swiss-weather-api adapter for ioBroker
Connects to the great SRF weather API - Version 2 (https://developer.srgssr.ch/api-catalog/srf-weather/srf-weather-description). The SRF Weather REST API allows you to get weather forecasts and reports from more than 25.000 locations across Switzerland. A "Freemium" subscription allows you to get 50 Request/day.
Please Be aware:
- This adapter only supports locations within Switzerland.
- This adapter supports SRF Weather API V2.
Update procedure Version 1.x.x to 2.0.x
- Remove the adapter (delete all Adapter-Objects in ioBroker!)
- Install Adapter completly new => New Objects will be generated
- Since SRF has changed the Path-Names, update your Visu: Just reimport the views.
Getting started
- Get a free accout on https://developer.srgssr.ch/
- Go to "Apps" and add new App. Here you can choose a API-Product. "SRF-MeteoProductFreemium" is their free product. If you only want a forecast for one location and get only 50 request per day (every 30min) or/and don't want to pay for more request per day, "SRF-MeteoProductFreemium" is what you want to choose. Now, this will create a specific ConsumerKey and ConsumerSecret
- Find out Longitude / Latitude (decimal degrees) of the chosen location for which forecast is needed. This information is optional if you have set your location in the ioBroker settings (main settings) (via the map). In this case you could leave the latitude and longitude fields empty. The adapter then ueses the settings of the ioBroker. Latitude and longitude entered in the adapter configuration override the ioBroker settings.
- Freemium-Users: Please note that the SRG API remembers the location used. From the first request on and for a certain period of time, the subscription used can only deliver requests for this one location.
- Install this Adapter on ioBroker => This can take several minutes (~7min on a Raspberry Pi 3)
- On Adapter Configuration fill in
- Name of App
- ConsumerKey of App
- ConsumerSecret of App
- Longitude / Latitude of the chosen swiss location for which forecast is needed. => Please use decimal degrees (for example Zürich: 47.36667 / 8.5)
- Poll Interval in Minutes (By default 60 minutes - 25 Request/Day)
The first query is made 10s after the adapter was started. After the first start, the query will be executed regularly according to the conifugation parameter (Poll Interval in Minutes). The Objects in forecast.current_hour will be createt 30s after frist startup and updated every hour by copying the corresponding values from forecast.hours.
Visualisation Example
Prerequisite:
- Adapter Material Design Widgets >= 0.5.7
- Adapter Vis
- Import Views to Vis
Example
Simple Example:
Extended Example:
Week-View Example:
2.2.2 (2024-11-01)
- (baerengraben) Fix for https://github.com/baerengraben/ioBroker.swiss-weather-api/issues/125
2.2.1 (2024-11-01)
- (baerengraben) Fix for https://github.com/baerengraben/ioBroker.swiss-weather-api/issues/78
2.2.0 (2024-10-30)
- (baerengraben) Wochensicht_reduziert neu als View und mit Legende
2.1.1 (2024-10-29)
- (baerengraben) Fix for https://github.com/baerengraben/ioBroker.swiss-weather-api/issues/124
- (baerengraben) Fix for https://github.com/baerengraben/ioBroker.swiss-weather-api/issues/123
- (baerengraben) Fix for https://github.com/baerengraben/ioBroker.swiss-weather-api/issues/122
- (baerengraben) Fix for https://github.com/baerengraben/ioBroker.swiss-weather-api/issues/121
2.1.0 (2024-01-10)
- (baerengraben) Added additional Week-View. Credits goes to https://github.com/pingus01
Copyright (c) 2024 baerengraben baerengraben@intelli.ch
