sonnenCharger
Integration of sonnenCharger into ioBroker
Current Release
1.2.1
ChrisWbb
sonnen-charger adapter for ioBroker
This adpater integrates your sonnenCharger into ioBroker
Additional information about sonnenCharger can be found on vendors webpage.
Configuration
After you have created an instance of the apdater you have to configure several parameters:
Parameter NameDescriptionDefault
IP-AddressIP-Address of the sonnenCharger-
PortPort of Modbus-Interface of the sonnenCharger502
Request intervalInterval for fetching data in seconds (ValueRage 30 - 3600)30
Allow write access to sonnenChargerEXPERIMENTAL be carefull when writing data into sonnenChargerfalse
Usage
Channel: info
IdDescriptionDatatypeUnitRead/WriteAddition Information
connectionDevice or service connectedboolean-R-
Channel: chargerSettings
serialNumberSerial numberstringR
modelModelstringR
hwVersionHardware versionstringR
swVersionSoftware versionstringR
numberOfConnectorsNumber of connectorsintegerR
Channel: chargerSettings.connector.<number>
connectorTypeConnector typestringR
numberOfPhasesNumber phasesintegerR
l1ConnectedToPhaseL1 connected to phaseintegerR
l2ConnectedToPhaseL2 connected to phaseintegerR
l3ConnectedToPhaseL3 connected to phaseintegerR
customMaxCurrentCustom max currentfloatAR
Channel: measurements.<number>
connectorStatusConnnector status idintegerR
connectorStatusLabelConnnector status labelstringR0 : Unknown
1 : SocketAvailable
2 : WaitingForVehicleToBeConnected
3 : WaitingForVehicleToStart
4 : Charging
5 : ChargingPausedByEv
6 : ChargingPausedByEvse
7 : ChargingEnded
8 : ChargingFault
9 : UnpausingCharging
10 : Unavailable
measuredVehicleNumberOfPhasesMeasured vehicle number of phases idintegerR
measuredVehicleNumberOfPhasesLabelMeasured vehicle number of phases labelstringR
evMaxPhaseCurrentEV max phase currentfloatAR
targetCurrentFromPowerMgmTarget current from power mgm or modbusfloatAR
frequencyFrequencyfloatHzR
voltageL1L-N voltage (L1)floatVR
voltageL2L-N voltage (L2)floatVR
voltageL3L-N voltage (L3)floatVR
currentL1Curent (L1)floatAR
currentL2Curent (L2)floatAR
currentL3Curent (L3)floatAR
activePowerL1Active power (L1)floatkWR
activePowerL2Active power (L2)floatkWR
activePowerL3Active power (L3)floatkWR
activePowerTotalActive power (total)floatkWR
powerFactorPower factorfloatR
totalImportedActiveEnergyInRunningSessionTotal imported active energy in running sessionfloatkWhR
runningSessionDurationRunning session durationnumbersecondsR
runningSessionDepartureTimeRunning session departure timenumbersecondsRUnix time (seconds since 1970-01-01 00:00:00 UTC)
runningSessionDepartureTimeISORunning session departure time in ISO UTC formatstringR
runningSessionIDRunning session IDintegerRIn the case that charger is communicating with central system, this is a transactionId provided by central system over OCPP
evMaxPowerEV max powerfloatkWRMax power detected in the currently running charging session
evPlannedEnergyEV planned energyfloatkWhRTotal amount of energy that is planned to be delivered for currently running charging session
Channel: commands
restartRestart sonnen-chargerbuttonW
setTimeSet time UTC"integersecondsWUnix time (seconds since 1970-01-01 00:00:00 UTC)
Channel: commands.connectors<number>
stopChargingStop chargingbuttonW
pauseChargingPause chargingbuttonW
setDepartureTimeSet departure timeintegersecondsW
setCurrentSetpointSet current setpointfloatAW
cancelCurrentSetpointCancel current setpointbuttonW
setPowerSetpointSet power setpointfloatkWW
cancelPowerSetpointCancel power setpointbuttonW
  • (ChrisWbb) smart mode implementation (currently not disabled)
  • (ChrisWbb) update dependancy versions
1.2.1 (2024-05-30)
  • (ChrisWbb) fix findings of adapter checker
1.2.0 (2024-05-30)
  • (ChrisWbb) fix finding of adapter checker
  • (ChrisWbb) adjust state roles
  • (ChrisWbb) new version of @types/node
  • (ChrisWbb) tests for node 20.x
1.1.1 (2023-03-30)
  • (ChrisWbb) fixed release problem
1.1.0 (2023-03-30)
  • (ChrisWbb) write access to holding register
  • (ChrisWbb) refactoring async calls
  • (ChrisWbb) smaller changes based on suggestions from review
  • (ChrisWbb) update readme
1.0.2 (2023-02-18)
  • (ChrisWbb) fix ESLint findings
1.0.1 (2023-02-18)
  • (ChrisWbb) preparation for release
  • (ChrisWbb) small fixes from adapter check
1.0.0 (2023-01-02)
  • (ChrisWbb) initial version
Copyright (c) 2024 ChrisWbb development@chrweber.de
