OekoFEN JSON
Connect OekoFEN Pellematic via JSON to ioBroker
Current Release
2.0.0
chaozmc, iobroker-community-adapters, mcm1957
oekofen-json adapter for ioBroker
Description
This adapter connects a OekoFEN heater with the new touch interface (also called Pelletronic Touch) to ioBroker. As OekoFEN implemented the JSON interface step by step and without public available documentation it should work at least with Version 3.10d and newer. As there are many combinations of heaters, solarmodules, layer storages, sterling engines etc. out there, this adapters tries to read all available datapoints from the interface and creates the objects on the fly at startup.
Read-Only datapoints are created as such as these starts mit L_ prefix in their name. Also converts the adapter the number's scaling according to the informations provided by the interface (factor attribute). For example, the heater deals with temperatures in the format XXX and factor 0.1, this will be converted by the adapter to XX.X on read operations and back to XXX on write operations.
Installation
After installation, it's just required to enter
  • the IP,
  • TCP port,
  • the "so-called" password
  • and the interval
at which the adapter tries to pull the updates.
The adapter maintains the connected state, even there's no real permanent connection. If the device sends an error or the adapter isn't able to contact the OekoFEN controller it set's the connected state to false. For example this could happen if there are too many requests on the controller, which answers with HTTP 401 then. Under normal conditions the rate limit of the controller shouldn't be hit (2,5 seconds between requests).
Credits
This adapter would not have been possible without the great work of Markus Feiler (chaozmc) https://github.com/chaozmc, who created previous releases of this adapter.
2.0.0 (2025-11-26)
  • (mcm1957) Adapter has been migrated to iobroker-community-adapters organisation
  • (mcm1957) Adapter requires node.js >= 20, js-controller >= 6.0.11 and admin >= 7.6.17 now
1.0.5 (2023-09-23)
  • (chaozmc) set min node version to 18.x (merge pull request #23)
1.0.4 (2023-09-22)
  • (chaozmc) Removed Node 16.x from Test-and-release (fix Issue #19)
  • (chaozmc) updated dependencies
  • (chaozmc) updated protobufjs and google-gax
  • (chaozmc) updated word-wrap
1.0.3 (2023-05-09)
  • (chaozmc) Bump version
1.0.2 (2023-05-09)
  • (chaozmc) Added missing translations
  • (chaozmc) Updated Copyright Year
  • (chaozmc) Added .releaseconfig.json for release-script
  • (chaozmc) changed github workflow config
0.0.3
  • (chaozmc) code cleanup, trigger for update & rescan
0.0.2
  • (chaozmc) first working release, fixed 0-value updates
0.0.1
  • (chaozmc) initial build phase, much try and error
Copyright (c) 2025-2026 iobroker-community-adapters iobroker-community-adapters@gmx.de
Copyright (c) 2023 chaozmc chaozmc@is-jo.org
