LG ESS Home adapter for ioBroker
An iobroker adapter for a LG ESS hybrid inverter. With this adapter, the status of the inverter can be read. It is also possible to operate the inverter.
Configuration
Getting the password
Possibility Number 1
The password is the MAC address of the LAN interface of the ESS in lower case and without :. The MAC address can be read in the Fritzbox (or other router). (Thanks riessfa)
Possibility Number 2
- Download the file LG_Ess_Password.exe
- Connect the computer to the WLAN of the LG_ESS system. (WLAN password is on the type plate)
- Start LG_Ess_Password.exe (At least .Net Framework 4.5 required)
- Make a note of your password
Possibility Number 3
For those, who don't like exe: (Thanks grex1975)
you can use any REST Client to get the password:
- connect to the WLAN of the LG_ESS
- Execute a POST request
Url: https://192.168.23.1/v1/user/setting/read/password
Headers: "Charset": "UTF-8", "Content-Type": "application/json"
{Body: "key": "lgepmsuser!@#"}
This should give you the password and a status in return.
0.4.1 (2024-12-23)
- (Morluktom) Bugfix lg-ess-home.0.user.essinfo.common not updated
- (Morluktom) Responsive Design added
0.4.0 (2024-12-23)
- (Morluktom) Bugfix: State value to set for "lg-ess-home.0.user.essinfo.home.statistics.bat_status" has to be type "number" but received type "string"
- LG ESS HOME 15 Plus added
- Switch AutoCharge and backup soc writeable
0.3.0 (2024-08-10)
- (Morluktom) Fixed warnings found by adapter checker
- (Morluktom) Added Admin 5 configuration
- (Morluktom) Added Ukrainan language
- (Morluktom) Add PV Forecast to chart
- (morluktom) NodeJS >= 18.x and js-controller >= 5 is required
0.2.3 (2022-04-05)
- (Morluktom) Chart widget: Datepicker changed to jquery
0.2.2 (2022-04-04)
- (Morluktom) Chart widget updated
0.2.1 (2022-04-04)
0.2.0 (2022-03-14)
- (Morluktom) Chart widget added
0.1.1 (2022-01-07)
- (Morluktom) replaced deprecated library and login as installer only when needed
0.1.0 (2021-11-27)
- (Morluktom) Read chart data and data from the installer settings
0.0.10 (2021-05-04)
- (Morluktom) Bugfix boolean value
0.0.9 (2021-05-04)
0.0.8 (2021-02-06)
- (Morluktom) Code cleanup
0.0.7 (2021-02-01)
0.0.6 (2020-12-23)
- (Morluktom) Data type recognition fixed
0.0.5 (2020-12-15)
- (Morluktom) ScalingFactor moved to nativ
- password encryption => auto encryption (Maybe you have to set the password new)
0.0.4
- (Morluktom) W => kW, values confirmed
0.0.3
- (Morluktom) Structure of the channel and states changed
0.0.2
- (Morluktom) Separate Intervall for Common and Home
0.0.1
- (Morluktom) initial release
Copyright (c) 2025-2026 Morluktom strassertom@gmx.de
