Linux Control
Controlling Linux devices and information about your system
Current Release
1.1.5
Scrounger
Linux Control Adapter for ioBroker
paypal
Controlling Linux devices and get information about your system
Configuration
General
General
settingdescription
enabledenabled or disable updating of the host
datapoint idid under which all datapoints are to be stored
IPIP address of your linux device
PortSSH Port of your linux device
polling intervalpolling interval in minutes.
To deatcivate the polling you can use '0' or leave it blank
userssh user for login
password / passpharsessh password for login or passpharse if you use a rsa key
use Sudousing sudo
legacy SSHenable legacy / deprecated SSH key exchange & cipher algorithms (e.g., diffie-hellman-group1-sha1, 3des-cbc, ssh-rsa) for older devices/switches
rsa keypath and filename of your rsa key. Access rights must be available!
timeoutconnection timeout
Datapoints
Datapoints
The adapter creates predefined datapoints with information and the possibility to control the Linux device. These can be selected here. In addition, for each individual host, individual data points or entire channels can be placed on the blacklist by drag & drop so that they are not created for the host.
Note if you would like to add the whole channel to the blacklist, you must drag & drop the channel node to the blacklist. Only then the whole channel will be ignored - see sreenshot below:
Datapoints
Due to the many different Linux distributions this feature is only tested with Debian 10, Ubuntu 18 / 20 LTS!
Services
Services
If the retrieval of services under datapoints is activated, you can define here per host for which services only information should be retrieved.
Folders
Folders
Here you can retrieve information about the size of folders, count of the files included in these folders and the timestamp of the last change in this folder.
settingdescription
enabledenabled or disable updating of the folder
HostHost which should be used
Pathpath of the folder
filename patternpattern for files names which should be regonized.
UnitUnit for size
decimal placesdecimal places
count of filescreate datapoint for count of files
last changecreate datapoint for timestamp of the last change in this folder
My Commands
Custom Commands
Here, very individual commands can be defined and then written to your own defined data points. It is important that the retrieved data is transmitted in the correct type! The type must then be configured accordingly.
settingdescription
enabledenabled or disable updating of the command
datapoint idid under which datapoints are to be stored
polling intervaldiffrent polling interval in seconds for the command only. For deactivating use 0 or leave the field blank, then the polling interval from the host is used
descriptiondescription / name of the datapoint
commandcommand that should be used
If you use a user that needs sudo then you have to add sudo -S to your own command!
typetype of the datapoint
unitunit of the datapoint
Known Issues
  • if its not possible to get connection to your linux client, check if iputils-ping is correct installed on client
  • (meistermopper) add optional legacy SSH algorithms support for older devices (closes #90)
  • (meistermopper) add Biome linter, npm run test:local workflow and align with harvia-fenix quality standard
  • (meistermopper) fix invalid common.states type for command.host object
  • (meistermopper) update dependencies, adminUI configuration and repochecker compliance
1.1.6 (2022-09-06)
  • (Scrounger) global interval for update informations added
  • (Scrounger) fix invalid object host
1.1.6 (2026-07-23)
  • (meistermopper) Improved timer resource cleanup on unload using adapter-core safe timeouts
  • (meistermopper) Enforced state ack handling filter in onStateChange
  • (meistermopper) Added legacy SSH key exchange and cipher algorithm support
1.1.5 (2022-05-03)
  • (Scrounger) Dependencies updated
1.1.4 (2021-12-18)
  • (Scrounger) always create my command datapoint
1.1.3 (2021-10-04)
  • (Scrounger) show warn message if permission denied
  • (xCruziX) preformance improvment
1.1.2 (2021-01-08)
  • (Scrounger) show error if user is not in sudoers file
  • (Scrounger) bug fix if response has no result optimized
  • (Scrounger) myCommands: bug fix sudo is no longer mandatory
Older changelogs can be found in CHANGELOG_OLD.md.
Copyright (c) 2020-2026 Scrounger scrounger@gmx.net
