Simple HTTPS/HTTP reverse proxy manager for ioBroker.
Features
- HTTPS + HTTP in parallel – both servers always run
- Per-host protocol – backend with certificate = HTTPS, without = HTTP
- Certificate per virtual host – ACME (Let's Encrypt), self-signed or manual collections
- Configurable backends via the admin interface
- IP filtering for internal services (CIDR-based, IPv4 + IPv6, multiple networks)
- HTTP → HTTPS redirect with ACME challenge forwarding
- Automatic SSL certificate reload on ACME renewal
- Certificate expiry warning in the log
- HSTS (Strict-Transport-Security)
- WebSocket support (e.g. for ioBroker Admin)
- Dual-stack IPv4 + IPv6
- Change Origin option
Prerequisites
- Node.js >= 22
- ioBroker with js-controller >= 6.0.11
- ACME adapter for automatic SSL certificates (optional – also usable without certificates)
- The configured ports must be available (defaults: 80 for HTTP, 443 for HTTPS)
Configuration
Tab "General"
| Setting | Default | Description |
| HTTPS Port | 443 | Port for HTTPS |
| HTTP Port | 80 | Port for HTTP – backends without a certificate are served here; with certificate → redirect to HTTPS |
| ACME Adapter Port | 0 | Internal port of the ACME adapter (0 = disabled) |
| Enable HSTS | ✓ | Strict-Transport-Security header (HTTPS only) |
| HSTS max-age | 31536000 | HSTS validity duration in seconds (1 year) |
| Check interval | 1 | How often certificates are checked (hours) |
| Expiry warning | 0 | Warn X days before expiry (0 = disabled) |
| Log security events | ✗ | Log denied access (IP filtering, WebSocket) as warning entries |
| Log requests | ✗ | Log every incoming request (IP, host, URL) as debug entries |
Tab "Backends"
Each backend defines a virtual host:
| Field | Description |
| Active | Enable/disable backend |
| Hostname | Domain that points to this server via DNS |
| Target URL | Backend address (http://IP:Port) |
| Certificate | Certificate from system.certificates. With certificate = HTTPS + automatic HTTP→HTTPS redirect. Without certificate = HTTP only (no HTTPS for this host). |
| Allowed Networks | Comma-separated CIDR networks/IPs (e.g. 192.168.0.0/24, fd00::/8). Empty = access from anywhere allowed. |
| Change Origin | Rewrite the Host header to the target IP |
Example Configuration
| Hostname | Target URL | Certificate | Allowed Networks | Change Origin |
website.example.com | http://127.0.0.1:3000 | acme | – | ✗ |
iobroker.example.com | http://127.0.0.1:8081 | default (ioBroker self-signed) | 192.168.0.0/24 | ✗ |
host.example.com | http://192.168.0.1 | (no certificate) | 192.168.0.0/24, 10.0.0.0/8 | ✓ |
In this example:
website.example.com→ HTTPS with Let's Encrypt certificate, HTTP redirects to HTTPSiobroker.example.com→ HTTPS with ioBroker default certificate (default), local network onlyhost.example.com→ HTTP (no certificate), local network only
States
| State | Type | Description |
info.connection | boolean | Proxy is running |
certificates.<name>.expires | string | Expiry date of the certificate (per collection) |
certificates.<name>.daysLeft | number | Days until expiry (per collection) |
Certificate states are created dynamically for each used certificate collection (e.g. certificates.acme.daysLeft, certificates.default.expires).
ACME Adapter Configuration
The ACME adapter must run on a port other than 80, if the proxy runs on the default port 80. ACME challenges are automatically forwarded by the proxy to the configured ACME port.
- Set the ACME adapter port to 8080 (or any desired port)
- Set the same value as the ACME adapter port in the proxy manager
- Enter all desired domains in the ACME adapter
Certificates
The adapter reads certificates from system.certificates and offers three types:
1. Individual Certificates by Naming Convention
These are certificates that the user can add manually through the ioBroker system settings. All key/certificate pairs stored in system.certificates → native.certificates can be used, provided they follow this naming convention:
| Key | Content |
{name}Private | Private key (PEM) |
{name}Public | Certificate (PEM) |
{name}Chained | Full certificate chain (PEM, preferred over Public) |
The base name {name} is what appears in the dropdown and is stored in the config.
Example: If ioBroker has stored the keys
myCertPrivateandmyCertChained,myCertwill appear in the dropdown.
The ioBroker Default Certificate
The self-signed certificate shipped with ioBroker is stored under the names defaultPrivate and defaultPublic in system.certificates. It follows the same convention as any other certificate:
- Base name:
default - Appears in the dropdown as
default - Ideal for internal services that do not require a publicly signed certificate
2. ACME Collections
Let's Encrypt certificates automatically generated by the ACME adapter. They are stored in system.certificates → native.collections under the name assigned to the collection in the ACME adapter configuration. ACME challenges on port 80 are automatically forwarded by the proxy to the configured ACME port.
Per-Host Protocol
The adapter decides per backend whether HTTPS or HTTP is used:
| Backend Certificate | HTTP Request | HTTPS Request |
| Set | 301 redirect → HTTPS | Served with SNI certificate |
| Empty | Served directly (HTTP) | 302 redirect → HTTP |
Both servers run in parallel. Each backend can have its own certificate source. SNI (Server Name Indication) automatically selects the correct certificate for the requested hostname during the TLS handshake.
Hosts with an unknown hostname are rejected at the TLS level – no fallback certificate is used.
Certificate loading details are available in the debug log.
1.0.0 (2026-07-07)
0.1.10 (2026-04-29)
- Harden error handling: certificate loading, renewal, cleanup and adapter teardown are now individually guarded so a single failure no longer aborts the entire operation
- Fix: register server
error/closehandlers before callinglisten()(correct Node.js pattern) - Code quality: remove inconsistent
typeof this.terminateguards, rename misleadingcertHashestocertPemCache, fix template literal formatting
0.1.9 (2026-04-06)
- Optimize logging behavior: request logs now use debug level, transient backend restart errors are logged as debug with details, and startup logs are less noisy ...
- Harden certificate handling: hosts with configured but unavailable certificates now fail closed for HTTPS/WSS instead of falling back silently
- Improve
info.connectionstate handling: state is now true only when both HTTP and HTTPS listeners are active
0.1.8 (2026-03-26)
- Update GitHub Actions test matrix (Node.js 20, 22, 24)
- Address reviewer suggestions (use
node:prefix, specific state roles, interval limiting) - Fix linting errors
0.1.7 (2026-03-20)
- Docs: remove generic installation section per S6014
Copyright (c) 2026 lubepi
