Read presets
http://192.168.178.26/fsapi/LIST_GET_NEXT/netRemote.nav.presets/-1?pin=7389&sid=883168529&maxItems=10
Nav on
http://192.168.178.26/fsapi/SET/netRemote.nav.state?pin=7389&sid=883168529&value=1
Read current mode
http://192.168.178.26/fsapi/GET/netRemote.sys.mode?pin=7389&sid=682647964
Search for updates
http://192.168.178.26/fsapi/SET/netRemote.sys.isu.control?pin=7389&value=2
On/Off?
http://192.168.178.26/fsapi/GET/netRemote.sys.power?pin=7389&sid=682647964
Switch On
http://192.168.178.26/fsapi/SET/netRemote.sys.power?pin=7389&sid=883168529&value=0
Other FSAPI documents
https://github.com/flammy/fsapi/blob/master/FSAPI.md
https://www.niehoff.nl/producthandleiding/PMR4000RMKII-03.pdf
https://downloads.biamp.com/assets/docs/default-source/control/apart-pmr4000r-mkii-mkiii-control-command-list.pdf?sfvrsn=13dc3a3e_6&_ga=2.16179958.1900116300.1624008695-122457801.1580652037
https://github.com/z1c0/FsApi/blob/master/FsApi/Command.cs
0.6.0 (2026-09-14) - 2026H2 maintenance release
- (pdbjjens) New: navigation functions (up/down/select/back/home/search) for all modes (#342)
- (pdbjjens) New: functions to set presets and to navigate presets up/down
- (pdbjjens) Fixed: i18n directory migrated to short format
- (pdbjjens) Fixed: dependency updates and minor bugfixes
0.5.1 (2026-03-07)
- (pdbjjens) Fixed: update release-script (#348)
- (pdbjjens) Fix: Add GitHub as npm Trusted Publisher
- (pdbjjens) Change: Update dependencies
0.5.0 (2025-08-28) - 2025H2 maintenance release
- (pdbjjens) Change: node>=20, js-controller>=7.0.7 and admin>=7.6.17 required
- (oelison) New: Read and write from daylight saving time
- (pdbjjens) Fix: UpdatePreset now handles empty presets correctly (#289)
- (pdbjjens) Change: Adapter and FSAPI documentation was moved to the docs folder (#281)
- (pdbjjens) Change: Cleanup devDependencies
0.4.0 (2025-02-01) - 2025H1 maintenance release
- (pdbjjens) Change: media state changed from number to string and readonly (#241)
- (pdbjjens) New: Added media control function "stop" (#241)
- (pdbjjens) New: Optimizations for responsive design (#244)
- (pdbjjens) Change: Migration to ESLint 9 (#253)
- (pdbjjens) Fix: Added button state acknowledgement
- (pdbjjens) Fix: Prevent warning on adapter stop
0.3.0 (2024-08-27) - 2024H2 maintenance release
- (pdbjjens) Change: node>=18, js-contoller>=5 and admin>=6 required
- (pdbjjens) Change: Removed .npmignore
- (pdbjjens) Change: Cyclic connection retry instead of disabling the adapter (#191)
- (pdbjjens) New: Updated dependencies
- (pdbjjens) Fix: Replace deprecated method "deleteChannel" by "delObject" (#224)
Copyright (c) 2026 iobroker-community-adapters iobroker-community-adapters@gmx.de
Copyright (c) 2025 halloamt iobroker@halloserv.de & IoBroker-Community
