Simple RESTful API
This adapter allows to read and write ioBroker objects and state with web RESTful API
Current Release
3.0.7
bluefox, Apollon77, Marco.K
Simple-api
This is a RESTFul interface to read the objects and states from ioBroker and to write/control the states over HTTP Get/Post requests.
Use better ioBroker.rest-api instead of this adapter.
Usage
Call in browser http://ipaddress:8087/help to get the help about API. The result is:
  "getPlainValue": "http://ipaddress:8087/getPlainValue/stateID",
  "getPlainValue": "http://ipaddress:8087/getPlainValue/stateID?json",
  "get": "http://ipaddress:8087/get/stateID/?prettyPrint",
  "getBulk": "http://ipaddress:8087/getBulk/stateID1,stateID2/?prettyPrint",
  "set": "http://ipaddress:8087/set/stateID?value=1&prettyPrint",
  "toggle": "http://ipaddress:8087/toggle/stateID?prettyPrint",
  "setBulk": "http://ipaddress:8087/setBulk?stateID1=0.7&stateID2=0&prettyPrint",
  "objects": "http://ipaddress:8087/objects?pattern=system.adapter.admin.0*&prettyPrint",
  "objects": "http://ipaddress:8087/objects?pattern=system.adapter.admin.0*&type=adapter&prettyPrint",
  "states": "http://ipaddress:8087/states?pattern=system.adapter.admin.0*&prettyPrint"
  "search": "http://ipaddress:8087/search?pattern=system.adapter.admin.0*&prettyPrint",
  "query": "http://ipaddress:8087/query/stateID1,stateID2/?prettyPrint"
  "query": "http://ipaddress:8087/query/stateID1,stateID2/?noHistory=true&prettyPrint"
  "query": "http://ipaddress:8087/query/stateID1,stateID2/?dateFrom=2019-06-06T12:00:00.000Z&d&prettyPrint"
  "query": "http://ipaddress:8087/query/stateID1,stateID2/?dateFrom=2019-06-06T12:00:00.000Z&dateTo=2019-06-06T12:00:00.000Z&aggregate=minmax&count=2000&prettyPrint"
getPlainValue
Call e.g.:
http://ipaddress:8087/getPlainValue/system.adapter.admin.0.alive
Result:
true
Additionally, you can use query key json to force the parsing of the stored value:
http://ipaddress:8087/getPlainValue/javascript.0.value?json
Result:
{"a":1}
And without json flag the result would be
"{\"a\": 1}"
One more useful flag could be used too, noStringify:
http://ipaddress:8087/getPlainValue/javascript.0.stringValue?noStringify
Result:
VALUETEXT
And without noStringify flag the result would be
"VALUETEXT"
get
Call e.g.: http://ipaddress:8087/get/system.adapter.admin.0.alive
Result:
{"val":true,"ack":true,"ts":1442432193,"from":"system.adapter.admin.0","lc":1442431190,"expire":23437,"_id":"system.adapter.admin.0.alive","type":"state","common":{"name":"admin.0.alive","type":"boolean","role":"indicator.state"},"native":{}}
or call e.g.:
http://ipaddress:8087/get/system.adapter.admin.0.alive?prettyPrint
Result:
  "val": true,
  "ack": true,
  "ts": 1442432238,
  "lc": 1442431190,
  "expire": 28494,
  "_id": "system.adapter.admin.0.alive",
  "type": "state",
  "common": {
    "name": "admin.0.alive",
    "type": "boolean",
    "role": "indicator.state"
  "native": {}
getBulk
Get many states with one request, returned as an array of objects in order of a list in request and id/val/ts as a sub-object
set
Call e.g.: http://ipaddress:8087/set/javascript.0.test?value=1
Result:
{"id":"javascript.0.test","value":1}
or call e.g.: http://ipaddress:8087/set/javascript.0.test?value=1&prettyPrint
Result:
  "id": "javascript.0.test",
  "value": 1
Of course the data point javascript.0.test must exist.
Additionally, the type of value could be defined: http://ipaddress:8087/set/javascript.0.test?value=1&prettyPrint&type=string
and an acknowledgment flag could be defined too: http://ipaddress:8087/set/javascript.0.test?value=1&prettyPrint&ack=true
toggle
Toggles value:
  • boolean: true => false, false => true
  • number without limits: x => 100-x
  • number with limits: x => max - (x - min)
setBulk
Set many states with one request. This request supports POST method too, for POST data should be in body and not URL.
