Pi-Hole 2
Manage a pi-hole installation
Current Release
1.5.0
oweitman
pi-hole2 adapter for ioBroker
Manage a pi-hole installation >=v6. Get information from pi-hole. Start/Stop blocking domains. (for pi-hole <v6 please use adapter ioBroker.pi-hole)
USE AT YOUR OWN RISK!!! ABSOLUTELY NO WARRANTY FOR DAMAGES, ETC.!!!
Help or hints are welcome.
This adapter was rewritten for pi-hole V6 based on an idea by Michael Schuster development@unltd-networx.de.
Steps
  1. Install the adpater
  2. Fill in the fields of the adapter-admin. The url of the pi-hole device, the password, and obligatory the intervall to renew the values of the pi-hole (renew statistic in iobroker). Input in all refresh fields only between 1 second and 86400 seconds (24h) possible.
Functions
Enable/Disable the blocking
To Enable/Disable the blocking, please use the switch in Datapoint Blocking. The BlockingTime is only used for disabling the blocking to automaticly reenable the blocking. Enabling takes place immediately.
Detailed information Summary
Some data from Summary is extracted into data points in Data.Summary. This can be enabled/disabled in the configuration. The data points are highlighted green/red when the feature is enabled/disabled.
Detailed information Version
Some data from Version is extracted into data points in Data.Version. This can be enabled/disabled in the configuration. The data points are highlighted green/red when the feature is enabled/disabled.
Current-day domains per client
The optional per-client domain statistics read the Pi-hole query log for the current local calendar day. By default, they are refreshed once per hour. Client requests are distributed over 10 percent of this refresh interval to reduce load on Pi-hole. The percentage is configurable from 0 to 90. The adapter calculates the individual pause from the current number of clients, so the sum of all pauses can never exceed the refresh interval.
For every named Pi-hole client, the adapter creates two JSON states:
pi-hole2.0.Clients.<clientName>.permitted
pi-hole2.0.Clients.<clientName>.blocked
pi-hole2.0.Clients.<clientName>.QueriesTotal
pi-hole2.0.Clients.<clientName>.QueriesBlocked
Each value is a JSON array such as [{"domain":"example.org","count":12}]. A domain occurs only once in each array, and entries are sorted by descending count. Characters not safe in an ioBroker object ID (including . and #) are replaced with _. If two client names result in the same ID, a numeric suffix keeps their states separate. QueriesTotal contains the absolute number of all queries read for the client, while QueriesBlocked contains the absolute number of blocked queries. The names follow the same convention as the detailed summary datapoints.
Pi-hole client names are matched with their IP addresses using the client information returned with the queries. A client with a hostname keeps the sanitized hostname as its ioBroker object ID, while the channel object's display name contains its IP address. If Pi-hole reports only an IP address, the sanitized IP address is used as the object ID as well as the display name.
Pi-hole privacy levels and the Pi-hole excludeClients/excludeDomains settings also apply to this data. The adapter only reads the query log; it does not modify allowlists or denylists.
The optional inactive-client cleanup runs once per local day after 00:05. It recursively deletes a client channel only when its channel object has not been updated since the start of the previous local calendar day and its QueriesTotal state is 0. This means that no write occurred during the complete previous day. Timestamps in the future are not treated as activity. New client channels are created only after at least one query was found for the current day.
General SendTo Function
The sendTo function is used to send commands to the pi-hole device. You can try the api on your local machine. Go to http://pihole/api/docs/#, enter your password, and click the Login button. If the domain pihole doesn't work, please check the hostname of your pi-hole instance in the top right corner of the dashboard page.
