ioBroker adapter for the Solakon ONE hybrid solar inverter
Monitors and controls the Solakon ONE hybrid solar inverter (www.solakon.de) with battery storage over the local network via Modbus TCP (Port 502).
Deutsch / German documentation
Requirements
- ioBroker with js-controller >= 6.0.0
- Node.js >= 22
- Solakon ONE inverter reachable in the local network
- Modbus TCP enabled on the device (Port 502)
Installation
Install via the ioBroker Admin interface: Adapters → search for "solakon-one" → Install.
Configuration
| Field | Description | Default |
| IP Address | IP of the Solakon ONE on the LAN | 192.168.1.100 |
| Port | Modbus TCP port | 502 |
| Modbus Device ID | Slave address (1–247) | 1 |
| Interval (s) | Poll interval (1–300 s) | 30 |
Data Points
All data points are created under solakon-one.<instance>.* (e.g. solakon-one.0.* for the default instance number 0; multiple instances are possible).
Connection Status
| ID | Description | Type |
info.connection | Connection active | Boolean |
Device Information (device.*)
| ID | Description |
device.model | Model name |
device.serial | Serial number |
device.fw_master | Firmware version (Master) |
device.fw_slave | Firmware version (Slave) |
Photovoltaics (pv.*)
| ID | Description | Unit |
pv.total_power | Total PV power | W |
pv.total_energy | Total PV energy | kWh |
pv.pv1_voltage … pv4_voltage | String voltage | V |
pv.pv1_current … pv4_current | String current | A |
pv.pv1_power … pv4_power | String power | W |
Battery (battery.*)
battery.soc | State of Charge (SoC) | % |
battery.voltage | Voltage | V |
battery.current | Current | A |
battery.power | Power (+ charge, − discharge) | W |
battery.combined_power | Combined power | W |
battery.total_charge | Total charge energy | kWh |
battery.total_discharge | Total discharge energy | kWh |
battery.bms1_soh | State of Health (SoH) | % |
battery.design_energy | Nominal capacity | Wh |
battery.ambient_temp | Ambient temperature | °C |
battery.max_temp | Maximum temperature | °C |
battery.min_temp | Minimum temperature | °C |
Grid (grid.*)
grid.off_grid | Island mode active | Boolean |
grid.r_voltage | Grid voltage phase R | V |
grid.s_voltage | Grid voltage phase S | V |
grid.t_voltage | Grid voltage phase T | V |
grid.frequency | Grid frequency | Hz |
grid.active_power | Active power (+ export, − import) | W |
grid.reactive_power | Reactive power | kvar |
grid.power_factor | Power factor | – |
grid.total_export | Total feed-in energy | kWh |
grid.total_import | Total purchased energy | kWh |
grid.standard | Grid standard (6=VDE0126, 7=VDE4105_DE) | – |
Inverter (inverter.*)
inverter.temperature | Internal temperature | °C |
inverter.frequency | Output frequency | Hz |
inverter.daily_energy | Daily yield | kWh |
inverter.total_energy | Total yield | kWh |
inverter.operating_mode | Operating mode | – |
inverter.network_status | Network status | – |
Emergency Power / EPS (eps.*)
eps.voltage | EPS output voltage | V |
eps.current | EPS output current | A |
eps.power | EPS output power | W |
Status (status.*)
| ID | Description |
status.remote_control | Active remote control mode |
status.remote_countdown | Remaining time remote control (s) |
Control (control.*) — writable
| ID | Description | Range |
control.remote_control_mode | Remote control mode | 0/1/3/5/7/9/11/13/15 |
control.remote_timeout | Remote control timeout (s) | 0–3600 |
control.remote_active_power | Active power setpoint (W) | -100000–100000 |
control.remote_reactive_power | Reactive power setpoint (var) | -100000–100000 |
control.eps_output | EPS/UPS output | 0=Off, 2=EPS, 3=UPS |
control.minimum_soc | Min. state of charge | 0–100 % |