Please use content type text/plain for that.
setValueFromBody
This command allows setting the value of a given state to be set by the POST body content.
Call e.g.: http://ipaddress:8087/setValueFromBody/0_userdata.0.example_state with body hello where 0_userdata.0.example_state is the ID of the state.
objects
Read objects of a defined type from DB.
Call e.g.: http://ipaddress:8087/objects?pattern=enum.*&type=enum - to read all enums
or
http://ipaddress:8087/objects?pattern=system.adapter.admin.0.* - to read all states in branch system.adapter.admin.0
states
search
If a data source (History, SQL) in the configuration is set, then only the data points known to the data source are listed. If the option 'List all data points' has been activated or no data source has been specified, all data points will be listed. This command is needed for the Grafana JSON / SimpleJSON Plugin.
query
If a data source (History, SQL) has been specified in the instance configuration, the data from the specified data points are read out for the specified period, otherwise only the current value is read out. This command is needed for the Grafana JSON / SimpleJSON Plugin.
help
Gives this output back
Usage
Assume, we have no security and the server runs on default port 8087.
For all queries, the name or id of the state can be specified.
For every request that returns JSON you can set parameter prettyPrint to get the output in human-readable form.
If authentication is enabled, two other fields are mandatory: ?user=admin&pass=iobroker
getPlainValue
Read state value as text. You can specify more ids divided by semicolon
http://ip:8087/getPlainValue/admin.0.memHeapTotal => 31.19
http://ip:8087/getPlainValue/admin.0.memHeapTotal, admin.0.memHeapUsed =>
  31.19
  17.52
get
Read state and object data of state as JSON. You can specify more ids divided by semicolon. If more than one ID is requested, the JSON array will be returned.
http://localhost:8087/get/admin.0.memHeapTotal/?prettyPrint =>
    "val": 31.19,
    "ack": true,
    "ts": 1423154619,
    "lc": 1423153989,
    "_id": "system.adapter.admin.0.memHeapTotal",
    "type": "state",
    "common": {
      "name": "admin.0.memHeapTotal",
      "type": "number",
      "role": "indicator.state",
      "unit": "MB",
      "history": {
        "enabled": true,
        "changesOnly": true,
        "minLength": 480,
        "maxLength": 960,
        "retention": 604800,
        "debounce": 10000
    "native": {}
http://ip:8087/get/admin.0.memHeapTotal,admin.0.memHeapUsed/?prettyPrint =>
      "val": 31.19,
      "ack": true,
      "ts": 1423154544,
      "lc": 1423153989,
      "type": "state",
      "common": {
        "type": "number",
        "unit": "MB",
        "history": {
          "enabled": true,
          "minLength": 480,
          "maxLength": 960,
          "debounce": 10000
      "native": {}
      "val": 16.25,
      "ack": true,
      "ts": 1423154544,
      "lc": 1423154544,
      "_id": "system.adapter.admin.0.memHeapUsed",
      "type": "state",
      "common": {
        "name": "admin.0.memHeapUsed",
        "type": "number",
        "unit": "MB",
        "history": {
          "enabled": true,
          "minLength": 480,
          "maxLength": 960,
          "debounce": 10000
      "native": {}
getBulk
Read the states of more IDs with timestamp. You can specify more ids divided by semicolon. The JSON array will be returned always.
http://ip:8087/getBulk/admin.0.memHeapTotal,admin.0.memHeapUsed/?prettyPrint =>
      "admin.0.memHeapTotal": {
          "val": 31.19,
          "ts": 1423154754
      "admin.0.memHeapUsed": {
          "val": 15.6,
          "ts": 1423154754
set
Write the states with specified IDs. You can specify wait option in milliseconds to wait for answer from driver.
