matrix-org adapter for ioBroker
Adapter for matrix push messages Big thanks for creating matrix (https://matrix.org/) for creating a full free communication base
Configuration
Best: Run your own client on your server!
Create an own user as your BOT with password. Create a room for all members who want the bot messages. Add your BOT to this room (not needed if autojoin is active). Add all members to this room. Put all the data into the config. (BOT name, password, room name)
Usage
Add as many instances as you need. Add a value to matrix-org.0.sendMessage on the way you like, with js If you set "image" to matrix.0.sendMessage, it will send the matrix logo to your channel. Or in js use:
sendTo("matrix-org.0", "Hello World!");
Or use the blockly symbol in Sendto.
For images from local file system (Linux):
sendTo("matrix-org.0",{file: "file:///tmp/images/test.png"});
For images from local file system (Windows):
sendTo("matrix-org.0",{file: "file:///C:/tmp/images/test.png"});
For images as reference:
sendTo("matrix-org.0",{file: "https://www.abcd/images/test.png"});
For images in base64:
sendTo("matrix-org.0",{file:{type:"image/png",base64:"iVBORw0KGgoAAAANSUhEUgAAACAAAAAgCAYAAABzenr0AAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAACmSURBVFhH7ZdhCoAgDEZnd9D737T8xJkNNY1Ef+yB2LTcC1qWOT20kCBgjIkh0WwfmeuIxyGYnRzIPElgFSqgAvsKOOdCzeZ1y7EcZzDG16HvwtckihLdA4xxk3HeGGttc17Cc+lN6Ds/dlO6w6/ItQHn7H4GcDK3Em/zNboE5KKjcQstQxVQARVYLlDdC2YzvBfMQgVUYB8BlMWfn2E1ZJ7Fv+dEF0UZoNhXp9NnAAAAAElFTkSuQmCC"}});
Or
sendTo("matrix-org.0",{file:"data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAACAAAAAgCAYAAABzenr0AAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAACmSURBVFhH7ZdhCoAgDEZnd9D737T8xJkNNY1Ef+yB2LTcC1qWOT20kCBgjIkh0WwfmeuIxyGYnRzIPElgFSqgAvsKOOdCzeZ1y7EcZzDG16HvwtckihLdA4xxk3HeGGttc17Cc+lN6Ds/dlO6w6/ItQHn7H4GcDK3Em/zNboE5KKjcQstQxVQARVYLlDdC2YzvBfMQgVUYB8BlMWfn2E1ZJ7Fv+dEF0UZoNhXp9NnAAAAAElFTkSuQmCC"});
For html please follow this spec: https://spec.matrix.org/v1.3/client-server-api/#mroommessage-msgtypes E.g.:
sendTo("matrix-org.0",{html: "<h1>Hello World!</h1>", text: "Hello World!"});
or
sendTo("matrix-org.0",{html: "<table><tr><td>1</td><td>2</td></tr><tr><td>a</td><td>b</td></tr><table>", text: "Your client can not show html!"});
If your client is not able to decode html you will get the text. If your client do not support table it either show the text or simply 12ab.
to test your configuration use sendMessage
simply open the objects and change the string of one matrix-org instance Mostly the port is 443, if you have a public system like matrix.org The port is sometimes 8448, when you have a self hosted system without proxy, but then you know it.
If you like to test it: Server: matrix.org Port: 443 room: #test-ioBroker-adapter:matrix.org Join this room and try it out with your own credentials
- some bumps
1.2.2 (2026-03-29)
- string normalisation due to bug report #95
- some bumbs
1.2.1 (2026-02-12)
- set body in send file to matrix
1.2.0 (2025-10-17)
- upgrade matrix-js-sdk to 38.4.0 node 22 required
- switch to ESM
- eslint 9 (what a messi commit)
1.1.0 (2024-11-23)
- auto join added (default false)
1.0.0 (2023-04-01)
- upgrade matrix-js-sdk (node 18 needed)
Copyright (c) 2026 Christian Oelschlegel iobrokermatrix@sciphy.de
