CODESYS Network Variable List
Send and receive Network Variable Lists (NVL) from CODESYS driven PLC
Current Release
0.0.6
Bannsaenger
codesys-nvl adapter for ioBroker
Send and receive Network Variable Lists (NVL) from CODESYS® driven PLC
References
CODESYS® is a registered trademark of CODESYS GmbH, A member of the CODESYS Group
The logo is taken from the CODESYS Homepage
EN 61131 is a european standard based on the international standard IEC 61131-3 comp. Wikipedia
Data helper is taken from jisotalo/iec-61131-3
Telegram handling (parsing and building) as well as dealing with the variable structure is taken from Hopperpop and his project node-red-contrib-nvl
Purpose
Simple adapter to send and receive data to and from CODESYS® driven PLC via NVL lists. These lists can be edited and exported in the CODESYS editor.
Documentation
Getting started
First we have to create a NVL in the CODESYS editor. For now only uncompressed lists will be supported. If the list exeeds 256 bytes the data is transmitted in more tham one telegram. This is not supported for now.
Creating a GVL file
First export the NVL list in the editor and save it as a GVL file. e.g. myfirstlist.gvl It looks like:
<GVL>
  <Declarations><![CDATA[{attribute 'qualified_only'}
VAR_GLOBAL
	Watchdog: BOOL;
	Input1: BOOL;
	Input2: BOOL;
END_VAR]]></Declarations>
  <NetvarSettings Protocol="UDP">
    <ListIdentifier>1</ListIdentifier>
    <Pack>True</Pack>
    <Checksum>False</Checksum>
    <Acknowledge>False</Acknowledge>
    <CyclicTransmission>True</CyclicTransmission>
    <TransmissionOnChange>True</TransmissionOnChange>
    <TransmissionOnEvent>False</TransmissionOnEvent>
    <Interval>T#10s</Interval>
    <MinGap>T#20ms</MinGap>
    <EventVariable>
    </EventVariable>
  </NetvarSettings>
</GVL>
Place the file in ioBroker and configure it
Next the file must be dropped in the Files tab unter codesys-nvl.0 or whatever your instance number is. After a adapter restart the file appears in the admin interface in the tab Network Variable Lists.
Here you can configure the Type of the list to Send, Receive or Disable.
Usage
On start, the adapter creates a database for each list. The path to the list is e.g.:
codesys-nvl.0.nvl.1
Under config you find the imported GVL content. The info channel gives information about the connection state and the data actuality.
Under var you find the variable names as channel and in the channel the type and the value.
In a send list you can set the values in the database to transmit the data to the PLC. On the other sind you see the received values from a receive list.
ToDo
  • Fix the support for long NVLs
  • Add support for compressed NVLs
0.0.6 (2026-08-31)
  • (Bannsaenger) fixed last errors from code review
0.0.5 (2026-08-25)
  • (ioBroker-Bot) Adapter requires admin >= 7.8.23 now.
  • (Bannsaenger) fixed errors from code review for check in to latest repository
0.0.4 (2026-07-08)
0.0.3 (2026-06-16)
  • (Bannsaenger) fixed errors for check in to repository
0.0.2 (2026-05-15)
  • (Bannsaenger) add initial documentation
Copyright (c) 2024 - 2026 Bannsaenger bannsaenger@gmx.de