http://ip:8087/set/hm-rpc.0.IEQ12345.LEVEL?value=1&prettyPrint =>
       "id": "hm-rpc.0.IEQ12345.LEVEL",
       "value": 1
http://ip:8087/set/hm-rpc.0.IEQ12345.LEVEL?value=1&wait=5000&prettyPrint =>
       "val": 1,
       "ack": true,
       "ts": 1423155399,
       "from": "hm-rpc.0.IEQ12345.LEVEL",
       "lc": 1423155399
If no answer is received in specified time, the null value will be returned. In the first case the answer will be returned immediately and ack is false. In the second case ack is true. That means it was response from driver.
setBulk
  • write the bulk of IDs in one request.
http://ip:8087/setBulk?hm-rpc.0.FEQ1234567:1.LEVEL=0.7&Anwesenheit=0&prettyPrint =>
      "id": "hm-rpc.0.FEQ1234567:1.LEVEL",
      "val": "0.7"
      "error": "error: datapoint \"Anwesenheit\" not found"
You can send this request as POST too. Please use content type text/plain and put the data in the body.
objects
Get the list of all objects for pattern. If no pattern is specified, all objects as JSON array will be returned.
http://ip:8087/objects?prettyPrint =>
  "system.adapter.admin.0.uptime": {
    "_id": "system.adapter.admin.0.uptime",
    "type": "state",
    "common": {
      "name": "admin.0.uptime",
      "type": "number",
      "unit": "seconds"
    "native": {}
  "system.adapter.admin.0.memRss": {
    "_id": "system.adapter.admin.0.memRss",
    "type": "state",
    "common": {
      "name": "admin.0.memRss",
      "desc": "Resident set size",
      "type": "number",
      "unit": "MB",
      "history": {
        "enabled": true,
        "minLength": 480,
        "maxLength": 960,
        "debounce": 10000
    "native": {}
Get all control objects of adapter system.adapter.admin.0: http://ip:8087/objects?pattern=system.adapter.admin.0*&prettyPrint =>
      "type": "state",
      "common": {
        "type": "number",
        "unit": "seconds"
      "native": {}
states
Get the list of all states for pattern. If no pattern is specified, all states as JSON array will be returned.
http://ip:8087/states?prettyPrint =>
      "val": 32176,
      "ack": true,
      "ts": 1423156164,
      "lc": 1423156164
      "val": 41.14,
      "ack": true,
      "ts": 1423156164,
      "lc": 1423156119
    "system.adapter.admin.0.memHeapTotal": {
      "val": 31.19,
      "ack": true,
      "ts": 1423156164,
      "lc": 1423155084
http://ip:8087/states?pattern=system.adapter.admin.0*&prettyPrint =>
        "val": 32161,
        "ack": true,
        "ts": 1423156149,
        "lc": 1423156149
        "val": 41.14,
        "ack": true,
        "ts": 1423156149,
        "lc": 1423156119
        "val": 31.19,
        "ack": true,
        "ts": 1423156149,
        "lc": 1423155084
      "system.adapter.admin.0.memHeapUsed": {
        "val": 19.07,
        "ack": true,
        "ts": 1423156149,
        "lc": 1423156149
      "system.adapter.admin.0.connected": {
        "val": true,
        "ack": true,
        "ts": 1423156149,
        "lc": 1423128324,
        "expire": 28100
      "system.adapter.admin.0.alive": {
        "val": true,
        "ack": true,
        "ts": 1423156149,
        "lc": 1423128324,
        "expire": 28115
search
http://ip:8087/search?pattern=system.adapter.admin.0*&prettyPrint =>
    "system.adapter.admin.0.outputCount",
    "system.adapter.admin.0.inputCount",
    "system.adapter.admin.0.cputime",
    "system.adapter.admin.0.cpu",
    "system.adapter.admin.0.connected",
query
If a data source (History, SQL) is specified, data from the specified data points will be retrieved for the given period.
http://ip:8087/query/system.host.iobroker-dev.load,system.host.iobroker-dev.memHeapUsed/?prettyPrint&dateFrom=2019-06-08T01:00:00.000Z&dateTo=2019-06-08T01:00:10.000Z =>
      "target": "system.host.iobroker-dev.load",
      "datapoints": [
          0.12,
          1559955600000
          0.46,
          1559955601975
          0.44,
          1559955610000
      "target": "system.host.iobroker-dev.memHeapUsed",
      "datapoints": [
          23.01,
          1559955600000
          22.66,
          1559955601975
          22.69,
          1559955610000
If no data source was specified or the noHistory parameter is passed, then only the current value of the data point is read out.
http://ip:8087/query/system.host.iobroker-dev.load,system.host.iobroker-dev.memHeapUsed/?prettyPrint&noHistory=true =>
      "datapoints": [
          0.58,
          1559970500342
      "datapoints": [
          21.53,
          1559970500342
You can use relative time in the query. For example, dateFrom=-1h or dateTo=today.
