Stiebel-ISG/Tecalor-ISG
This adapter is a ment to read values from stiebel-eltron/tecalor internet service gateways (ISG) and control the device.
Current Release
2.1.0
Michael Schuster, iobroker-community-adapters, mcm1957
ioBroker adapter for STIEBEL ELTRON/Tecalor Internet Service Gateways (ISG)
This adapter reads values from STIEBEL ELTRON/Tecalor Internet Service Gateways (ISG) web pages and can send commands to control the device.
NOTE: This adapter has been tested with legacy ISG devices only. (ISG Plus and ISG Web). Whether it works with the current ISG Connect device is to be determined yet.
NOTE: This adapter has been transferred to iobroker-community-adapters for maintenance. Only important bug fixes and dependency updates will be released in the future. However PRs with bug fixes or feature enhancements are always welcome.
Credits: This adapter would not have been possible without the great work of Michael Schuster (unltdnetworx) https://github.com/unltdnetworx, who created previous releases of this adapter.
Release Notes
Caution: Version 2.x.x includes some Breaking Changes:
  • node.js >= 22, js-controller >= 6.0.11 and admin >= 7.7.22 is required
    Upgrade your ioBroker to at least this software level, if you want to use this adapter
  • Password and username encryption in config UI
    If you update this adapter from a previous version instead of a new installation, the adapter may not start, even if your password and username in your config is correct and has not been changed. To fix this, simply enter the same previous password and username once more in the config UI and store and close the config UI to restart the adapter. This of course is only neccessary once after the first start after the update.
  • The type and/or name of some objects in the object tab has changed
    If you update this adapter from a previous version instead of a new installation, you may possibly find warnings in the ioBroker log or object values and/or names are not updated correctly. To prevent this from happening, the most simple solution is to stop the adapter in the instances tab of ioBroker, completely delete the object tree in the objects tab and then restart the adapter. However, this is only neccessary once after the update and is not required if you do a clean new installation.
    CAUTION: Deleting the object tree will erase any user-defined settings e.g. links to other adapters like history or statistics. You will have to recreate them manually, so make sure to remember the details of the settings.
Configuration
  1. Configure the instance by entering the IP-address or domain name of the ISG and if configured in the ISG, the user name and password.
  2. The other settings and the the list of the web pages of the ISG on tab URLs may be left at their default values.
  3. You can improve performance and reduce the load on the ISG if you remove any paths from the URLs tab which do not exist in you ISG Web GUI or which you are not interested in. You can easily identify the URLs by opening the ISG SERVICEWELT Web page and open the various navigation tabs one by one. The URL of the respective page is shown in your browser e.g http://IP-of-your-ISG/?s=1,0 is the value path to INFO/ANLAGE.
2.1.0 (2026-09-09)
  • (copilot) Breaking: Adapter requires node.js >= 22 now
  • (pdbjjens) Fixed: i18n directory migrated to short format
  • (pdbjjens) Fixed: dependency updates and minor bug fixes
  • (pdbjjens) Fixed: startup logic and misleading error messages (#168)
2.0.3 (2026-03-04) - 2026H1 maintenance release
  • (pdbjjens) Fixed: update release-script (#143)
  • (pdbjjens) Fixed: parse missing "info_alone" objects (#140)
  • (pdbjjens) Fixed: Cleanup some eslint issues
2.0.2 (2025-11-23)
  • (pdbjjens) Fixed: Adapter hangup on wrong credentials. (fixes #127)
2.0.1 (2025-11-12)
  • (pdbjjens) Fixed: ioBroker warnings are avoided by clamping any values exceeding min/max to the min value before setting. (fixes #53 & #65)
2.0.0 (2025-10-27)
  • (mcm1957) Change: Adapter has been migrated to iobroker-community-adapters organisation
  • (mcm1957) Change: Adapter requires node.js >= 20, js-controller >= 6.0.11 and admin >= 7.6.17 now
  • (mcm1957) Fix: Dependencies have been updated
  • (pdbjjens) Change: remove .npmignore
  • (pdbjjens) Change: migrate adapter configuration to jsonConfig
  • (pdbjjens) Change: migrate from deprecated "request" http client to native fetch API
  • (pdbjjens) Fix: min/max handling
Legal Notices
STIEBEL ELTRON, TECALOR, ISG and associated logos are trademarks or registered trademarks of STIEBEL ELTRON GmbH & Co KG https://www.stiebel-eltron.com
All other trademarks are the property of their respective owners.
The authors are in no way endorsed by or affiliated with STIEBEL ELTRON GmbH & Co KG, or any associated subsidiaries, logos or trademarks.
Copyright (c) 2025-2026 iobroker-community-adapters iobroker-community-adapters@gmx.de
Copyright (c) 2018-2023 Michael Schuster development@unltd-networx.de
