixes and lots of new widgets added.
Following widgets are present right now
current
  • Door
  • Window
  • Temperature
  • Humidity
  • Pressure
  • Temp&Humidity
  • Occupancy
  • Dimmer
  • Light-temperature
  • Shutter
  • Volume
  • Thermostat
  • Boolean
  • Number
  • Text
  • Valve
in progress
Not yet final:
  • Garage door
  • Radiostation
lot of widgets still in plan
Options
The following options are available in most of the widgets: - text-color - cardIcon (does not yet make sense everywhere, e.g. dimmer) - opacity color (the standard opacity color) - colorizeByValue (depending on some values, the opacity color can be changed e.g. if it is too hot make it red, to cold blue) - below,above, min, max (the values for colorizeByValue) - color-low/high,medium... (the color to use if border is raised) - read-only (some widgets can be set to read only mode for display only) - border-radius to enable and change the round corner - valueAlign Align the Value field left,center or right - value-vertical Align the Value field top,bottom or middle - borderColor Color of the Border if activated
Getting started
install the Adapter and start VIS in Edit mode. On the left side, choose vis-material-adapter and then all widgets are shown in preview.
............. lots of docu missing ......................
this is example2.png, import it and see it live
you can import the example.json file into vis thanks to @sigi234
  • (iobroker-bot) Adapter requires node.js >= 20 now.
1.7.4 (2023-09-07)
  • (DEV2DEV-DE) Subscribe to updates of both values (temperature, humidity)
1.7.3 (2022-04-11)
  • (bluefox) Removed erroneous chars from HTML
1.7.2 (2021-07-02)
  • bugfix 2 Temp Humidity
1.7.1 (2021-07-02)
  • bugfix for Temp Humidity
1.7.0 (2021-04-19)
  • added new Widget Window3 for possibility showing open/tilted/closed [0/1/2] windows
Copyright (c) 2026 iobroker-community-adapters iobroker-community-adapters@gmx.de
Copyright (c) 2020-2023 EdgarM73 edgar.miller@gmail.com