The following relative patterns are supported:
  • hour or thisHour or this hour - start of the current hour
  • last hour or lastHour - start of the previous hour
  • today - start of the current day
  • yesterday - start of the previous day
  • week or thisWeek or this week - start of the current week
  • lastWeek or last week - start of the previous week
  • month or thisMonth or this month - start of the current month
  • lastMonth or last month - start of the previous month
  • year or thisYear or this year - start of the current year
  • lastYear or last year - start of the previous year
  • -Nd - N days ago
  • -NM - N months ago
  • -Ny - N years ago
  • -Nh - N hours ago
  • -Nm - N minutes ago
  • -Ns - N seconds ago
CORS
With option "Allow origin (CORS)" you can set the Access-Control-Allow-Origin header to allow requests from other domains.
If you leave it blank, the header will not be set.
Modifiers
You can use some options to modify the answer:
  • prettyPrint - to get the output in human-readable form
  • json - to force the parsing of the value in the getPlainValue command
  • timeRFC3339 - to get the time of timestamps (ts and lc) in RFC3339 format, like 2019-06-08T01:00:00.000Z
  • callback - response with JSONP format. In callback=<CALLBACK> the CALLBACK is the name of the callback function
Authentication
This adapter supports the following types of authentication:
  • Query parameter user and pass
  • Basic authentication
  • Oauth2 Bearer token in the header. Read more in the web adapter about how to get tokens.
3.0.7 (2025-06-16)
  • (@GermanBluefox) corrected reading of history data
3.0.6 (2025-03-15)
  • (bluefox) Added support for 'Access-Control-Allow-Origin'
  • (bluefox) Removed letsencrypt information
  • (bluefox) Added basic and OAuth2 authentication
  • (bluefox) Implemented JSONP response
  • (bluefox) Implemented relative times for query
3.0.5 (2025-03-13)
  • (bluefox) Corrected the indication of running mode in admin
  • (bluefox) Corrected the writing of numeric values
  • (bluefox) Clear cache after 10 minutes
3.0.0 (2025-03-09)
  • BREAKING: When the adapter is configured to work as a web extension, no own local port is opened anymore
  • (bluefox) Updated packages
  • (bluefox) Migrated to TypeScript
  • (bluefox) If State/Object not found, the response will be 404 (and not 500)
  • (bluefox) If a user has no permission, the response will be 403 (and not 401)
2.8.0 (2024-05-23)
  • (foxriver76) ported to @iobroker/webserver
2.7.2 (2022-10-08)
  • (Apollon77) Prepare for future js-controller versions
2.7.1 (2022-08-29)
  • (bluefox) Check if the port is occupied only on defined interface
  • (bluefox) Added JSON config
2.7.0 (2022-05-31)
  • (crycode-de) Allow use of ack flag for setBulk post requests
  • (Apollon77) Return an ack flag too on getBulk
2.6.5 (2022-04-14)
  • Added support for aggregate and count for queries
2.6.4 (2022-03-17)
  • (Apollon77) Optimize performance, especially when using names instead of object ids
2.6.3 (2022-02-19)
  • (Apollon77) Optimize error message for multi-language objects
  • (Apollon77) Do not overwrite state properties by object properties
2.6.2 (2021-11-12)
  • (bluefox) Support of new flags for getPlainValue: json and noStringify
2.6.1 (2021-05-13)
  • (Apollon77) Catch error in request parsing when malformed (Sentry IOBROKER-SIMPLE-API-16)
2.6.0 (2021-05-09)
  • (Apollon77) Also URL-Decode the path parts like state ids
  • (Apollon77) Optimize for js-controller 3.3
