MiHome Cloud
Adapter for all MiHome Cloud devices
Current Release
1.0.6
TA2k
mihome-cloud adapter for ioBroker
Adapter for all Mi Home Cloud devices. Connects to the Xiaomi Cloud API and provides status, control and scene execution for all devices registered in your Mi Home account.
This adapter uses Sentry libraries to automatically report exceptions and code errors to the developers. For more details and for information how to disable the error reporting see Sentry-Plugin Documentation! Sentry reporting is used starting with js-controller 5.0.
Requirements
  • Node.js >= 22
  • js-controller >= 6.0.11
  • Admin >= 7.6.20
Configuration
In the adapter settings you can configure:
SettingDescription
RegionSelect the Xiaomi Cloud region matching your Mi Home app (Germany, China, Russia, Taiwan, Singapore, USA)
Update intervalPolling interval in minutes for device status updates via the Xiaomi Cloud API (minimum 1 minute in Admin UI)
Block additional runtime login attemptsIf enabled, no additional automatic login attempts are started during runtime after the initial startup attempt.
Login
The adapter uses a URL-based login (no username/password needed in the adapter settings).
  1. Configure Region, Update interval and (optionally) Block additional runtime login attempts in the adapter settings and save.
  2. Start the adapter.
  3. If no valid persisted session is available, the adapter creates a login URL and exposes it in two places:
    • as a warning in the adapter log
    • as state mihome-cloud.0.auth.loginUrl
  4. Open the URL in your browser and sign in with your Xiaomi account.
  5. The adapter detects the successful login automatically and connects.
When the session expires server-side, the adapter clears the invalid session and switches to re-authentication state (mihome-cloud.0.auth.status = reauth_required).
  • Startup behavior: If no valid session exists on adapter start, one login attempt (login URL generation) is triggered.
  • Runtime behavior: Automatic re-login attempts are scheduled after authentication failures/session expiry.
  • Optional runtime block: If Block additional runtime login attempts is enabled, no further automatic login attempts are started during runtime.
The session is persisted in auth.session and can be reused after adapter restarts when still valid.
Object tree
After startup and login, the adapter creates the following object structure:
mihome-cloud.0.info.connection
Connection indicator (true/false) for the Xiaomi Cloud session.
mihome-cloud.0.auth.*
Authentication runtime and session states:
  • auth.status - current authentication state (for example connected, qr_login_pending, reauth_required, cooldown_wait)
  • auth.loginUrl - current Xiaomi login URL used for browser login
  • auth.session - persisted cookie/session JSON for session restore
Per device, the adapter creates:
If the Xiaomi account or configured region changes, old device objects are removed and recreated for the current account/region.
mihome-cloud.0.<device-id>.general
General device information (model, name, firmware version, etc.).
mihome-cloud.0.<device-id>.status
Read-only states from MIoT specification properties (polled at the configured update interval).
Event indicator states may exist depending on model/spec parsing, but cloud event subscription is currently not active in this adapter.
mihome-cloud.0.<device-id>.remote
Writable MIoT specification properties and actions.
  • Writable properties are sent via MIoT prop/set
  • Actions are sent via MIoT action
  • Actions with input arguments expect JSON input in the state value
After commands, the adapter performs an automatic status refresh for MIoT spec and custom states (vacuum status updates continue via normal polling cycle).
mihome-cloud.0.<device-id>.custom
Model-specific states from internal configDes mappings (for example vacuum metrics such as clean_area, clean_time, battery).
mihome-cloud.0.<device-id>.remotePlugins
Additional writable commands extracted from Xiaomi plugin bundles (best-effort, depends on plugin/model).
mihome-cloud.0.scenes
Smart scenes / automations from your Mi Home account. Set a scene state to true to execute it.
Example: Robot vacuum room cleaning
  1. Find room IDs:
    mihome-cloud.0.<id>.remote.get-map-room-list – requires [cur-map-id] as input.
    You can get the current map ID from mihome-cloud.0.<id>.status.cur-map-id, or query the map list via:
    mihome-cloud.0.<id>.remote.get-map-list (no input needed) → result appears under mihome-cloud.0.<id>.status.map-list
  2. Set the map ID and query rooms:
    mihome-cloud.0.<id>.remote.get-map-room-list with input [<map-id>]
    → Result: mihome-cloud.0.<id>.status.room-id-name-list: [{"name":"room1","id":10}]
  3. Start room cleaning:
    mihome-cloud.0.<id>.remote.start-room-sweep with format ["10", "11", "12", "13"]
    or
    mihome-cloud.0.<id>.remote.set-room-clean with format ["10",0,1]
Troubleshooting
  • "DB closed" warnings: Harmless – these are now proactively prevented during adapter shutdown by a clean termination flag.
  • "ECONNRESET" errors: Temporary network interruptions to the Xiaomi Cloud. The adapter retries automatically at the next polling interval.
  • "-106 device network unreachable": The device (e.g., a vacuum cleaner) is currently offline, disconnected from Wi-Fi, or powered off. The adapter will log this as debug and keep trying.
  • 401/400 authentication errors: The adapter clears the invalid session and enters re-authentication mode. A new login URL is provided via log warning and auth.loginUrl if automatic login attempts are enabled.
  • No new login URL after session expiry: Check Block additional runtime login attempts. If enabled, runtime auto-retries are suppressed by design.
  • Device tree rebuilt after account/region change: Expected behavior. The adapter removes old device objects and recreates them for the active account/region.
  • No properties for device: Some pure Zigbee/Bluetooth sensor devices (e.g. lumi.sensor_switch.v2) do not expose their status via the Cloud API. Consider using a local Zigbee adapter instead.
Discussion and questions
https://forum.iobroker.net/topic/59636/test-adapter-mihome-cloud
1.0.6 (2026-04-29)
  • (lubepi) NEW: Added admin option to block additional automatic runtime login attempts to reduce log spam
  • (lubepi) ENHANCED: Exposed Xiaomi login URL in auth.loginUrl for automation and easier re-authentication handling
  • (lubepi) ENHANCED: Updated README
  • (lubepi) FIXED: Suppress "DB closed" warnings during adapter shutdown and restart by implementing a clean shutdown flag
  • (lubepi) ENHANCED: Optimized error handling to prevent uncontrolled adapter crashes from expired sessions and missing null guards
1.0.5 (2026-04-01)
  • (lubepi) improve 401 authentication error handling and session reset
  • (lubepi) validate and limit user configurable update interval
  • (lubepi) update dependencies to address vulnerabilities
1.0.4 (2026-03-14)
  • (lubepi) Maintenance update: Consolidated changelog and fixed repository metadata for better standards compliance
1.0.3 (2026-03-14)
  • (lubepi) Improved error handling for network interruptions
  • (lubepi) Migration to external i18n files and Node.js 20+ requirement
  • (lubepi) Updated dependencies and fixed known vulnerabilities
  • (lubepi) Added missing translations (uk, ru, pt, nl, fr, it, es, pl, zh-cn)
  • (lubepi) Migration to ESLint flat config and release-script support
0.2.2
  • (lubepi) Minor improvements with device handling
0.2.1
  • (lubepi) Fix login. Check Log after starting Adapter
0.2.0
0.0.5
  • (TA2k) Bugfixes
0.0.4
  • (TA2k) initial release
Copyright (c) 2023-2026 TA2k tombox2020@gmail.com
