SOLECTRUS InfluxDB
Writes configurable ioBroker states to InfluxDB
Current Release
2.0.1
patricknitsch
🌞 SOLECTRUS InfluxDB Adapter for ioBroker
Overview
The SOLECTRUS InfluxDB Adapter stores selected ioBroker states into an InfluxDB 2.x database and optionally computes derived values using a built-in formula engine.
It is designed for energy monitoring systems such as photovoltaic installations, battery storage, heat pumps, wallboxes, grid import/export monitoring, and custom sensors.
Features
  • Sensor Mapping -- Map any ioBroker state to an InfluxDB measurement/field with configurable data type (int, float, bool, string)
  • Internal Sensors -- Mirror and monitor states without writing them to InfluxDB
  • Reliable Buffering -- Persistent write buffer (up to 100k points) survives InfluxDB outages and adapter restarts
  • Data-SOLECTRUS Formula Engine (optional) -- Compute derived values from multiple inputs using formulas, source mirroring, or rule-based state machines
  • State Machine Mode -- Generate string/boolean states from rule conditions (first-match-wins), ideal for status labels and operating modes
  • Formula Builder -- Visual editor with drag-and-drop building blocks, live preview, operator tooltips, and example patterns
  • Folder Grouping -- Organize sensors and computed values into folders for better overview
  • Built-in Backup -- Create, upload, restore, download and delete local backups of the instance config, sensors and Data-SOLECTRUS items right from the Backup tab, no other adapter required
Quick Start
  1. Install the adapter via the ioBroker admin UI
  2. Configure InfluxDB connection (URL, Organization, Bucket, Token) on the InfluxDB tab
  3. Map your ioBroker states on the Sensors tab
  4. (Optional) Enable Data-SOLECTRUS checkbox to unlock the formula engine with Data Values and Data Runtime tabs
  5. Save and start the adapter
Documentation
🇺🇸 Documentation
🇩🇪 Dokumentation
Requirements
  • ioBroker >= latest stable
  • ioBroker.admin >= 8.0.0 - required since v2.0.0, the admin UI no longer works on Admin 6/7 (see Changelog)
  • Node.js >= 22
  • InfluxDB 2.x
  • (patricknitsch) Add Node.js 26 in test-and-release.yml
2.0.1 (2026-08-04)
  • (patricknitsch) BREAKING CHANGE: Requires ioBroker.admin 8 (currently Alpha) or newer. Admin 8 introduced a new "GUI API generation" for custom jsonConfig components (React 19 / MUI 9, @iobroker/gui-components) with no backward compatibility, so the Sensors, Data Values and Backup tabs no longer load on Admin 6/7. Do not update to this version unless ioBroker.admin has already been updated to version 8.
  • (patricknitsch) Fix Sensor Overview Format
  • (patricknitsch) Fix missing unit in Formula Engine
  • (patricknitsch) Split internal and external Sensors in Overview
  • (patricknitsch) Update Doc
2.0.0 (2026-08-03)
  • (patricknitsch) Rebuild the admin UI (sensors editor, Data-SOLECTRUS items editor, backup panel) as a proper Vite + Module Federation build (src-admin/) targeting @iobroker/gui-components, replacing the hand-written vanilla-JS Module Federation containers
  • (patricknitsch) Log a clear error and set info.lastError at startup if the installed ioBroker.admin is below version 8, so an incompatible setup is immediately visible instead of a silent/confusing failure in the config dialog
  • (patricknitsch) Cleanup i18n
  • (copilot) Fix timeout for Backup Manager
1.12.0 (2026-07-08)
  • (patricknitsch) Final Release
1.12.0-beta.1 (2026-07-08)
  • (patricknitsch) Fix npm run check (tsc type-checking of the JSDoc-typed JS codebase) so it passes cleanly again
  • (patricknitsch) Improve JSDoc type coverage across dsProxy.js, jsonpath.js, stateMachine.js and helpers.js
  • (patricknitsch) Resolve all remaining ESLint JSDoc warnings (npm run lint is now warning-free)
1.12.0-beta.0 (2026-07-05)
  • (patricknitsch) Update Dependencies
  • (patricknitsch) Add built-in Backup tab: create/upload/restore/download/delete local backups of the instance config, sensors and Data-SOLECTRUS items, with a configurable storage location (InfluxDB token is excluded and must be re-entered after a restore)
  • (patricknitsch) Add Enable iFrame dashboard checkbox: gates both the iFrame config tab and the Dashboard tab in the sensor overview (tab.html); reuse Enable notifications as the single switch that both activates notifications and reveals the Notifications tab
Older changelog entries can be found in CHANGELOG_OLD.md.
Copyright (c) 2026 patricknitsch patricknitsch@web.de
