hyperion-connector adapter for ioBroker
Connect to hyperion.ng server. Hyperion Projekt https://hyperion-project.org/forum/
Shortly after starting up, the adapter automatically searches for available Hyperion servers in the local network. If it finds one, it attempts to connect; if a login is required, it requests a token. This will cause a pop-up to appear on the Hyperion WebUI, which you must confirm. If the connection is not established after the first confirmation, please wait 1-2 minutes, and another prompt should appear.
Commands that I find useful have been incorporated.
If you require additional commands, please post in the forum or here.
- (ticaki) feat: controls/effect/* — start hyperion effects (name dropdown is auto-populated from serverinfo)
- (ticaki) feat: multi-instance support — per-instance channels under instances//, instances.json metadata, controls/instance/{setinstance,start,stop} lifecycle commands
- (ticaki) feat: convenience light role — light/{power,brightness,color} as a VIS/Alexa/Google-friendly projection over componentstate LEDDEVICE / adjustment.brightness / color
- (ticaki) feat: writable controls/videomode/mode, controls/processing/mappingType, controls/leddevice/identify
- (ticaki) chore: replaced silent catch blocks with debug logging so failures stop being invisible
- (ticaki) test: added a reusable mock hyperion server (test/mock-hyperion-server.ts) and protocol-level specs (npm run test:hyperion-mock); the existing smoke test (test/integration.js) is unchanged
- (ticaki) docs: added CLAUDE.md with project conventions, architecture map and Hyperion-API quick reference
0.2.1 (2025-11-11)
- (ticaki) first latest release
- (ticaki) Clean termination of the adapter
0.2.0 (2025-10-27)
- (ticaki) controls: adjustment added
- (ticaki) workaround for buggy subscribe in 2.1.1 (maybe adapter only work with 2.1.1)
- (ticaki) update deps
0.1.2 (2025-02-05)
- (ticaki) remove unit from admin
- (ticaki) reduced version requirements for js-controller
0.1.1 (2025-01-14)
- (ticaki) Renaming repo
- (ticaki) Adjustable reconnection interval. State to activate accelerated reconnection
- (ticaki) Incoming updates for leds are handled (most updates force a complete update of the data unless I have added code to handle - leds, components, effects so far)
- (ticaki) Added a json data point for priorities to allow better access from the javascript adapter
- (ticaki) Added leds update handling
- (ticaki) remove leds subfolders and write all data into a json datapoint (-500 folder/states for me)
- (ticaki) added controls.system
- (ticaki) add info.connection for adapter and device
- (ticaki) initial release
Copyright (c) 2025-2026 ticaki github@renopoint.de
