ioBroker.MaxxiCharge — это адаптер для системы ioBroker, обеспечивающий интеграцию и управление устройствами MaxxiCharge CCU. Адаптер предоставляет ряд функций, включая чтение данных устройства, настройку конфигураций и отправку команд управления.
Документация
Совместимость версий
| CCU V1 | Локальный API | Облачный API |
| 0.36 - 0.40 | ❌ | ✅ |
| 0.41 или новее | ✅ | ✅ |
- MaxxiSun может в любой момент отключить облачные сервисы. Локальный режим всегда более безопасен для CCU 1.
| CCU V2 | Локальный API | Облачный API |
| <= 2.10.1 | ❌ | ❌ |
| Скоро в продаже | ❓ | ❓ |
🔹 Легенда :
✅ - Совместимо
❌ - Несовместимо
❓ - Неизвестно
- Requires Node.js >= 22
- Adding CCU V2 Support
- Migrated from JavaScript to TypeScript
- Replaced Axios with native fetch
- Fixed BKW mode after deactivation
- Dependencies update
1.4.48 (2026-04-02)
- Added optional cloud sync when using local mode
- Redesign Adapter Config Page
1.4.40 (2025-05-13)
- New Option Mode "BKW"
At a battery level of ≥ 97%, the script enables BKW mode to feed a constant 600–800 W into the grid alongside household use, potentially receiving compensation if registered as a balcony power system (BKW).
1.4.11 (2025-03-17)
- CloudApi: Request times no longer aligned to second 0 on all adapters, improving load distribution.
- Updated dependencies.
1.4.9 (2025-02-08)
- Bugfix on Battery Calibration.
- Fixes for stable release on ioBroker adapter.
- Feedback update
1.4.1 (2025-01-12)
Please delete the
.sendcommandfolder and restart the adapter when updating from a previous version to this one. - New: Added support for battery calibration (Expert Settings)
- Improved: Redesigned adapter settings for a better user experience
1.3.13 (2025-01-07)
- Fixed: Issue with the dcAlgorithm datapoint where the UI could crash due to an incorrect states definition
- Removed the info.localip datapoint. The local IP address is now directly included in the jsonConfig.
- Adjusted code to use modern methods, replacing deprecated ones like setObjectAsync.
1.3.0 (2024-12-15)
- Summer/Winter mode added:
- Dynamic adjustment of charging parameters based on seasons.
- Configurable with start and end dates.
- Cloud API query interval: CCU polling in cloud mode is fixed at 5 seconds.
Older changelogs can be found in CHANGELOG_OLD.md.
Copyright (c) 2024-2026