control.maximum_soc | Max. state of charge | 0–100 % |
control.minimum_soc_ongrid | Min. SoC (grid-connected) | 0–100 % |
control.max_charge_current | Max. charge current | 0–40 A |
control.max_discharge_current | Max. discharge current | 0–40 A |
control.operating_mode | Operating mode | 0–7 |
Operating modes (operating_mode)
| Value | Description |
| 0 | Unspecified |
| 1 | Self-consumption |
| 2 | Feed-in priority |
| 3 | Backup |
| 4 | Peak shaving |
| 6 | Force charge |
| 7 | Force discharge |
Remote control modes (remote_control_mode)
| 0 | Off |
| 1 | Inverter export (PV priority) |
| 3 | Inverter import (PV priority) |
| 5 | Battery discharge |
| 7 | Battery charge |
| 9 | Grid export |
| 11 | Grid import |
| 13 | Inverter export (grid priority) |
| 15 | Inverter import (grid priority) |
1.0.18 (2026-07-24)
- Fix stale Modbus connection not being reset after a poll returns no data, which could cause the adapter to keep reusing a dead connection instead of reconnecting
1.0.17 (2026-07-24)
- Speed up adapter startup by creating/healing all datapoints in parallel instead of sequentially
- Make Modbus reconnect more robust (graceful socket close, automatic connect retry) to reduce ECONNRESET disconnects
1.0.16 (2026-07-23)
- Fix Admin GUI crash when hovering enum values in the object tree (#44): common.states is now resolved to plain per-language strings instead of translation objects, with automatic self-healing for existing installations
- Add common.desc (English/German) for control and status datapoints
1.0.15 (2026-06-28)
- Fix README manufacturer link: use solakon.de instead of the unrelated Home Assistant integration repo
1.0.14 (2026-06-28)
- Address manual review feedback: remove postinstall script, English log messages, i18n state labels and instanceObjects, translatable admin labels, sequential polling, README fixes, integration tests
1.0.13 (2026-06-11)
- Fix invalid role 'level.power' for power setpoint states (E1008)
1.0.12 (2026-06-10)
- Update @tsconfig/node22 to ^22.0.5 (W0083); migrate i18n to short format (S5601)
1.0.11 (2026-06-10)
- Add CHANGELOG_OLD.md for older entries (W6020); add tsconfig.json and @tsconfig/node22 (S0085/S0087); add README link to CHANGELOG_OLD.md
1.0.10 (2026-06-10)
- Fix W5005: use adapter.setTimeout in modbus.js; update eslint-config to 2.3.4; remove CHANGELOG_OLD.md
1.0.9 (2026-06-09)
- Fix JSON syntax error in io-package.json; limit news entries to 7 (E1032)
1.0.7 (2026-06-09)
- Fix @types/node version specifier: change >=22 to ^22.0.0 (W0066)
1.0.6 (2026-06-09)
- Fix Node.js requirement in README (>=22); add @types/node devDependency
1.0.5 (2026-06-09)
- Fix repo checker errors: require Node.js >=22, update release-script packages, remove redundant eslint devDependency, add macOS to CI test matrix, use this.setInterval/clearTimeout correctly
1.0.4 (2026-06-09)
- Add multilingual names (11 languages) to all datapoints
1.0.3 (2026-05-30)
- Add Node.js 24 to CI test matrix; use Node 24 for lint and deploy
1.0.2 (2026-04-13)
- Fix: add changelog to README, remove obsolete .eslintrc.json, add release-script packages, VS Code schema, automerge workflow
1.0.1 (2026-04-13)
- Fix: compact mode enabled, ESLint migrated to @iobroker/eslint-config, node: prefix for built-in modules, automated deploy workflow added
1.0.0 (2026-04-12)
- Initial release
- Modbus TCP communication
- All sensor data points (PV, battery, grid, inverter, EPS)
- All control data points (operating mode, SoC limits, remote control, EPS)
- Admin UI with jsonConfig
For older changelog entries see CHANGELOG_OLD.md.
Copyright (c) 2026 Marco Bertulies berto74online@gmail.com
Based on the Home Assistant integration for Solakon ONE.
