Widgets
Buttons and switches
Clock
- Analog
- Analog variation
- Digital
- Digital2 (SVG Text)
Simple state
With this widget, you can control one device. Boolean or number.
- Number
- Control
View in widget
Not as a button: View could be shown in full size, and you can control elements in view.
As button: You can show a small thumbnail of view, and by pressing on it, it will be shown in full size.
Thermostat
Additionally, it can show a history if you activated it.
Actual value with chart
Security control
You can define the delay in seconds.
By activation, the defined ID will be written with the number of the delay seconds, and after the delay is over, the defined ID will be set to 0, and the alarm ID will be set to true.
Player
Map
Position could be defined as a combined state, like 9.2344;41.374652 - longitude;latitude or as two separate states.
Camera
HTML Template
HTML template can be used to show any HTML code. Additionally, you can show an image or iframe with this widget too.
Blinds
Color Lamp
With the RGB lamp widget, you can control different types of RGB lamps. Here are some examples:
- RGB colors are set in one state like '#RRGGBB'
- R/G/B colors are set in different states from 0 to 255
- RGBW as one variable like '#RRGGBBWW'
- R/G/B/W colors are set in different states from 0 to 255
- hue/sat/lum as 3 different states
- color temperature as one state from 2700 to 6500 or defined by min/max of the object
- White mode state can be used to switch between RGB and white mode via a special state
Door lock
Vacuum cleaner
This widget is primary for Xiaomi vacuum cleaner. But it can be used for any other vacuum cleaner too.
The only difference is that Xiaomi supports the room cleaning.
Time picker
Todo
- Extend Blinds with shutter
1.6.7 (2026-05-17)
- (@GermanBluefox) Corrected error with button and alarm widget
1.6.1 (2026-03-14)
- (@GermanBluefox) Corrected error with select value widget
1.6.0 (2025-09-03)
- (@GermanBluefox) Corrected "Actual" widget
1.5.3 (2025-08-27)
- (@GermanBluefox) Added support for older Android devices
1.5.0 (2025-05-19)
- (bluefox) Corrected thermostat slider
- (bluefox) Rewritten with TypeScript and vite
- (bluefox) Corrected blinds control
- (bluefox) Added disabled mode additionally to hidden mode in the 'switches and buttons' widget
- (bluefox) Added
_ts=Date.now()to camera URL to disable the browser cache - (bluefox) Simple state has a new option - step
- (bluefox) Added new navigation widget: jump to view, url or list of views
Older changelogs can be found there## License
The MIT License (MIT)
Copyright (c) 2022-2026 Denis Haev dogafox@gmail.com
