ioBroker.tr-064
This adapter uses the Sentry libraries. These libraries report exceptions and code errors automatically to the developers. For more details, and for information about how to switch off the error reporting, see the documentation of the Sentry plugin. The Sentry reporting is used from js-controller 3.0 on.
Info
This adapter reads the most important information from an AVM Fritz!Box. Examples are the call list and the number of messages on the answering machine.
The adapter is based on the FRITZ! interface documentation.
Required settings in your Fritz!Box
- Change the login method to "Use user name and password".
- The Fritz!Box uses a maximum of 32 characters of the password. The Fritz!Box shortens longer passwords in its own user interface without a warning. Therefore, enter only these 32 characters in the configuration of the adapter.
- Create a user and give this user the permission to control the Fritz!Box and its settings.
- Switch on the access for applications on the "Network" tab. In the German user interface, the path is:
Netzwerk->Heimnetzfreigaben->Zugriff für Anwendungen->aktiviert. - If you want to use the
ringfunction, you must configure additional settings. See the section ring (dial a number).
Features
Simple states and functions
- Switch the Wi-Fi for 2.4 GHz and 5 GHz on and off
- Switch the guest Wi-Fi on and off
- Restart the Fritz!Box
- Start the WPS process
- Reconnect the internet connection
- Read the external IP address
- If you use an internal number, for example
**610, the stateringlets this internal telephone ring. Example:**610[,timeout] - If you use an external number, the state
ringconnects you with this external number. The Fritz!Box calls the external number, and your default telephone rings as soon as the called person picks up the telephone.
You can configure the default telephone in the Fritz!Box. In the German user interface, the path is: Telefonie -> Anrufe -> Wahlhilfe -> Wählhilfe verwenden. Select there also the option Verbindung mit dem Telefon ISDN- und Schnurlostelefone.
toPauseState
- Possible values:
ring,connect,end - You can use this state to pause a video player on an incoming call (
ring), or when somebody picks up the telephone (connect). - You can continue the playback on the value
end.
Presence
You can use this adapter to monitor the presence of persons in your home. In this way you see when a member of your family or a roommate leaves the home or comes back:
- Open the settings of the adapter and switch to the tab "Devices".
- Add all devices of your family members or roommates, for example, their smartphones, and confirm with "Save".
- For every device, the adapter creates a folder structure in the objects of the adapter. Normally this is the folder
tr-064.0.devices. - As soon as somebody arrives or leaves, the adapter gets this information. The state
tr-064.0.devices.xxx.active, wherexxxis the name of the device, shows whether this device is available, and therefore whether the person is at home.
You can also switch on the option "Use mDNS to discover new devices". If mDNS is used, the adapter does not need to poll the Fritz!Box, and it detects changes faster.
Users report that the detection also works reliably for iOS devices, for example, for iPhones. For iPhones, users report that the Fritz!Box needs up to 10 minutes to detect that a person has left and is no longer connected with the Wi-Fi. The Fritz!Box needs up to 1 minute to detect the presence again.
The ioBroker community has published a script that uses this information of the adapter to trigger actions. Examples are: switch off everything automatically after all persons have left the home, show the number of persons that are at home, or show the status of a person in VIS. See the thread in the ioBroker forum (in German).
Answering machine (in German: Anrufbeantworter)
You can switch the answering machine on and off. With the state cbIndex you select the number of the answering machine.
Call monitor
The call monitor creates states in real time for every incoming and outgoing call. If the phone book is switched on, which is the default setting, the adapter resolves the numbers into names. There is also a state that shows a ringing telephone.
Phone book
- If the phone book is switched on, the adapter uses it to find the name for the number of the caller.
- There are three more states to resolve a number or a name. If a picture is available, you also get the URL of the picture of the contact.
Example: if you set the state phonebook.number, the adapter sets all 3 states, name, number and image, to the values of the contact that was found. Note: for a search by name, the adapter first compares the complete name. If no contact is found, the adapter searches for a part of the name.
Call lists
Output formats:
jsonhtml
The following call lists exist:
- all calls
- missed calls
- incoming calls
- outgoing calls
Call counter: you can set the call counter to 0. The next call increases the counter by 1.
You can configure the HTML output with a template.
The states command and commandResult
With the state command you can call every tr-064 command from this documentation. Example:
command = {
"service": "urn:dslforum-org:service:WLANConfiguration:1",
"action": "X_AVM-DE_SetWPSConfig",
"params": {
"NewX_AVM-DE_WPSMode": "pbc",
"NewX_AVM-DE_WPSClientPIN": ""
Set the state command to the JSON of the lines above, this means to { ... }, without command = and without line breaks. The answer of the call is written into the state commandResult.
The following example shows how to switch the answering machine of the Fritz!Box on and off with the state command. For a test you can copy the text and paste it into the state tr-064.0.states.command.
