Xiaomi Air Purifier
Controll your Xiaomi Air Purifier
Current Release
0.1.8
Johannes Jaeger
How to get the token?
You have to install the miio command line tool npm install -g miio
Now you have two options:
  1. With Mi Home App:
    You connect the purifier with MI Home App to your Wifi Network and then run the following command:
    miio discover
    You should get the following output and can save the token.
    Device ID: 48765421
    Model info: zhimi.airpurifier.m1
    Address: 192.168.100.9
    Token: token-as-hex-here via auto-token
    Support: At least basic
  2. Without Mi Home App:
    You reset the WIFI settings of the air purifier. Then you connect your network with the WIFI of the air purifier and run the following command:
    miio discover
    You should get the same output as above and can now configure the connection to your network by following command:
    miio configure id-or-address --ssid ssid-of-network --passwd password-of-network
    Now the air purifier is connected to your network.
Cloud Connection
To control the Air Purifier with the cloud adapter just add the state "manuallevel" to your Cloud Adapter. After that you can send f.e. the following commands through Alexa:
Alexa, turn the air purifier on,
Alexa, set the air purifier to 50%,
Alexa, turn the air purifier off
If you set in the Cloud adapter the "On Value" to "Last active value", the device always start running in the latest active power level.
Control States
To control your air purifier, the following objects can be written:
StateDescription
powerTurn the device on / off
autoActivate the auto mode of the device.
silentActivate the silent mode of the device.
manualActivate the manual mode of the device.
manuallevelControl the power of the manual mode in the range from 0-100%. This will also turn on / off the device if necessary
ledTurn the auto led on / off
buzzerTurn the buzzer on / off
Info States
The following information is collected from your air purifier (read-only states):
Device Info
StateDescription
modeThe actual device mode, just valid, if the device is powered on.
temperatureThe measured temperature in °C of the device.
humidityThe measured relative humidity in % of the device.
pm25The air pollution in PM2.5.
filterLifeRemainingThe remaining filter life in hours.
filterHoursUsedThe used hours of the filter.
0.1.8 (02.05.2020)
  • (JoJ123) bug: npm install
0.1.7 (01.05.2020)
  • (JoJ123) bug: interval load data
0.1.6 (01.05.2020)
  • (JoJ123) support for 'zhimi.airpurifier.mc1'
0.1.5 (01.05.2020)
  • (JoJ123) add new parameter
0.1.4 (01.05.2020)
  • (JoJ123) bug fixing
0.1.1 (18.04.2020)
  • (JoJ123) move to typescript
0.0.6 (09.04.2019)
  • (JoJ123) update miio to fork of Sineos
0.0.5 (06.01.2019)
  • (JoJ123) update natives
0.0.4 (02.01.2019)
  • (JoJ123) update type
0.0.3 (18.12.2018)
  • (JoJ123) npm release
0.0.2 (29.11.2018)
  • (JoJ123) auto reconnect
0.0.1 (10.10.2018)
  • (JoJ123) initial release
The MIT License (MIT)
Copyright (c) 2019 Johannes Jaeger johannesjaegeroffice@gmail.com
Copyright (c) 2020 Johannes Jaeger johannesjaegeroffice@gmail.com
