iobroker.goodwe-pv
Versions
Sentry
This adapter uses Sentry libraries to automatically report exceptions and code errors to the developers. For more details and for information on how to disable error reporting, see Sentry-Plugin Documentation!
goodwe-pv adapter for ioBroker
Communication with GoodWe hybrid inverters of the ET, EH, BH and BT series via the local UDP interface (port 8899). No cloud connection required — the adapter talks directly to the inverter on your LAN.
Supported devices
All GoodWe hybrid inverters that expose the local Modbus-over-UDP interface on port 8899:
- ET series (e.g. GW5-ET, GW8-ET, …)
- EH series
- BH series
- BT series
Configuration
IP address — Local IP address of the GoodWe inverter (default: 127.0.0.1). Find it in your router's DHCP lease table or in the SEMS portal / ShinePhone app under "Device Info". A static IP or DHCP reservation is recommended.
Poll cycle — How often in seconds each data group is re-read from the inverter (default: 10). The four data groups (DeviceInfo, RunningData, ExtComData, BMSInfo) are staggered so only one UDP request is in flight per second.
Tip: Find the inverter's IP address in your router's DHCP lease table, or check the GoodWe SEMS portal / ShinePhone app under "Device Info". Assigning a static IP or DHCP reservation is recommended so the address does not change.
Based on
This adapter is based on ioBroker.goodwe by FossyTom (Thomas Schönberger), licensed under MIT. Copyright (c) 2023 Thomas Schönberger SchoenbergerThomas@freenet.de
If you enjoyed this project — or just feeling generous, consider buying me a beer. Cheers! :beers:
- (hombach) switch to iobroker testing 6.x
- (hombach) added node 26 tests
- (hombach) updated dependencies
1.0.0 (2026-09-06)
- (hombach) version for stable release
0.2.4 (2026-08-07)
- (hombach) add missing descriptions to DeviceInfo and BMSInfo states
- (hombach) remove placeholder desc "-" from states without a meaningful description
- (hombach) remove unused Rtc field from GoodWeRunningData type
0.2.3 (2026-07-18)
- (hombach) replace deprecated role value.power.consumption with value.energy.consumed
- (hombach) replace value.power.produced with value.energy.produced for accumulated kWh states
- (hombach) replace invalid roles value.power.apparent and value.signal with valid alternatives
0.2.2 (2026-07-12)
- (hombach) assign semantic ioBroker roles to many states
- (hombach) fix PowerFactor scaling: signed int / 1000 instead of uint / 100
- (hombach) fix TotalReactivePower sign: use signed int (VAR can be negative)
- (hombach) fix EnergyTotalSell/Buy unit: GM3000 meter float is in Wh, divide by 1000
0.2.1 (2026-07-12)
- (hombach) add GoodWe manufacturer link to README
- (hombach) remove debug code (checkPasswordAsync/checkGroupAsync) from onReady
- (hombach) disable unused onStateChange handler (no writable states)
- (hombach) add runtime validation for pollCycle config parameter
- (hombach) expose DerateFlag as ioBroker state in RunningData
- (hombach) fix UTF-8 encoding corruption in all i18n translation files
Copyright (c) 2026 hombach goodwePV@homba.ch
