Control Dune HD media players via IP network from ioBroker.
Dune HD produces high-quality network media players supporting 4K HDR playback, Blu-ray, and a wide range of media formats. All Linux-based Dune HD players support IP control via HTTP API, which this adapter uses to provide full remote control from ioBroker.
Features
- Full playback control (play, pause, stop, seek, prev/next, fast-forward/rewind)
- Navigation (D-pad, enter, return, menus)
- Volume and mute control
- Status polling (player state, position, duration, volume, bitrate, audio language, video resolution)
- Built-in PWA web remote — use your phone as a remote control
- Smart offline polling — reduces poll frequency when player is unreachable
- PWA text input — send text directly to the player's on-screen keyboard
- PWA Play URL — start media playback from any URL directly from the remote
Supported Models
All Dune HD media players with IP control support (Linux-based firmware).
Tested on: Dune HD Pro 4K (firmware with XML response format).
| Model type | Default port |
| Linux-based (Pro 4K, Solo 4K, etc.) | 80 |
| Android/ATV-based | 11080 |
Configuration
Player
| Field | Description |
| Player Name | Display name (for reference only) |
| Player IP Address | IP address of the Dune HD player |
| Player Port | HTTP port (default: 80) |
| Connection Timeout | Request timeout in ms (default: 5000) |
Status Polling
| Enable Status Polling | Enable periodic status updates |
| Polling Interval | Interval in seconds when player is online (default: 5) |
| Offline Polling Interval | Interval in seconds when player is unreachable (default: 30) |
PWA Remote Control
Enable the built-in web remote to control the player from any browser or mobile device.
| Enable PWA Remote Control | Start the built-in web server |
| Bind IP Address | Network interface to bind to (0.0.0.0 = all interfaces) |
| PWA Server Port | Port for the web remote (default: 8765) |
After enabling, open http://<iobroker-host>:8765/ in your browser.
The URL is also stored in the info.pwaUrl state.
PWA features:
- Main tab: D-pad, playback controls, volume, seek
- Main tab: text input field — sends text to the active player keyboard (
set_textAPI) - Main tab: Play URL field — starts media playback from any URL (
launch_media_urlAPI) - Digits tab: number keys, color buttons (A/B/C/D), subtitle, zoom, eject, REC
- Settings tab: dark/light theme, connection settings
- Works as installable PWA on iOS and Android (Add to Home Screen)
Dune Notify Plugin
Show notifications from ioBroker on top of the video during playback.
Requires the dune-notify PHP plugin installed on the player (see dune-notify/ folder).
| Enable Notifications | Enable the dune-notify integration |
| Notify Request Timeout | HTTP request timeout in ms (default: 3000) |
States
| State | Type | Description |
info.connection | boolean | Player reachable |
info.pwaUrl | string | PWA remote URL |
info.playerModel | string | Player model name |
info.firmwareVersion | string | Firmware version |
status.playerStatus | string | playing / stopped / paused |
status.position | number | Playback position (seconds) |
status.duration | number | Total duration (seconds) |
status.volume | number | Volume level |
status.mute | boolean | Mute state |
status.caption | string | Current media title |
status.audioLang | string | Audio language |
status.videoWidth/Height | number | Video resolution |
status.bitrate | number | Current bitrate (bit/s) |
control.play/pause/stop | boolean | Trigger playback actions |
control.volume | number | Set volume |
navigation.up/down/left/right/ok/back | boolean | Navigation buttons |
media.playUrl | string | Play media from URL |
media.seek | number | Seek to position (seconds) |
notify.send | string | Send notification (text or JSON) |
notify.hide | boolean | Hide current notification |
notify.lastResult | string | Result of last notification request |
1.2.5
- Migrate i18n to short format ({lang}.json)
- Update adapter-core range to ^3.4.3 in package.json
1.2.4
- Update @iobroker/adapter-core to 3.4.3
1.2.3
- Fix W0066: downgrade @types/node to >=22 <23
- Add extends clause to tsconfig.json (@tsconfig/node22)
- Add 1.2.2 changelog entry to README
1.2.2
- Fix W5612: add missing i18n keys for notify section (all 11 languages)
- Add prettier.config.mjs, tsconfig.json, @types/node, @tsconfig/node22
- Update devDependencies (eslint-config 2.3.4, release-script 5.2.1)
- Fix jsdoc types in lib files
1.2.1
- Fix E8915: add dependabot cooldown (7 days) to reduce supply chain risk
- Fix deploy step: use Node.js 24 for trusted publishing compatibility
- Remove redundant
eslintandprettierdevDependencies (included via@iobroker/eslint-config) - Add manufacturer link and device description to README
- Add CHANGELOG_OLD.md for older changelog entries
1.2.0
- Add dune-notify plugin integration: show notifications on screen during playback
- New states:
notify.send,notify.hide,notify.lastResult - New config options:
notifyEnabled,notifyTimeout
1.1.5
- Fixed README: added missing changelog entry for 1.1.4
1.1.4
- Fixed README changelog (E6006), added
needs: check-and-lintto adapter-tests job (S3014)
1.1.3
- Use standard workflow and testing scripts as provided by create-adapter
- Added
needs: check-and-lintto adapter-tests job - Restructured test directory to match ioBroker.example template
1.1.2
- Use
node:prefix for all built-in Node.js modules (fs, http, path, url)
1.1.1
- Fixed prettier formatting errors in lib files
- Added
test:integrationscript for CI/CD compatibility
For older changelog entries see CHANGELOG_OLD.md.
MIT © 2026 sadam6752-tech
Copyright (c) 2026 sadam6752-tech sadam6752@gmail.com