2.5.3 (2021-01-25)
  • (Apollon77) Make sure that delayed answers are not crashing (Sentry IOBROKER-SIMPLE-API-Z)
2.5.2 (2021-01-09)
  • (bluefox) Support of new Let's Encrypt (only with js-controller 3.2.x)
2.4.8 (2020-09-17)
  • (Apollon77) Make sure missing favico file locally is not throwing exceptions (Sentry IOBROKER-SIMPLE-API-G)
2.4.7 (2020-08-17)
  • (Apollon77) check that targets are an array for "query" requests (Sentry IOBROKER-SIMPLE-API-F)
2.4.6 (2020-06-11)
  • (Apollon77) Make sure that the adapter is showing the correct error when webserver cannot be initialized (Sentry IOBROKER-SIMPLE-API-7)
2.4.5 (2020-05-04)
  • (Apollon77) webserver initialization optimized again to prevent errors with invalid certificates
2.4.4 (2020-05-02)
  • (Apollon77) Make sure Permission errors do not crash adapter (Sentry IOBROKER-SIMPLE-API-3)
2.4.3 (2020-04-30)
  • (Apollon77) Optimize web server error handling
2.4.1 (2020-04-23)
  • (bluefox) Caught the web server errors
2.4.0 (2020-04-12)
  • (Apollon77) Add Sentry support with js-controller 3.0
  • (Apollon77) fix potential crash
2.3.3 (2019-11-16)
  • (bluefox) Added response code for unknown commands
2.3.2 (2019-10-18)
  • (Apollon77) Fix Admin 3 support
2.3.1 (2019-10-12)
  • (bluefox) Admin 3 is now supported
  • (bluefox) NPM packages were updated
2.2.0 (2019-09-10)
  • (bluefox) New flags are supported: ack and type
  • (bluefox) Return error codes as JSON if no pretty print defined
2.1.2 (2019-09-05)
  • (Apollon77) fix compact mode
2.1.0 (2019-07-05)
2.0.5 (2019-06-26)
  • (Apollon77) remove logging
2.0.4 (2019-06-23)
  • (Apollon77) fix usage as web extension
2.0.2 (2018-12-17)
  • (Apollon77) fix decoding for state Ids with # in it
2.0.0 (2018-06-29)
  • (Giermann) BREAKING CHANGE: getBulk is returning data in a different structure
1.6.3 (2018-04-15)
  • (Apollon77) Return used character encoding (UTF-8)
1.6.2 (2017-11-27)
  • (Apollon77) Fix decoding problems
1.6.1 (2017-09-25)
  • (Apollon77) Fix statuscode for setBulk and optimize permission errors
1.6.0 (2017-07-10)
  • (Apollon77) Fix handling of URL-encoded values, they are now decoded properly
  • (Apollon77) Optimize Permission handling
  • (Apollon77) add possibility to only allow access to states where user is also owner, finally works correct with js-controller 1.1.1!
1.5.0 (2017-03-10)
  • (greyhound) Add new POST method setValueFromBody
1.4.0 (2017-01-05)
  • (bluefox) new web server plugin support
1.3.0 (2016-08-30)
  • (bluefox) compatible only with new admin
1.2.0 (2016-08-27)
  • (bluefox) support of letsencrypt certificates
1.1.1 (2016-07-06)
  • (bluefox) support of chained certificates
1.1.0 (2016-02-09)
  • (bluefox) fix toggle, objects, states, setBulk, POST
  • (bluefox) add tests
1.0.0 (2015-09-30)
  • (bluefox) stop adapter before update
0.1.2 (2015-06-28)
  • (bluefox) add description in readme.md
  • (bluefox) change "toggle" for boolean and numbers
0.1.1 (2015-06-28)
  • (bluefox) change setForeignState api
  • (bluefox) add type to io-package.json
  • (bluefox) enable run from "web"
  • (bluefox) add default user
0.1.0 (2015-06-10)
  • (bluefox) support of user permissions
0.0.4 (2015-03-11)
  • (bluefox) remove socket.io from file
0.0.3 (2015-02-13)
  • (bluefox) remove socket.io from dependencies
0.0.2 (2015-02-12)
  • (bluefox) enable be a part of "web"
0.0.1 (2015-02-06)
  • (bluefox) initial commit
The MIT License (MIT)
Copyright (c) 2015-2025 bluefox dogafox@gmail.com
