vbus-gw adapter for ioBroker
Allows TCP access to serial port based VBus devices
This ioBroker Adapter is based on work by Daniel Wippermann.
https://github.com/danielwippermann/resol-vbus/tree/master/examples/serial-to-tcp
Copyright and license see section "License"
Overview
There are two types of VBus hardware adapters:
- TCP based: DL2, DL3, KM2, VBus/LAN
- Serial port based: VBus/USB, USB port of DeltaSol SLT and other controllers
This ioBroker adapter connects to one or more serial port based hardware adapters and exposes them over TCP. This allows:
- transmitting VBus data over longer distances than USB or serial ports would normally permit
- accessing serial port based adapters from applications that only support TCP based ones
Configuration
Configurable items are:
The TCP port on which the service is listening for incoming connections.
Default is port: 7053, which should not be changed. -
The http port on which the service is listening for discovery requests.
Default is port: 80, alternatively port 3000 can be selected. -
The password of the VBus gateway.
Allows access to all serial port connected VBus devices. Default is "vbus". -
A list of serial ports to connect to with the following parameters for each serial port:
channel: The vbus channel to which the serial port is assigned.
If you only want to connect to a single serial port it is recommended to configure that to use channel 0, since most applications will by default try and connect that channel 0. -
path: The path to the serial port like
'/dev/ttyUSB0' or
'/dev/serial/by-id/usb-Silicon_Labs_USB-Modul_UO2102_TDEB6I8DAVDLGAGC-if00-port0' or
'/dev/serial/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4.1:1.0-port0' or
'COM5' -
baudrate: The baudrate of the serial port. Default is 9600, which normally does not need to be changed.
Known issues
- This adapter currently supports up to 3 VBus devices connected via serial ports.
- The passwords for all VBus'es connected to the serial ports are the same.
- VBus.net connected devices are not emulated. Sending the CONNECT (via tag) command returns +OK although no connection is established.
- Sending the DATA command with a non-existing channel selected returns +OK, but immediately closes the connection afterwards.
0.3.2 (2026-03-04) - 2026H1 maintenance release
- (pdbjjens) Changed: node>=20, js-controller>=7.0.7 and admin>=7.7.22 required
- (pdbjjens) Fixed: update release-script (#149)
0.3.2-alpha.0 (2025-10-20)
- (pdbjjens) Fix: Removed NPM_TOKEN secret from repository
0.3.1-alpha.0 (2025-10-20)
- (pdbjjens) Fix: Add GitHub as npm Trusted Publisher
- (pdbjjens) Change: Update dependencies
0.3.0 (2025-08-29) - 2025H1 maintenance release
- (pdbjjens) Change: node>=20, js-controller>=7.0.7 and admin>=7.6.17 required
- (pdbjjens) Change: Cleanup devDependencies
0.2.0 (2025-01-29) - 2025H1 maintenance release
- (pdbjjens) Change: Migration to ESLint 9
- (pdbjjens) New: Accept serial port paths /dev/serial/by-id/usb-xxxxxxxxxxxxxxxxxxx or /dev/serial/by-path/platform-xxxxxxxxxxxxxxxxxxx
- (pdbjjens) Change: Responsive Design optimizations
Copyright (c) 2025-2026 Jens-Peter Jensen jjensen@t-online.de
Copyright (c) 2013-present, Daniel Wippermann.
