Fronius Wattpilot
A adapter to read and write states from and to the Fronius wattpilot
Current Release
4.8.0
tim2zg, SebastianHanz, derHaubi
Zur deutschen Version der Dokumentation
What is this adapter?
This adapter integrates your Fronius Wattpilot EV charger with ioBroker, allowing you to monitor and control your charging station. The Wattpilot is an intelligent electric vehicle charging solution that can be integrated into your smart home system.
🌟 Key Features:
  • Real-time monitoring of charging status
  • Remote control of charging parameters
  • Cloud and local connection support
Installation and Setup
Prerequisites
Before installing the adapter, you need to set up your Wattpilot:
  1. Complete Wattpilot Setup: Finish the initial setup using the official Fronius Wattpilot app and remember your password
  2. Connect to WiFi: In the app, go to the "Internet" tab and connect your Wattpilot to your WiFi network
  3. Find IP Address: You'll need your Wattpilot's IP address using one of these methods:
  • Router Method: Check your router's web interface for connected devices
  • App Method: In the Wattpilot app, tap on the WiFi name after connection. You'll see network details including the IP address
💡 Important: It's highly recommended to assign a static IP address to your Wattpilot in your router settings to prevent connection issues.
Adapter Installation
  1. Install the adapter from the ioBroker "Adapters" page
  2. Create a new instance of the fronius-wattpilot adapter
  3. In the instance configuration:
  • Enter your Wattpilot's IP address
  • Enter your Wattpilot password
  • Configure other settings as needed
  1. Save the configuration
If everything is configured correctly, the adapter will connect and start creating data points.
How to Use the Adapter
Reading Data
The adapter automatically creates data points for all Wattpilot values. You can use these like any other data points in ioBroker for:
  • Visualization in VIS or other frontends
  • Logic in scripts and Blockly
  • Automation rules
Data Modes:
  • Key Points Only (default): Shows only the most important values
  • All Values: Uncheck the "Key points only" option to see all available API data
📖 Full API documentation: Wattpilot API Documentation (Thanks to joscha82)
Controlling Your Wattpilot
Direct State Control (NEW!)
You can now directly control important Wattpilot functions by writing to the states.
Advanced Control via set_state
For more advanced control, use the set_state data point with this format:
stateName;value
Available states:
  • amp: 6-16 (charging current in Amperes)
  • cae: true or false (⚠️ disables cloud functionality - may require restart)
Examples:
amp;10          // Set charging current to 10A
Examples and Use Cases
Solar Integration Example
Check out our Blockly example that shows how to:
  • Monitor your solar power production
  • Automatically adjust Wattpilot charging current based on excess solar power
How to use the example:
  1. Copy the content from the example file
  2. In ioBroker Blockly, click the "Import blocks" icon (upper right corner)
  3. Paste the content and adapt it to your setup
Common Automations
  • Time-based charging: Start charging during off-peak hours
  • Solar surplus charging: Charge only when excess solar power is available
  • Presence detection: Start/stop charging based on car presence
  • Load balancing: Adjust charging current based on household power consumption
Technical Details
The adapter connects to the Wattpilot's WebSocket interface and converts incoming data into ioBroker data points. It supports both local WiFi connections and cloud-based connections.
Connection Types:
  • Local WiFi (recommended): Direct connection to your Wattpilot
  • Cloud: Connection via Fronius cloud services
Troubleshooting
Common Issues:
  • Connection failed: Check IP address and password
  • Frequent disconnections: Assign a static IP to your Wattpilot
  • Missing data points: Try enabling "All Values" mode
  • Cloud connection issues: Verify the cae setting
⚠️ Disclaimer: This adapter uses unofficial APIs. Use at your own risk and be careful when modifying settings that could affect your device's operation.
