VIS-2 weather and heating widgets
Current Release
1.5.0
rg-engineering
ioBroker.vis-2-widgets-weather-and-heating
If you like it, please consider a donation:
paypal
weather
This vis-2-widget shows weather forecast data from DasWetter.com or weatherunderground. You need DasWetter-Adapter or weatherunderground-Adapter running on your system.
weather
  • OID's are automatically set based on general settings
  • x axis labels can be configured according momentjs docu
weather day
  • icon sets are changeable
Meteored weather widget
see METEORED for more information.
You must create your widget on METEORED and get the ID for the widget. This ID must be set in the widget settings here. Do not forget to whitelist your domain in METEORED settings. In my case I had to whitelist https://192.168.xxx.xxx:8082 to get the widget running.
general chart
input data for general chart
  • "OID data serie" should point to data point like sbfspot.0.xxxxxxxx.history.years
  • data point should contain key / value pairs like
[{"year":"2008","value":7000},{"year":"2009","value":2309000},{"year":"2010","value":4445000},{"year":"2011","value":7019000},{"year":"2012","value":9371000},{"year":"2013","value":11393000},{"year":"2014","value":13666000},{"year":"2015","value":16034000},{"year":"2016","value":17826790}]
  • it's possible to auto calculate and show differences of values. Just tick "difference calculation" in settings.
  • it supports adapter sbfspot and ebus: just select instance, and basic adjustments are done automatically
heating (widgets for HeatingControl adapter)
Based on Pittini's project for old VIS there are similar widgets available for VIS-2 now.
Room Overview
Heating Time Schedule
General Parameter
Room
Room Profile Paeameter
Window Status Overview
1.5.0 (2026-09-13)
  • (René) new widget "inform landloard" added, to send messages to landlord
  • (René) dependencies updated
1.4.3 (2026-07-05)
1.4.2 (2026-06-05)
  • (René) see #264: decimal places for temperature values can now be configured in weather day widget
  • (René) decimal places for Y axis can now be configured in SourceAnalytics bar graph widget
  • (René) #263: bug fix to switch color for datepicker in dark mode
1.4.0 (2026-05-26)
  • (René) see #174: unused empty space in weather widget removed
1.3.0 (2026-01-03)
  • (René) update echarts@6.0.
  • (H5N1v2) 41 icons for DasWetter@4.x (galeria7)
  • (René) optimisations based on mui@7.x in WeatherDay-widget
  • (René) weather widget shows now min and max temperature (if values available)
The MIT License (MIT)
Copyright (c) 2024-2026 rg-engineering info@rg-engineering.eu