Example
sendTo(
    'pi-hole2.0',
    'piholeapi',
        method: 'GET',
        endpoint: '/history/clients',
        params: {
            N: 20,
    function (data) {
        console.log(data);
If you want to use timestamps as parameters, please note that pi-hole uses UNIX timestamps. These count the seconds since January 1, 1970. A JavaScript timestamp can be divided by 1000:
new Date('2025-02-01#12:34:56').getTime() / 1000;
Visualization
Versions with widget jsontemplate for vis and vis2
The jsontemplate widget can be installed via the following documentation: https://forum.iobroker.net/topic/31521/test-widget-json-template
In the widget configuration enter the following datapoint:
pi-hole2.0.Version
and the following template:
<style>
    p.pihole {
        margin: 0px;
    p.pihole .name {
        display: inline-block;
        width: 100px;
    p.pihole .version {
        width: 50px;
</style>
<p class="pihole"><span class="pihole name">core.local:</span><span class="pihole version"><%- data.version.core.local.version %></span></p>
<p class="pihole"><span class="pihole name">core.remote:</span><span class="pihole version"><%- data.version.core.remote.version %></span></p>
<p class="pihole"><span class="pihole name">web.local:</span><span class="pihole version"><%- data.version.web.local.version %></span></p>
<p class="pihole"><span class="pihole name">web.remote:</span><span class="pihole version"><%- data.version.web.remote.version %></span></p>
<p class="pihole"><span  class="pihole name">ftl.local:</span><span class="pihole version"><%- data.version.ftl.local.version %></span></p>
<p class="pihole"><span class="pihole name">ftl.remote:</span><span class="pihole version"><%- data.version.ftl.remote.version %></span></p>
Summary with widget jsontemplate for vis and vis2
pi-hole2.0.Summary
<style>
    p.pihole {
        margin: 0px;
    p.pihole .name {
        width: 150px;
    p.pihole .number {
        width: 70px;
        text-align: right;
</style>
<p class="pihole"><span class="pihole name">queries.total:</span><span class="pihole number"><%- data.queries.total %></span></p>
<p class="pihole"><span class="pihole name">queries.blocked:</span><span class="pihole number"><%- data.queries.blocked %></span></p>
<p class="pihole"><span class="pihole name">clients.active:</span><span class="pihole number"><%- data.clients.active %></span></p>
<p class="pihole"><span class="pihole name">clients.total:</span><span class="pihole number"><%- data.clients.total %></span></p>
Todo Existing Functions
  • login
  • interval time
  • activate / decativate blocking
  • activating / deactivating timeinterval
  • version
  • versions
  • summary
  • type
  • summaryRaw ? dont know details
  • topItems ? dont know details
  • getQuerySources ? dont know details
  • overTimeData10mins ? dont know details
  • getForwardDestinations ? dont know details
Todo New Functions
  • sendTo Functions to control and get informations with parameters
Not Implemented or planned functions
  • 2FA
  • https protocol (possible but not tested)
Troubleshooting
WARNING: No free API seats available
Go to your pi-hole installation and delete in Settings / Webinterface/API / Currently active sessions alls Sessions with User Agent iobroker.pi-hole2. You have restarted the adapter too often and each time a new session is requested.
1.5.0 (2026-08-23)
  • Optional cleanup of clients if no update took place the previous day and QueriesTotal is 0.
  • Unnamed clients with IP addresses have been added. Only clients that have performed at least one DNS query during the day are added.
1.4.2 (2026-08-22)
  • fix pihole session handling
1.4.1 (2026-08-21)
  • An issue with the Pi-hole API prevented all data from being retrieved; this has been fixed.
1.4.0 (2026-08-21)
  • Added QueriesTotal and QueriesBlocked as counts per client.
  • move coverage dir to docs/coverage.
  • fix setTimeout and setObject
1.3.0 (2026-08-20)
  • Added configurable per-client daily domain statistics for permitted and blocked queries, including safe request distribution and JSON datapoints sorted by query count.
1.2.0 (2026-06-10)
  • fix errors
  • add test and coverage
  • improve and harden error handling
1.1.1 (2025-07-25)
  • fix translation
1.1.0 (2025-07-24)
  • add update indicators for different pihole components in the Data/Versions datapoints
1.0.0 (2025-07-16)
  • If the adapter was already installed, please remove all existing data points of the adapter and restart the adapter.
  • first beta channel release
0.4.2 (2025-07-16)
  • set rejectUnauthorized to false
  • remove some double jsdoc blocks
  • fixed comments from adapter review
    remove unload event, create datapoint "Data", adjust state roles, check and limit refresh input parameters, fix roles
0.4.1 (2025-06-27)
  • fix repochecker issues
  • update packages
  • remove history datapoint
  • add jsdoc
  • fix Blockingtime enabling
  • fix datapoint coloring
0.4.0 (2025-06-25)
  • Make extraction of detail values ​​for version/summary deactivatable
0.3.0 (2025-06-25)
  • add translation files
  • rework refresh logic aligned with pihole
  • encrypt password (Password must be entered again )
  • add detailed datapoints for Summary and Version for selected data
0.2.3 (2025-06-25)
  • small documentation bugfix
  • adjust user agent and add trouble shooting info
  • add visualization example for versions
  • add visualization example for summary
0.2.2 (2025-06-24)
  • fix github action file
0.2.1 (2025-06-24)
  • enable NPM deploy
0.2.0 (2025-06-24)
  • (oweitman) first npm release
Copyright (c) 2025-2026 oweitman oweitman@gmx.de
