Cisco 9800 CheckPresence
The adapter checks the presence of family members over the Cisco Catalyst 9800 Wireless Controller
Current Release
0.1.1
M1kad0
Cisco Catalyst 9800 CheckPresence adapter for ioBroker
Detects the presence of family members by querying the Cisco Catalyst 9800 Wireless Controller via RESTCONF. Instead of unreliable ping checks, the adapter reads the authenticated client table directly from the WLC — if the controller says a device is associated, it is there.
Requirements
  • Cisco Catalyst 9800 Series Wireless Controller (9800-L, 9800-CL, 9800-40, 9800-80)
  • 802.1X authentication is required. The adapter identifies clients by their 802.1X username. No external RADIUS server is needed — Local EAP on the WLC is sufficient.
  • A WLC user account with RESTCONF read access
  • ioBroker with js-controller ≥ 6.0.11 and Admin ≥ 7.0.23
Configuration
Open the adapter settings in ioBroker Admin.
Connection tab
FieldDescription
WLC Host / IP AddressIP address or hostname of the Catalyst 9800 WLC
UsernameRESTCONF username (e.g. iobroker_bot)
PasswordRESTCONF password (stored encrypted)
Interval (s)Poll interval in seconds (10–300, default: 30)
Ignore self-signed certificateEnable if your WLC uses a self-signed TLS certificate (recommended)
Users tab
Map 802.1X usernames to state names in ioBroker:
FieldDescription
802.1X UsernameThe username as seen in the WLC client table
State NameName used for the state under presence.<name>
States
For each configured user the adapter creates the following states:
StateTypeDescription
presence.<name>.presentbooleantrue if the client is currently associated
presence.<name>.apstringName of the associated Access Point (e.g. AP03n)
presence.<name>.bandstringRadio band (2.4 GHz, 5 GHz, or 6 GHz)
presence.<name>.rssinumber (dBm)Received signal strength
presence.<name>.snrnumber (dB)Signal-to-noise ratio
info.connectionbooleantrue if the WLC is reachable
Integration with ioBroker Residents
The presence states can be linked to the ioBroker Residents adapter via the Foreign Presence Data Points field:
cisco-checkpresence.0.presence.leonie.present
Known Limitations
  • Multiple devices per user: If multiple devices are authenticated with the same 802.1X username, the first client returned by the WLC API is used. This is a use-case limitation, not a bug.
  • 802.1X required: Devices without 802.1X authentication (e.g. IoT devices using PSK) are not detected. Local EAP on the WLC is sufficient if no external RADIUS server is available.
  • Central switching only: Tested with APs in Local Mode with central switching (CAPWAP). Flex/local switching may behave differently.
0.1.1 (2026-09-12)
  • Fixed: Reuse a keep-alive HTTPS connection for RESTCONF requests instead of opening a new TLS connection (and WLC auth session) on every poll, which could accumulate DMI sessions and crash the WLC at short poll intervals
0.1.0 (2026-08-03)
  • (ioBroker-Bot) Adapter requires admin >= 7.8.23 now.
  • Changed: admin UI migrated from the deprecated @iobroker/adapter-react-v5 to @iobroker/gui-components
0.0.7 (2026-06-11)
  • Fixed: Sanitise user-supplied state names to remove characters forbidden in ioBroker object IDs
  • Fixed: Clamp pollInterval and absentThreshold to sane upper bounds
  • Fixed: Avoid overlapping polls by self-scheduling the poll loop instead of using setInterval
  • Fixed: Use translations for the admin tab labels and poll interval field
  • Fixed: Corrected admin page title
0.0.6 (2026-06-06)
  • Fixed: Fixed object structure
0.0.5 (2026-06-06)
0.0.4 (2026-06-06)
  • Chore: Update to node 22
  • Chore: Update dependencies
0.0.3 (2026-04-27)
  • (M1kad0) fix npm publishing
0.0.2 (2026-04-26)
  • (M1kad0) added absent threshold to debounce presence detection
0.0.1 (2026-04-26)
  • Initial release
  • Presence detection via RESTCONF (common-oper-data)
  • AP name, radio band, RSSI and SNR via traffic-stats
  • Encrypted password storage
  • Dark/light mode admin UI with MUI v6
Copyright (c) 2026 M1kad0 leonie+iobroker@sgessinger.de
