Crawls information from public netatmo stations
Current Release
1.2.0
Bart19, Backfisch88, mcm1957, iobroker-community-adapters
netatmo-crawler adapter for ioBroker
Table of contents
Instruction
To find the url of your preferred weather station, follow these steps:
  1. Open the Netatmo Weathermap
  2. Find your station and click the share icon
    Share Image
  3. Click on copy link
    Copy Link
  4. Insert the link in the instance settings of the adapter
    Insert
General information
The “Netatmo Crawler” parse a lot of real local information near you. What do you do with all this information? Here are some general facts and examples:
Humidity
Netatmo use the relative humidity, this is the ratio of the current absolute humidity to the highest possible absolute humidity (which depends on the current air temperature). A reading of 100 percent relative humidity means that the air is totally saturated with water vapor and cannot hold any more, creating the possibility of rain. This doesn't mean that the relative humidity must be 100 percent in order for it to rain — it must be 100 percent where the clouds are forming, but the relative humidity near the ground could be much less.
Rain
Uses the unit millimeter. If you wish the unit liter per meter cube, you can use this anyway. You can use it for watering in the garden (for example).
Pressure
The air around you has weight, and it presses against everything it touches. That pressure is called atmospheric pressure, or air pressure. What should you do with this value? As simple as it sounds: Weather forecast! High pressure = good weather, low pressure = bad weather. The normal middle value is 1013 mBar. For “real” weather forecast you should need pressure history for some hours (I use four hours). If it falls it should be bad weather in future, if it rise it should be good weather. I found a script for forecast here (it’s called zambretti method for a 90% forecast). Other units: 1 mbar = 100 Pa = 1 hPa
Temperature
Here you can calculate chill temperature level. For low temperatures the windchill (10 °C or lower, calculate with wind) for high temperatures you can use the heat index (25 °C or higher, calculate with humidity). example script:
windchill1 = windchill(temp, windkmh); //Vars to-from IOBroker
function windchill(temperature, windspeed) {
	var windchill = 13.12 + 0.6215 * temperature - 11.37 * Math.pow(windspeed, 0.16) + 0.3965 *
			temperature * Math.pow(windspeed, 0.16);
	return windchill;
heatindex1 = heatindex(temp, hum); //Vars to-from IOBroker
function heat(temperature, humidity) {
	var heatindex = -8.784695 + 1.61139411 * temperature + 2.338549 * humidity - 0.14611605 *
			temperature * humidity - 0.012308094 * (temperature * temperature) -
			0.016424828 * (humidity * humidity) + 0.002211732* (temperature *
			temperature) * humidity + 0.00072546 * temperature * (humidity * humidity)
			- 0.000003582 * (temperature * temperature) * (humidity * humidity);
	return heatindex;
Wind
Wind speed is a measure from air moving from high to low pressure, usually due to changes in temperature. The gust strength is the highest value of wind, measured in a short time (something like three seconds). You should do a script for your awning or for the Zambretti method (look above).
Credits
This adapter would not have been possible without the great work of @bart1909 (https://github.com/jbart1909)", who created pre V1.x.x releases of this adapter.
Many thanks to backfisch for the initial idea and support!
1.2.0 (2026-05-10)
  • (mcm1957) Dependencies have been updated.
1.1.0 (2025-09-27)
  • (mcm1957) Adapter requires node.js 20, js-controller 6.0.11 and admin 7.6.17 now.
  • (Bart1909) Missing headers have been added [#95, #96]
1.0.0 (2025-06-13)
  • (Bart1909) A problem handling urls and authentication has been fixed.
  • (mcm1957) Adapter has been migrated into iobroker-community-adapters organisation.
  • (Bart1909) Adapter requires node.js 20, js-controller 6.0.11 and admin 7.4.10 now.
0.8.0
  • (Bart19) Adds additional 'rain_lastHour' state as 'rain' state is now real time value
0.7.1
  • (Bart19) removed old news (#17)
Copyright (c) 2025-2026 iobroker-community-adapters iobroker-community-adapters@gmx.de
Copyright (c) 2022 Bart19 webmaster@bart19.de
