Чтение предустановок http://192.168.178.26/fsapi/LIST_GET_NEXT/netRemote.nav.presets/-1?pin=7389&sid=883168529&maxItems=10
Навигация на http://192.168.178.26/fsapi/SET/netRemote.nav.state?pin=7389&sid=883168529&value=1
Режимы чтения http://192.168.178.26/fsapi/LIST_GET_NEXT/netRemote.sys.caps.validModes/-1?pin=7389&sid=682647964&maxItems=100
Чтение текущего режима http://192.168.178.26/fsapi/GET/netRemote.sys.mode?pin=7389&sid=682647964
Поиск обновлений http://192.168.178.26/fsapi/SET/netRemote.sys.isu.control?pin=7389&value=2
Вкл/Выкл? http://192.168.178.26/fsapi/GET/netRemote.sys.power?pin=7389&sid=682647964
Включить http://192.168.178.26/fsapi/SET/netRemote.sys.power?pin=7389&sid=883168529&value=0
Другие документы FSAPI https://github.com/flammy/fsapi/blob/master/FSAPI.md https://www.niehoff.nl/producthandleiding/PMR4000RMKII-03.pdf https://downloads.biamp.com/assets/docs/default-source/control/apart-pmr4000r-mkii-mkiii-control-command-list.pdf?sfvrsn=13dc3a3e_6&_ga=2.16179958.1900116300.1624008695-122457801.1580652037 https://github.com/z1c0/FsApi/blob/master/FsApi/Command.cs
0.5.0 (2025-08-28) - 2025H2 maintenance release
- (pdbjjens) Change: node>=20, js-controller>=7.0.7 and admin>=7.6.17 required
- (oelison) New: Read and write from daylight saving time
- (pdbjjens) Fix: UpdatePreset now handles empty presets correctly (#289)
- (pdbjjens) Change: Adapter and FSAPI documentation was moved to the docs folder (#281)
- (pdbjjens) Change: Cleanup devDependencies
0.4.0 (2025-02-01) - 2025H1 maintenance release
- (pdbjjens) Change: media state changed from number to string and readonly (#241)
- (pdbjjens) New: Added media control function "stop" (#241)
- (pdbjjens) New: Optimizations for responsive design (#244)
- (pdbjjens) Change: Migration to ESLint 9 (#253)
- (pdbjjens) Fix: Added button state acknowledgement
- (pdbjjens) Fix: Prevent warning on adapter stop
0.3.0 (2024-08-27) - 2024H2 maintenance release
- (pdbjjens) Change: node>=18, js-contoller>=5 and admin>=6 required
- (pdbjjens) Change: Removed .npmignore
- (pdbjjens) Change: Cyclic connection retry instead of disabling the adapter (#191)
- (pdbjjens) New: Updated dependencies
- (pdbjjens) Fix: Replace deprecated method "deleteChannel" by "delObject" (#224)
0.2.0 (2024-01-28)
- (pdbjjens) Change: Increase minor version number
0.1.2 (2024-01-26) - 2024 maintenance release
- (pdbjjens) Change: node>=16, js-contoller>=4 and admin>=5 required
- (pdbjjens) New: Optionally display PIN code and limit to 4 digits in config GUI
- (pdbjjens) Updated dependencies
Copyright (c) 2025 halloamt iobroker@halloserv.de & IoBroker-Community
