InfluxDB ProLogger adapter for ioBroker
Flexible InfluxDB v2 data logger with configurable logging groups, multiple buckets, cron-based and on-change triggers.
Important: This adapter is a write-only data logger. It sends ioBroker state values to InfluxDB v2 — it does not read historical data back into ioBroker and does not implement the standard ioBroker history adapter interface. If you need to query stored history data within ioBroker (e.g., for charts or scripts via
getHistory), use the official ioBroker InfluxDB adapter instead.The goal of this adapter is to give you more flexibility over how data is written to InfluxDB: you can define multiple logging groups with different buckets, trigger types (cron or on-change), custom measurement names, field keys, and tags — independent of ioBroker's built-in history system.
Features
- Multiple Logging Groups - Define separate groups with different InfluxDB buckets and trigger types
- Cron-based Logging - Periodically collect and batch-write data points (e.g., every 15 minutes)
- On-Change Logging - Instantly write data to InfluxDB when a state value changes (spontaneous writes)
- Multiple Buckets - Each logging group can write to a different InfluxDB bucket
- InfluxDB v2 Line Protocol - Native HTTP API writes using InfluxDB line protocol
- Retry with Exponential Backoff - Configurable retry logic for failed writes
- Encrypted Token Storage - API token is stored encrypted in ioBroker's database
- Connection Test - Test your InfluxDB connection directly from the admin UI
- Admin UI - Fully configurable via the ioBroker admin interface (JSON Config)
Requirements
- ioBroker with js-controller >= 6.0.11
- ioBroker Admin >= 7.0.23
- Node.js >= 20
- InfluxDB v2 instance
Configuration
1. Connection Tab
Configure your InfluxDB v2 connection:
| Setting | Description |
| Protocol | HTTP or HTTPS |
| Host | InfluxDB server hostname or IP (e.g., 192.168.10.191) |
| Port | InfluxDB server port (default: 8086) |
| Organization | Your InfluxDB organization name |
| API Token | InfluxDB API token (stored encrypted) |
Use the Test Connection button to verify connectivity.
2. Logging Groups Tab
Define one or more logging groups. Each group has:
| Enabled | Enable/disable this group |
| Group Name | Unique name for this group (referenced by data points) |
| Bucket | InfluxDB bucket to write to |
| Trigger Type | Cron (periodic) or On Change |
| Cron Expression | Cron schedule (only for cron groups), e.g., */15 * * * * |
| Batch | Enable batch writing (for cron groups) |
Example groups:
| Name | Bucket | Trigger | Cron |
| Betriebsstunden | iobroker | Cron | */15 * * * * |
| Spontanwerte | iob_spontanwerte | On Change | - |
3. Data Points Tab
Configure which ioBroker states to log. Each data point must reference a logging group:
| Enabled | Enable/disable this data point |
| Group | Name of the logging group (must match a group from Tab 2) |
| Object ID | ioBroker state to read (use the object browser) |
| Measurement | InfluxDB measurement name |
| Field | InfluxDB field name |
| Tags | InfluxDB tags in key=value format (e.g., area=kitchen,floor=eg) |
Example data points:
| Group | Object ID | Measurement | Field | Tags |
| Betriebsstunden | 0_userdata.0.Heizkessel | betriebssekunden | zaehlerstand | area=heizkessel |
| Spontanwerte | shelly.1.EM0.TotalActivePower | energie | elektrische_leistung_haus | area=gesamtenergiebedarf |
4. Advanced Tab
| Write Timeout | HTTP request timeout in ms (default: 5000) |
| Retry on Error | Retry failed writes with exponential backoff |
| Max Retries | Maximum retry attempts (default: 3) |
| Debug Logging | Enable verbose debug logging |
How It Works
Cron Groups (Periodic Logging)
- At each cron interval, the adapter reads all configured state values in the group
- Values are formatted as InfluxDB line protocol
- All lines are batch-written to InfluxDB in a single HTTP POST
On-Change Groups (Spontaneous Logging)
- The adapter subscribes to each data point's ioBroker state
- When a state value changes, the new value is immediately written to InfluxDB
- Each change triggers an individual HTTP POST
InfluxDB Line Protocol
