Tractive Next
Unofficial Tractive GPS integration with automatic state discovery.
Current Release
0.5.5
Fraese73
Unofficial Tractive GPS adapter for ioBroker.
Features
  • Tractive account login with automatic token renewal
  • One automatic retry after HTTP 401 or 403
  • Tracker list / details / hardware / position
  • Activity and health overview (…health.*)
  • 24h position history (…history.*)
  • Alert states for automation (…alerts.*)
  • Geofence JSON plus structured geofence states (…geofences.*)
  • Optional commands for live tracking, LED and buzzer (…controls.*, gated by enableCommands)
  • Geofence payload as JSON when the API provides it
  • OpenStreetMap link and admin map overview tab with live-tracking / LED / buzzer buttons
  • Admin day track: path, heatmap toggle, from–to range slider and playback
  • Optional Vis-2 Material overview project (docs/vis-2/)
  • Automatic ioBroker object creation and datatype inference
  • Encrypted password, ESLint, package/unit tests, GitHub Actions CI
Important
Manufacturer website: https://tractive.com/
Tractive does not provide a documented public consumer API for these trackers. This adapter uses the unofficial endpoint used by existing open-source integrations. Tractive can change it at any time.
Installation
Install and update the adapter via the ioBroker Admin adapter list once it is available in the official Latest repository.
After adding an instance, open the configuration and enter the Tractive email address and password. After the first setup (and after password-encryption changes), save the password once so it is stored encrypted.
Configuration
To send live-tracking / LED / buzzer commands, enable Enable tracker commands in the instance settings. The writable states are under each tracker at …controls.liveTrackingActive, …controls.ledActive and …controls.buzzerActive.
Commands go through the Tractive cloud API. Inside a Power Saving / home zone the cloud often accepts the request as pending but does not activate LED, buzzer or live tracking on the device (the official app can still use Bluetooth Radar locally). Outside that zone, commands work; the adapter keeps an optimistic control value while the API reports pending, so the UI does not flip back to false before you can turn the feature off again.
Development
Contributor notes and publishing checklist: docs/PUBLISHING.md.
On a development host you can sync a local clone with UPDATE_ON_PI.sh (for maintainers only, not for end-user installation).
0.5.5
  • (Fraese73) Add alert states per tracker (alerts.trackerOffline, alerts.lowBattery, alerts.noRecentPosition, alerts.minutesSinceLastSeen)
  • (Fraese73) Add structured geofence states per tracker (geofences.<id>.id|name|active|enteredAt|leftAt, plus count/idsJson)
0.5.4
  • (Fraese73) Latest review fixes: English admin tab UI, valid state roles (text / value.battery), poll interval upper bound, full jsonConfig translations
  • (Fraese73) Admin day track: from–to range slider to limit visible track points
0.5.3
  • (Fraese73) Fix day-track / history parser for nested json_segments ([[points]])
0.5.2
  • (Fraese73) E6013/W6018: README install via Admin only; remove root CHANGELOG.md (changelog in README)
0.5.1
  • (Fraese73) Repository checker fixes: news only for published npm versions
0.5.0
  • (Fraese73) Admin day track with heatmap toggle and time-slider playback; history.distanceKm
0.4.0
  • (Fraese73) Optional live-tracking / LED / buzzer commands with enableCommands safety switch
  • (Fraese73) Fixed overview.charging for NOT_CHARGING string values
  • (Fraese73) Optimistic pending control state, admin control buttons, Vis-2 overview (shipped in 0.5.0)
0.3.0
  • (Fraese73) Activity/health overview, 24h history, live-tracking status, geofence JSON (read-only)
0.2.11
  • (Fraese73) Stabilization: null type hints, tolerant API sections, unit tests, redacted logs
0.2.10
  • (Fraese73) Trusted Publishing release with provenance; news limited to npm versions
Older entries: docs/CHANGELOG_OLD.md
Copyright (c) 2026 Fraese73
