KOSTAL Plenticore G3 API
Adapter to communicate with a KOSTAL Plenticore Plus via local network (non-modbus)
Current Release
1.0.2
fernetmenta
ioBroker.plenticore-g3
plenticore-g3 adapter for ioBroker
Adapter to communicate with a KOSTAL Plenticore (various models, see section below) via REST API. This API is much more powerful than modbus. It gives access to approximately 200 read-only data points referred to as 'processdata' and about 250 writable settings. This API is documented on this URL:
http://<plenticore host>/api/v1
This adapter uses 'Process Data' and 'Settings' of the REST API. Because no user needs all the data available, the adapter has only a very small number of preset processdata and settings but gives the user the option to select additional data points from a list of all availabe process data and settings, respectively.
You can also add your own descriptions to optional data points that will show up as descriptions in iobroker's object tree. In most cases the purpose of a data point can be derived by its name. For example 'devices:local/HomeBat_P' represents the power home uses from the battery.
Naming
Native objects are comprised of a module ID and a data ID, for example 'scb:statistic:EnergyFlow/Statistic:Yield:Day'. The part before the slash is the module ID. In this case 'scb:statistic:EnergyFlow'. In iobroker's object tree a folder structure will be created for the modules ID:
scb
  statistics
    EnergyFlow
Colons in the data ID are replaced by an underscore:
'Statistic:Yield:Day' will become 'Statistic_Yield_Day'
Supported / tested Plenticore models
Despite what the name of the adapter may suggest (that only G3 models are supported), other models are supported too. The API seems to be equal, only the available datapoints may differ. Below is a list of models that were successfully tested by users.
  • Plenticore G3
  • Plenticore plus 10 (G1) - FW Version 01.30.12092
  • Plenticore BI 10/26 (G2) - FW Version 02.15.19562
1.0.2 (2026-09-01)
  • update dependencies
1.0.1 (2026-06-29)
1.0.0 (2026-05-12)
  • reduce number of retries on init
0.5.3 (2026-04-02)
  • fix notification, only send notification about firmware updates every 14 days
0.5.2 (2026-01-04)
  • fix skipping optionals that have become preselected
  • fix not showing settings for battery when present
Copyright (c) 2025-2026 fernetmenta fernetmenta@online.de
