Unifi Network
Communication with the Unifi Network application using the websocket interface to receive information in real-time
Current Release
1.5.0
Scrounger
unifi-network adapter for ioBroker
Unifi Network uses the websocket interface to receive real-time information from the unifi-network application
Important
  1. The adapter is developed exclusively on the basis of the UniFi OS. Compatibility with a self-hosted network controller should be given, but cannot be guaranteed.
  2. This adapter can be very resource intensive!
    This depends on your environment, i.e. how many unifi-devices and clients are in your network. This can be influenced somewhat via the realtime api debounce time [s] parameter in the adapter settings. Real-time events are not affected by this setting, only the "cyclical" real time update of devices, clients, etc.
  3. Not all states are directly available after the adapter has started
    States are only created and updated when the data is sent by the network controller, this can take some time until the data is sent for the first time
Configuration
Local user (UniFi OS)
You will need a local user created in your UniFi OS Console to log in with. Ubiquiti SSO Cloud Users will not work. It is recommended you use the Administrator or a user with full read/write access to get the most out of the integration, but it is not required.
  1. Login to your Local Portal on your UniFi OS device, and click on Users.
    Note: This must be done from the UniFi OS by accessing it directly by IP address (e.g. 192.168.1.1), not via unifi.ui.com or within the UniFi Network app.
  2. Go to Admins & Users from the left hand side menu and select the Admins tab or go to [IP address]/admins/ (e.g. 192.168.1.1/admins/).
  3. Click on + in the top right corner and select Add Admin.
  4. Select Restrict to local access only and enter a new username and password.
  5. Select Hotspot Operator and Site Admin for the Network role.
    Note This is not absolutely necessary, if the permissions are not sufficient, you will be informed via log message
image info
  • (Scrounger) channel / device name undefined bug fix #116
  • (Scrounger) vpn client handling optimized
  • (Scrounger) event messages improved #122 #115
1.5.0 (2026-06-23)
  • (Scrounger) vpn event handler for network >= 10.3.x added #89
  • (Scrounger) event messages improved #109, #91
  • (Scrounger) typescript 6.x bug fixes
  • (Scrounger) dependencies updated
  • (ioBrokerTranslator) spanish language added #98
  • (Scrounger) bug fix for expired token since v10.4.57 #108
1.4.0 (2026-04-08)
  • (Scrounger) bug fix for speed test event spamming since v.10.2.105
  • (Scrounger) event messages improved #68 #54
  • (Scrounger) support for Unifi OS on custom port added (e.g. UniFi OS Server) #65
  • (Scrounger) bug fix: vpn is wrongly shown as lan
  • (Scrounger) system informations added #63
  • (Scrounger) port states up, rx/tx error and rx/tx dropped added
  • (Scrounger) event messages improved #64
  • (Scrounger) read controller version added #59
  • (Scrounger) option to set debug level for client connection events added #61
  • (Scrounger) property version for devices added
  • (Scrounger) satisfaction object create condition removed to prevent create and deletion of object
  • (Scrounger) event messages for dream machines compatibility < v10.x added #72
  • (Scrounger) weblate translation added
  • (Scrounger) downgrade @iobroker/adapter-core to v3.3.1 to prevent conflicts with js-controller < v7.1.0 in rare cases #56
1.3.1 (2025-12-01)
  • (Scrounger) null bug fix #48
  • (Scrounger) event messages improved #46
  • (Scrounger) bug fixes
1.3.0 (2025-11-24)
  • (Scrounger) option to change tx power mode of access point channels
  • (Scrounger) code optimized
  • (Scrounger) logging optimized
1.2.2 (2025-11-14)
  • (Scrounger) delete device event added
  • (Scrounger) event messages improved #43
Copyright (c) 2025-2026 Scrounger scrounger@gmx.net
