MaxxiCharge
Adapter to fetch data from MaxxiCharge CCU
Current Release
1.4.48
Christoph Böhrs
ioBroker.MaxxiCharge is an adapter for the ioBroker system that enables the integration and control of MaxxiCharge CCU devices. The adapter provides a range of features, including reading device data, adjusting configurations, and sending control commands.
http://www.maxxisun.de
Documentation
🇺🇸 Documentation
🇩🇪 Dokumentation
Version Compatibility
CCU V1Local APICloud API
0.36 - 0.40
0.41 or newer
  • MaxxiSun can deactivate cloud services at any time. Local mode is always more secure for CCU 1.
CCU V2Local APICloud API
<= 2.10.1
Comming Soon
🔹 Legend:
✅ - Compatible
❌ - Not compatible
❓ - Unknown
  • Requires Node.js >= 22
  • Adding CCU V2 Support
  • Migrated from JavaScript to TypeScript
  • Replaced Axios with native fetch
  • Fixed BKW mode after deactivation
  • Dependencies update
1.4.48 (2026-04-02)
  • Added optional cloud sync when using local mode
  • Redesign Adapter Config Page
1.4.40 (2025-05-13)
  • New Option Mode "BKW"
    At a battery level of ≥ 97%, the script enables BKW mode to feed a constant 600–800 W into the grid alongside household use, potentially receiving compensation if registered as a balcony power system (BKW).
1.4.11 (2025-03-17)
  • CloudApi: Request times no longer aligned to second 0 on all adapters, improving load distribution.
  • Updated dependencies.
1.4.9 (2025-02-08)
  • Bugfix on Battery Calibration.
  • Fixes for stable release on ioBroker adapter.
  • Feedback update
1.4.1 (2025-01-12)
  • Please delete the .sendcommand folder and restart the adapter when updating from a previous version to this one.
  • New: Added support for battery calibration (Expert Settings)
  • Improved: Redesigned adapter settings for a better user experience
1.3.13 (2025-01-07)
  • Fixed: Issue with the dcAlgorithm datapoint where the UI could crash due to an incorrect states definition
  • Removed the info.localip datapoint. The local IP address is now directly included in the jsonConfig.
  • Adjusted code to use modern methods, replacing deprecated ones like setObjectAsync.
1.3.0 (2024-12-15)
  • Summer/Winter mode added:
    • Dynamic adjustment of charging parameters based on seasons.
    • Configurable with start and end dates.
  • Cloud API query interval: CCU polling in cloud mode is fixed at 5 seconds.
Older changelogs can be found in CHANGELOG_OLD.md.
Copyright (c) 2024-2026
