Adapter for Wi-Fi and Ethernet settings on Raspberry Pi / Linux
This fork can configure network interfaces managed by NetworkManager.
Supported functions
- Connect and disconnect Wi-Fi networks
- Show current interface information (IPv4/IPv6, gateway, DNS)
- Change Ethernet IPv4 settings
- Change IPv4 settings of active Wi-Fi profiles
- Switch between DHCP and static IPv4 configuration
- Configure subnet mask/prefix, gateway and DNS servers
Tested logic is based on nmcli / NetworkManager.
Required permissions
This adapter assumes that the iobroker user may execute the following command:
/usr/bin/nmcli
You can add the rights by calling:
sudo chmod +x /opt/iobroker/node_modules/iobroker.wireless-settings/wlan_rights.sh
sudo /opt/iobroker/node_modules/iobroker.wireless-settings/wlan_rights.sh
Notes
- Applying new network settings can briefly interrupt the current Admin connection.
- When the device IP changes, reopen ioBroker Admin with the new address.
- For Ethernet interfaces without an existing profile, the adapter creates a dedicated NetworkManager profile automatically.
- (ioBroker-Bot) Adapter requires js-controller >= 6.0.11 now.
1.2.2 (2026-04-19)
- Detect docker
1.2.1 (2026-04-19)
- Added editable Ethernet and IPv4 settings in the Admin UI
- Added DHCP/static IPv4 switching with subnet, gateway and DNS handling
- Improved command execution by using argument-based process calls instead of raw shell strings
- Migrated GUI to vite
1.0.2 (2024-10-04)
- (@GermanBluefox) Updated for raspberry 5
- (@GermanBluefox) Change name to "wireless-settings"
0.4.0 (2024-10-03)
- (@GermanBluefox) Change name to "network-settings"
0.3.0 (2023-06-27)
0.2.2 (2023-06-27)
- (@GermanBluefox) Updated the GUI to the latest version
0.1.0 (2021-01-18)
- (ioBroker) fixed build scripts
0.0.1 (2021-01-18)
- (ioBroker) initial release
Copyright (c) 2021-2026 @GermanBluefox dogafox@gmail.com