Developers
  • (Miro1310 / tim2zg) Fix authentication with wallbox (PBKDF2 by default, automatic retry with fallback method, support fullStatus/deltaStatus messages)
4.8.0 (2025-11-29)
  • Integrated working bcrypt algorithm
4.7.0 (2025-06-19)
  • Rewrite of the adapter
  • Added ability to set states directly
  • Added ability to set common states directly
  • Fix all issues
4.6.3 (2023-12-24)
  • Fixed a bug where the adapter would use a undefined variable
  • Fixed bug #44
  • Fixed bug #43
4.6.2 (2023-08-15)
  • Thanks to Norb1204 for fixing a few bugs that I missed. More in Issue #40
4.6.1 (2023-08-15)
  • Fixed Issue #39 (set_state not working)
4.6.0 (2023-07-15)
  • Fixed timeout issue in normal parser mode (#36), still exist in dynamic parser mode --> use no timeout (0)
  • Fixed a number of issues concerning the static parser mode
  • Quality of life improvements --> you can now set the common states directly! (set_power, set_mode) are still available for compatibility reasons and for the dynamic parser mode
4.5.1 (2023-03-02)
  • Fixed issue #29 (custom states not working)
4.5.0 (2023-02-19)
  • Fixed random log messages
  • Fixed a type conflict at the set_state state
  • Commits from now on should be signed
4.4.0 (2023-02-16)
  • known states will now be updated even if the dynamic parser is enabled
4.3.0 (2023-01-14)
  • dependency updates
  • state updates
4.2.1 (2023-01-05)
  • Fixed bug in the all values mode / parser
4.2.0 (2023-01-01)
  • Some QoL improvements
4.1.0 (2022-12-30)
  • Added the possibility to add states manually via the instance-settings
  • Fixed the bug where the adapter didn't set the correct value types
  • Added some quality of life improvements
4.0.0 (2022-11-30)
  • Fixed timing issue
  • Added set_power and set_mode states
3.3.1 (2022-11-17)
  • Fixed a bug where set_state was not writable
3.3.0 (2022-11-17)
  • Fixed a bug where the adapter would not set the correct labels for the states
  • Performance improvements
  • Fixed dependencies
3.2.5 (2022-10-14)
  • Small changes to the package.json and io-package.json
3.2.4 (2022-10-11)
  • Fiexed cool down timer for normal values
3.2.3 (2022-10-08)
  • Bug fixed where the adapter would not respect the timout timer and would try to constantly reconnect to the WattPilot
  • Bug fixed where the adapter would send a wrong disconnect message to the WattPilot
3.2.2 (2022-10-06)
  • Fixed reconnecting frequency
  • Fixed multiple Websocket connections
  • Added frequency handler
3.2.1 (2022-10-02)
  • Fixed reconnecting to the WebSocket
  • Restructured the code
3.2.0 (2022-09-29)
  • Implemented reconnecting
  • Shrank code down
3.1.0 (2022-09-07)
  • Added the option to use the cloud as a datasource
  • Updated GitHub workflows
3.0.0 (2022-09-04)
  • Updated README.md
  • Created "examples"-directory for sample applications
  • Added some translations
  • Renamed checkbox "Parser" to something more intuitive
  • Fixxed #4: Datapoint "map" now gets created correctly
  • Fixxed #5: Password-characters are no longer visible
  • Fixxed type conflict of cableType
2.2.4 (2022-09-01)
  • SebastianHanz fixed infinite RAM-usage
  • added some description
2.2.3 (2022-08-30)
  • SebastianHanz fixed type-conflicts. Thank you!
2.2.2 (2022-08-25)
  • Bug fixes
2.2.1 (2022-08-22)
  • Bug fixes
2.2.0 (2022-08-21)
  • Fixed Bugs
2.1.0 (2022-08-19)
  • Min Node Version 16
2.0.3 (2022-07-20)
  • Updated Readme
2.0.2 (2022-07-12)
  • Bug fixed
2.0.1 (2022-07-10)
  • Added a how to install. Not to detail because currently not in stable repo.
2.0.0 (2022-07-10)
  • Fixed NPM Versions hopefully
1.1.0 (2022-07-10)
  • Added UselessPV and TimeStamp Parser, did some testing.
1.0.1 (2022-06-02)
  • Tests
1.0.0 (2022-06-02)
  • Did some changes
  • Did some more changes
0.0.5 (2020-01-01)
  • Better Code
0.0.4 (2020-01-01)
  • Parser option added
0.0.3 (2020-01-01)
  • Parser added
0.0.2 (2020-01-01)
  • Bug fixed
0.0.1 (2020-01-01)
  • Initial release
Copyright (c) 2025-2026 tim2zg tim2zg@protonmail.com