Data is written using the InfluxDB v2 line protocol format:
measurement,tag1=value1,tag2=value2 field=value
Example:
betriebssekunden,area=heizkessel zaehlerstand=12345.6
energie,area=gesamtenergiebedarf elektrische_leistung_haus=4521.3
Migration from ioBroker Scripts
If you are currently using ioBroker JavaScript scripts for InfluxDB logging, you can migrate to this adapter:
- Install the adapter
- Configure your InfluxDB connection (same host, port, org, token)
- Create logging groups matching your script setup:
- Scripts using
on({ id: ..., val: true })with a trigger state -> Create a Cron group - Scripts using
on({ id: objectId })for each state -> Create an On Change group
- Scripts using
- Add all data points from your
loggingTemplatearrays - Disable your old scripts
- Verify data is flowing in InfluxDB
Scripts in package.json
| Script name | Description |
build | Compile the TypeScript sources |
watch | Compile the TypeScript sources and watch for changes |
test:ts | Execute the tests defined in *.test.ts files |
test:package | Ensure package.json and io-package.json are valid |
test | Perform a minimal test run on package files and your tests |
check | Perform a type-check on your code (without compiling) |
lint | Run ESLint to check code for formatting errors and potential bugs |
translate | Translate texts in the adapter to all required languages |
release | Create a new release |
1.1.0 (2026-06-26)
- (ioBroker-Bot) Adapter requires admin >= 7.8.23 now.
- (Simon Prosen) Reduced excess spacing in the admin UI header by keeping configuration tab labels on a single line
- (Simon Prosen) Spontaneous (on-change) writes are now buffered with a configurable flush window (default 5000ms, adjustable per bucket)
1.0.1 (2026-04-13)
- (Simon Prosen) Fixed ack handling for on-change writes so acknowledged updates are processed correctly
- (Simon Prosen) Improved admin UI responsiveness on small screens with scrollable tabs and more flexible layouts
- (Simon Prosen) Removed the batch-write toggle from the admin UI and enforce batching based on trigger type
- (Simon Prosen) Added and improved translations for additional languages in the admin UI
- (Simon Prosen) Moved admin UI packages to
devDependenciesand consolidated the project package setup - (Simon Prosen) Updated admin logo assets and added an SVG variant
- (Simon Prosen) Refreshed build, test, TypeScript, and dependency configuration from the current template and dependency updates
1.0.0 (2026-03-21)
- (Simon Prosen) InfluxDB v2.x support via native HTTP API with token-based authentication
- (Simon Prosen) Dual-mode logging: cron-based periodic collection and on-change real-time writes
- (Simon Prosen) Multiple logging groups with independent bucket, trigger type, and cron schedule
- (Simon Prosen) Configurable data points with custom measurement names, field keys, and InfluxDB tags
- (Simon Prosen) InfluxDB line protocol formatting with proper type handling for strings, booleans, and numbers
- (Simon Prosen) Batch writing for cron groups combining all data points into a single HTTP request
- (Simon Prosen) Exponential backoff retry logic with smart classification (4xx no-retry, 429/5xx retry)
- (Simon Prosen) Configurable write timeout and retry attempts
- (Simon Prosen) Encrypted API token storage using ioBroker's native encryption
- (Simon Prosen) Connection health check on startup with
info.connectionstate indicator - (Simon Prosen) Admin UI with Connection, Logging Groups, Data Points, and Advanced tabs
- (Simon Prosen) Object browser for visual ioBroker state selection in admin UI
- (Simon Prosen) Connection test button for validating InfluxDB connectivity from admin UI
- (Simon Prosen) Cascading group rename updates across all referencing data points
- (Simon Prosen) Startup validation with warnings for missing or misconfigured groups and data points
- (Simon Prosen) Graceful shutdown with cron job cleanup and subscription removal
- (Simon Prosen) Debug logging mode for troubleshooting
- (Simon Prosen) English and German translations
0.0.1 (2026-03-20)
- (Simon Prosen) initial release
Copyright (c) 2026 Simon Prosen simon@prosen.dev
