Frontier Silicon
Bietet Unterstützung für Mediaplayer, die mit einem Frontier Silicon-Chipsatz mit FSAPI ausgestattet sind.
Aktueller Release
0.6.0
Entwickler
halloamt, pdbjjens, iobroker-community-adapters
Lizenz
Favoriten auslesen
http://192.168.178.26/fsapi/LIST_GET_NEXT/netRemote.nav.presets/-1?pin=7389&sid=883168529&maxItems=10
Nav ein
http://192.168.178.26/fsapi/SET/netRemote.nav.state?pin=7389&sid=883168529&value=1
Quellen auslesen
http://192.168.178.26/fsapi/LIST_GET_NEXT/netRemote.sys.caps.validModes/-1?pin=7389&sid=682647964&maxItems=100
aktuelle Quelle
http://192.168.178.26/fsapi/GET/netRemote.sys.mode?pin=7389&sid=682647964
Updates suchen
http://192.168.178.26/fsapi/SET/netRemote.sys.isu.control?pin=7389&value=2
Ein/Aus?
http://192.168.178.26/fsapi/GET/netRemote.sys.power?pin=7389&sid=682647964
Einschalten
http://192.168.178.26/fsapi/SET/netRemote.sys.power?pin=7389&sid=883168529&value=0
Andere FSAPI Dokumentation
https://github.com/flammy/fsapi/blob/master/FSAPI.md https://www.niehoff.nl/producthandleiding/PMR4000RMKII-03.pdf https://downloads.biamp.com/assets/docs/default-source/control/apart-pmr4000r-mkii-mkiii-control-command-list.pdf?sfvrsn=13dc3a3e_6&_ga=2.16179958.1900116300.1624008695-122457801.1580652037 https://github.com/z1c0/FsApi/blob/master/FsApi/Command.cs
0.6.0 (2026-09-14) - 2026H2 maintenance release
  • (pdbjjens) New: navigation functions (up/down/select/back/home/search) for all modes (#342)
  • (pdbjjens) New: functions to set presets and to navigate presets up/down
  • (pdbjjens) Fixed: i18n directory migrated to short format
  • (pdbjjens) Fixed: dependency updates and minor bugfixes
0.5.1 (2026-03-07)
  • (pdbjjens) Fixed: update release-script (#348)
  • (pdbjjens) Fix: Add GitHub as npm Trusted Publisher
  • (pdbjjens) Change: Update dependencies
0.5.0 (2025-08-28) - 2025H2 maintenance release
  • (pdbjjens) Change: node>=20, js-controller>=7.0.7 and admin>=7.6.17 required
  • (oelison) New: Read and write from daylight saving time
  • (pdbjjens) Fix: UpdatePreset now handles empty presets correctly (#289)
  • (pdbjjens) Change: Adapter and FSAPI documentation was moved to the docs folder (#281)
  • (pdbjjens) Change: Cleanup devDependencies
0.4.0 (2025-02-01) - 2025H1 maintenance release
  • (pdbjjens) Change: media state changed from number to string and readonly (#241)
  • (pdbjjens) New: Added media control function "stop" (#241)
  • (pdbjjens) New: Optimizations for responsive design (#244)
  • (pdbjjens) Change: Migration to ESLint 9 (#253)
  • (pdbjjens) Fix: Added button state acknowledgement
  • (pdbjjens) Fix: Prevent warning on adapter stop
0.3.0 (2024-08-27) - 2024H2 maintenance release
  • (pdbjjens) Change: node>=18, js-contoller>=5 and admin>=6 required
  • (pdbjjens) Change: Removed .npmignore
  • (pdbjjens) Change: Cyclic connection retry instead of disabling the adapter (#191)
  • (pdbjjens) New: Updated dependencies
  • (pdbjjens) Fix: Replace deprecated method "deleteChannel" by "delObject" (#224)
Copyright (c) 2026 iobroker-community-adapters iobroker-community-adapters@gmx.de
Copyright (c) 2025 halloamt iobroker@halloserv.de & IoBroker-Community
