script-restore adapter for ioBroker
Browse and recover individual scripts from ioBroker backup archives — without restoring the entire backup.
Description
The script-restore adapter adds a tab to the ioBroker admin interface that lets you open backup archives and browse all contained JavaScript, TypeScript, Blockly and Rules scripts. You can view the source code of each script and download or copy it individually.
The archive is parsed entirely in the browser — no files are written to disk during browsing.
Features
- Browse backup archives directly from the ioBroker admin tab
- Load local backup files from the backup directory (default:
/opt/iobroker/backups) - Upload archive files directly from your computer
- Supported formats:
.tar.gz,.tar,.json,.jsonl - Tree view of all scripts organized by folder
- Filter scripts by type: JS, TypeScript, Blockly, Rules
- Full-text search across script names, paths and source code
- View source code (JS/TS/Blockly/Rules)
- Copy source code to clipboard or download as file
- Select multiple scripts with the ☐ checkbox and download them as a ZIP archive
- Import ZIP archives from the script-restore export or from the JS adapter's own backup (
2026-07-17-scripts.zip) - Fully browser-based parsing — no server roundtrip for uploads
- Restore scripts directly into ioBroker with a configurable suffix (default:
_rcvr) — existing scripts are never overwritten
Configuration
| Setting | Description | Default |
| Backup path | Directory where ioBroker backup files are stored | /opt/iobroker/backups |
Usage
Loading a local backup file
- Open the Script Restore tab in ioBroker admin
- Click the Local files dropdown
- Select a backup file from the list — scripts are loaded automatically
Uploading a backup file
- Click Upload archive and select a file from your computer
- The archive is parsed in the browser and all scripts are displayed
Viewing and downloading scripts
- Click a script in the tree to view its source code
- Use the Copy button to copy the source to the clipboard
- Use the Download button to save the script as a file
- Click ☐ on the left of a script to select it — select multiple scripts and click ZIP to download them all in one archive
Supported backup formats
| Format | Description |
.tar.gz | Standard ioBroker backup (iobroker_YYYY-MM-DD-HH-mm_SS_backupiobroker.tar.gz) |
.tar | Uncompressed tar archive |
.json | JavaScript adapter script export |
.jsonl | ioBroker objects export (JSON lines) |
.zip (scripts.zip) | Script-restore ZIP export (contains .js/.ts files) |
.zip (JS adapter backup) | JS adapter internal backup (YYYY-MM-DD-scripts.zip, contains .json files with script metadata) |
0.1.13 (2026-07-22)
- (winnyschuster) fix: correct folder indentation in script tree for deeply nested folders
- (ipod86) chore: update dev dependencies (@types/tar, @iobroker/testing, @types/node)
0.1.12 (2026-07-18)
- (ipod86) fix: add 30s timeout to all WebDAV operations
- (ipod86) fix: remove redundant variable alias in handleListLocalFiles
0.1.11 (2026-07-18)
- (ipod86) fix: move @types/tar to devDependencies (W0050, W5060)
0.1.10 (2026-07-18)
- (ipod86) fix: replace shell tar command with pure Node.js tar library for Windows compatibility
- (ipod86) feat: test local backup path button with result feedback
- (ipod86) feat: suggest backup path button
- (ipod86) fix: jsonConfig sendTo result format validation
0.1.9 (2026-07-17)
- (ipod86) feat: checkbox multi-select for ZIP export — click ☐ to select, main click still views only
- (ipod86) feat: import scripts.zip (our adapter export) and JS adapter backup ZIP (2026-07-17-scripts.zip)
- (ipod86) fix: align script list item columns (checkbox, icon, name) with flex layout
0.1.8 (2026-07-15)
- (ipod86) fix: sanitize object IDs from backup paths to prevent invalid ioBroker state IDs
- (ipod86) fix: add 30s timeout to HTTP URL download
- (ipod86) fix: bundle jszip locally in admin tab — no CDN dependency
- (ipod86) fix: zip export now works in all browsers (script tag loading, DOM-append before click)
- (ipod86) fix: remove postinstall lifecycle script from package.json (E0093)
Older changelogs are available in CHANGELOG_OLD.md.
Copyright (c) 2026 ipod86 david@graef.email
