This adapter uses Sentry libraries to automatically report exceptions and code errors to the developers. For more details and instructions on disabling error reporting, please refer to the Sentry-Plugin Documentation! Use of Sentry reporting starts with js-controller 3.0.
I use my own Sentry server based on Glitchtip.
Description
This adapter allows for detailed monitoring of your Nextcloud instance via the official OCS API (serverinfo). It provides numerous system data, user statistics, shares, as well as performance values from PHP (OPcache/FPM) and the database directly in ioBroker.
Features
- System Status: CPU load, RAM usage, free disk space, and Nextcloud version.
- User Statistics: Number of active users (5 min, 1 hr, 24 hr), total number of files, and storage usage.
- Shares: Monitoring of link shares, Talk rooms, and federated shares.
- Server Health: PHP version, memory limit, OPcache hit rate, and detailed FPM process statistics.
- Widget: Use the internal widget, which creates an htmlWidget data point in the location folder; or, if you wish to customize it yourself, use this one.
Installation & Configuration
1. Connection Settings
- Domain: Enter your Nextcloud domain without
https://(e.g.,cloud.yourdomain.com). - Token: The OCS API token of your Nextcloud (see section "How-To: Token").
- Update Interval: Time in minutes between API requests (Default: 10 min, Minimum: 5 min).
- Multible Server: You can now add multible Server e.g.: my_server_1, and next server e.g.: other_server_2
- Widget:
- Enable: Check the "Create Widget" checkbox in the instance settings for your location.
- Find State: The adapter will create a state called
htmlWidget(undernextcloud-monitoring.0.SERVERNAME.htmlWidget). - In VIS/VIS2: * Drag a standard "HTML" widget onto your view.
- Set the "HTML" property of that widget to the binding of your state:
{nextcloud-monitoring.0.SERVERNAME.htmlWidget}. - Adjust the width and height of the widget container to fit the content.
2. Data Options
- Skip Apps: Disables the detailed list of installed apps to reduce API load.
- Skip Update Check: Disables checking for new Nextcloud versions.
How-To: Create & Set Token
Accessing the serverinfo API requires a valid API token. This token must be stored directly in the Nextcloud configuration.
Generate the Token (Linux / Windows)
To enable access, you must generate a token (a random string) and register it in your Nextcloud instance using the occ tool.
Command to generate the token:
- Linux (Terminal):
openssl rand -hex 32
- Windows (PowerShell):
$bytes = New-Object Byte[] 32; (New-Object System.Security.Cryptography.RNGCryptoServiceProvider).GetBytes($bytes); [System.BitConverter]::ToString($bytes).Replace("-", "").ToLower()
- Alternatively, you can use online tools such as
it-tools.tech/token-generator.*
Set Token in Nextcloud
Example for Linux (Standard path) in Terminal:
sudo -u www-data php /path_to/your/nextcloud_folder/occ config:app:set serverinfo token --value YOUR_GENERATED_TOKEN
Example for Linux (Directly in your Nextcloud folder) in Terminal:
sudo -u www-data php occ config:app:set serverinfo token --value YOUR_GENERATED_TOKEN
If you use your Nextcloud in a webspace or other Provider, mostly you don't need sudo, simply do:
#Directly in your Nextcloudfolder
#Or with path
Command for Windows (PowerShell/CMD): Navigate to your Nextcloud directory and execute:
Monitored Data Points (Excerpt)
| Path | Description | Data Type |
system.version | Installed Nextcloud version | string |
system.cpuload_1 | CPU load of the last minute | number |
system.freespace | Free disk space | string |
storage.num_users | Total number of users | number |
server.php.opcache_hit_rate | Efficiency of the PHP cache | string |
fpm.active_processes | Active PHP-FPM processes | number |
activeUsers.last5min | Users active in the last 5 minutes | number |
Troubleshooting (FAQ)
Invalid Domain: Enter the domain without a protocol.
Correct: mycloud.com or mycloud.com/folder
Incorrect: https://mycloud.com or http://mycloud.com/folder
API delivers no data:
Ensure that the "Server Info" app (standard app) is enabled in your Nextcloud under "Apps". Without this app, the adapter cannot retrieve any data.
Token Error:
Verify if the token was correctly saved in Nextcloud using:
- In Linux:
sudo -u www-data php /path_to/your/nextcloud_folder/occ config:app:get serverinfo token
- Or if you are directly in folder, use:
sudo -u www-data php occ config:app:get serverinfo token
- If you use your Nextcloud in a webspace or other Provider, mostly you don't need sudo:
php occ config:app:get serverinfo token or php /path_to/your/nextcloud_folder/occ config:app:get serverinfo token
Maintenance Mode:
If your Nextcloud is in maintenance mode, the adapter will not be able to fetch data and will log an info. This is normal behavior as the API is disabled during maintenance.
2.1.2 (2026-09-12)
- (H5N1v2) add node.js 26.x testmatrix
- (H5N1v2) update dependencies
2.1.1 (2026-07-06)
- (H5N1v2) chore: update dependencies
- (H5N1v2) fix: [W5612] add translations for 'your-cloud.com' in multiple languages
- (H5N1v2) fix: [E6025] README.md must contain exactly one H1 heading, but found 6.
2.1.0 (2026-05-09)
- (H5N1v2) widget toggleable in the admin area.
- (H5N1v2) update dependencies.
- (copilot) Adapter requires node.js >= 22 now.
2.0.6 (2026-03-30)
- (H5N1v2) Update axios dependency to version 1.14.0
2.0.5 (2026-03-26)
- (H5N1v2) add sentry plugin to automatically report errors to developer
Support & Feedback
If you encounter any bugs, have feature requests, or want to suggest improvements, please feel free to open an Issue on GitHub. This helps to track the progress and helps other users with similar problems.
Copyright (c) 2026 H5N1v2 h5n1@iknox.de