Switch the answering machine on:
{"service": "urn:dslforum-org:service:X_AVM-DE_TAM:1","action": "SetEnable", "params": {"NewIndex": "0","NewEnable": "1"}}
Switch the answering machine off:
{"service": "urn:dslforum-org:service:X_AVM-DE_TAM:1","action": "SetEnable", "params": {"NewIndex": "0","NewEnable": "0"}}
You find a detailed description of the actions and of the parameters for TAM here: x_tam.pdf. This link is also contained in the AVM documentation above.
Switch on the call monitor
Before you can use the call monitor, you must switch it on in the AVM Fritz!Box. To switch the call monitor on, dial #96*5* on a connected telephone. The Fritz!Box then opens the TCP/IP port 1012. To close the port, dial #96*4*.
Initial creation
@soef created this adapter at https://github.com/soef/ioBroker.tr-064. The adapter is not maintained there anymore. Therefore it was moved to iobroker-community, so that errors can be corrected. Thanks to @soef for his work.
How to migrate from tr-064-community (intermediate version and name)
If you switch from the adapter tr-064-community, you can copy the complete device list and all settings:
- Open the objects in the admin and switch on the expert mode.
- Search for the object tree
system.adapter.tr-064-community.0, where0is the number of the instance. If you had several instances, select the correct one. - Click the button with the pencil on the right side of this line.
- In the window, select "raw (experts only)", and copy the part
nativeof the JSON. - Open
system.adapter.tr-064.0, where0is the number of the instance. If you had several instances, select the correct one. - Paste the copied content into the part
native. - Save the changes.
- Start the adapter.
- Check the configuration and control whether everything was restored correctly.
- (@GermanBluefox) Fixed the crash
systemData.save is not a functionon start when a call list is generated: installations which ran an adapter version from 2017 to 2020 still had an invalid attributesavein the objecttr-064.<instance>, which is removed now - (@GermanBluefox)
wlanGuestswitches the guest WLAN again on boxes with three bands (e.g. FRITZ!Box 5690 Pro, 4060) instead of the third band: the guest WLAN is always the last WLAN configuration of the box - (@GermanBluefox) New states
wlan60andwlan60Passwordfor the 6 GHz WLAN, andwlan52andwlan52Passwordfor the second 5 GHz WLAN (e.g. FRITZ!Box 4060). The adapter asks the box which band its third WLAN uses - (@GermanBluefox) The call lists do not stop updating after some hours any more: the call monitor detects a connection which the box dropped unnoticed (e.g. by a restart) with TCP keepalive and reconnects, and the call lists are also read once a minute - that way they are updated without call monitor, too
- (@GermanBluefox) A call list download which the box does not answer is given up after 10 seconds with a warning
states.abNewMessages: number of new (not yet listened) messages on the answering machines
5.0.2 (2026-09-10)
Cannot read properties of undefined (reading 'safe')ingetWLANright after the start: the WLAN states are read again in every poll cycle - (@GermanBluefox) A box without a separate 5 GHz configuration does not delay the polling by 3 seconds any more
5.0.1 (2026-09-09)
- (@GermanBluefox) Breaking change: the adapter requires node.js >= 22 now
- (@GermanBluefox) Adapter requires admin >= 7.7.22 now
- (@GermanBluefox) Adapter requires js-controller >= 6.0.11 now
- (@GermanBluefox) The adapter does not stop any more if the Fritz!Box cannot be reached. The connection is retried every 30 seconds, and the new state
info.connectionshows whether the box answers - (@justr1) Expected disconnects of the call monitor (
ETIMEDOUT,ECONNRESET,EPIPE) are logged as info now, because the adapter reconnects on its own - (@GermanBluefox) The mDNS socket is closed when the adapter stops, so a restart does not leave a listener behind
- (@GermanBluefox) A phone book with only one contact is read now
- (@GermanBluefox) The hint how to open port 1012 is shown again if the call monitor is refused by the Fritz!Box
- (@GermanBluefox) The adapter was refactored to TypeScript. The sources are in
src/, the adapter runs frombuild/ - (@GermanBluefox) The configuration dialog was rewritten as JsonConfig. Admin 7.7.22 or newer is required for it
- (@GermanBluefox) The adapter can only be installed from npm now, no longer directly from GitHub (
common.nogit) - (@GermanBluefox) The options "Use call forwarding options", "Use mDNS" and "Create JSON device list" have a default value in
io-package.jsonnow - (@GermanBluefox) The command
dumpservices.fswrites the file again instead of stopping the adapter
4.3.0 (2024-04-30)
- (mcm1957) Adapter requires node.js >= 18 and js-controller >= 5 now
4.2.18 (2023-01-04)
- (Apollon77) Prepare for future js-controller versions
4.2.17 (2022-09-16)
- (simatec/Apollon77) Prevent duplication of entries in configuration
- (Apollon77) Make sure the active status of devices in jsonDeviceList is correct
The MIT License (MIT)
Copyright (c) 2023-2026 iobroker-community-adapters iobroker-community-adapters@gmx.de
Copyright (c) 2015-2023 soef soef@gmx.net, ioBroker-Community-Developers
