apg-info adapter for ioBroker
This adapter provides the peak-times for the Austrian Power Grid (Austrian values only!), where power consumption shall be avoided. In addition the adapter provides the PHELIX Day-Ahead (EPEX Spot) prices for Austria, Swiss and Germany (configure in Adapter settngs). Provider fee, tax, grid costs can be added optionally in the config (tab Calculation).
With the standard-configuration the adapter runs at 00:00, 13:00 and 15.00 o'clock. It's highly recommended not to remove the run at 00:00, otherwise the day-change (tomorrow --> today) will nit work propperly.
This adapter uses Sentry libraries to automatically report exceptions and code errors to the developers. For more details and for information how to disable the error reporting see Sentry-Plugin Documentation!
Requires
- Node.js 22 or higher
- ioBroker host (js-controller) 6.0.11 or higher
Quarter-hourly market prices
These market prices are collected by Exaa and as backup by Entsoe and Energy Charts. Therefore it is recommended to request an Entsoe token if quarter-hourly prices are configured.
Swiss market
For the swiss market a token from entsoe.eu is needed.
How to get an Entsoe token
Register at the page https://transparency.entsoe.eu/ and send afterwards and email to transparency@entsoe.eu asking for RESTFUL API access for the email address you registered.
For more details check https://transparency.entsoe.eu/content/static_content/Static%20content/web%20api/Guide.html#_authentication_and_authorisation
Time based grid cost calculation
In markets (like Austria) characterized by time-variable grid costs (e.g., reduced rates during midday hours in summer), parameters are now configurable via a table. A reference table illustrates the required data entry format. The feature is in the adapter configuration in the tab "calculation".
Important: Table view works with Admin 7.7.23 or later. In older versions the date field is not shown propperly (https://github.com/ioBroker/ioBroker.admin/issues/3344).
Charts
Its easy to create charts with the data provided by this adapter. Depending on your used visualization adapter, you have multiple options. A few common samples are listed bellow:
Vis-1
[..].marketprice.today.jsonChart and [..].marketprice.tomorrow.jsonChart can be used with https://github.com/Scrounger/ioBroker.vis-materialdesign#json-chart.
Unfortuneately vis-materialdesign is not supported by the vis-2 adapter (See: https://github.com/Scrounger/ioBroker.vis-materialdesign/issues/227, https://github.com/Scrounger/ioBroker.vis-materialdesign/pull/224).
And the new vis-2-widgets-material adapter does no longer have a "jsonChart".
Vis-2
As an alternative you can use the echarts adapter with "JSON" as data source (https://github.com/ioBroker/ioBroker.echarts#data-from-json). For this, apg-info adapter also provides the full data in other objects:
[..].marketprice.today.jsonChartDataand[..].marketprice.tomorrow.jsonChartDatacontain only the chart data array[..].marketprice.jsonChartDatacombines today's and tomorrow's chart data in one array.[..].marketprice_quarter_hourly.jsonChartDataprovides the same combined chart data for quarter-hourly prices.- The corresponding
jsonChartDataRawstates contain raw market prices before fees, charges, grid costs, and VAT are added.
With this you can create nice charts like this one (created with echarts adapter and the combined chart quarter hourly data):
0.1.36-alpha.0 (2026-09-15)
- (ioBroker-Bot) Adapter requires admin >= 7.8.23 now
- (SimonFischer04) add raw chart data states
- (HGlab01) Bump axios to 1.20.0
0.1.35 (2026-06-15)
- (HGlab01) improve provider sequence for forecast capability
0.1.34 (2026-06-13)
- (HGlab01) change provider sequence (Exaa as last)
- (HGlab01) fix EnergyCharts empty data recognition
- (HGlab01) Bump axios to 1.17.0
0.1.33 (2026-05-26)
- (HGlab01) Bump axios to 1.16.1
- (SimonFischer04) support echarts (vis-2)
- (HGlab01) fix E5050 process.exit() used
0.1.32 (2026-05-02)
- (HGlab01) Adapter requires node.js >= 22 now
- (HGlab01) fix 'DE' is not the code for an available bidding zone
- (HGlab01) Bump axios to 1.15.2
Older Changelog
can be find here
Copyright (c) 2023-2026 HGlab01 myiobrokeradapters@gmail.com
Disclaimer apg-powermonitor
More about the security of supply & all data, facts and figures regarding the world of electricity and the energy transition can be found at www.apg-powermonitor.at.
Disclaimer data providers
Four data providers are used for this adapter
- Exaa (https://www.exaa.at/)
- Entso-e (https://www.entsoe.eu/data/transparency-platform/)
- Energy Charts (https://api.energy-charts.info/) licensed under the CC BY 4.0 license
- aWATTar (https://www.awattar.at/services/api and https://www.awattar.de/services/api)
