ioBroker adapter for password and e-mail breach checking
This adapter checks whether your passwords or e-mail addresses have appeared in known data breaches — without ever sending your actual passwords to any server.
Features
- Privacy first – passwords are never transmitted. The SHA-1 hash is computed locally in the browser; only the first 5 characters are sent to the API (k-anonymity)
- Password check – uses the free Have I Been Pwned k-anonymity API — no API key required
- E-mail check – uses the free XposedOrNot API — no API key required
- Breach details – individual data points per breach source under
emails.<id>.leaks.* - ioBroker notifications – sends a system notification when a new breach is detected, in the configured system language (11 languages supported)
- HTML visualisation – generates a ready-to-use HTML data point for use in VIS or other dashboards
- Configurable appearance – theme (light/dark), background transparency, card transparency, font size
- Configurable interval – check every 3, 6, 12 or 24 hours
- Malware detection – detects pawns-cli (iProyal proxy software) via process and file check (Linux only — automatically skipped on Windows and macOS)
Platform support
Password and e-mail breach checking works on all platforms (Linux, Windows, macOS).
The malware detection (pawns-cli check) is Linux-only — the malware detection tool (pawns-cli) is a Linux binary and is not available on Windows or macOS. The check is automatically skipped on non-Linux systems; no configuration is required.
Installation
Install via the ioBroker Admin interface — search for pwned-check.
Configuration
Passwords tab
Add one entry per password you want to monitor. Enter a description (e.g. the service name) and the password. The SHA-1 hash is computed in your browser and stored — the plaintext password is never saved.
| Field | Description |
| Description | A label for this password (e.g. "GitHub") |
| Password | Entered once; only the SHA-1 hash is stored |
E-Mails tab
Add one entry per e-mail address to monitor.
| The e-mail address to check |
Settings tab
| Setting | Description | Default |
| Interval | How often to check for new breaches | 24 hours |
| Theme | Light or dark visualisation | Light |
| Background transparency | Outer container opacity (0 = fully transparent) | 100% |
| Card transparency | Individual entry card opacity | 100% |
| Font size | Text size in the visualisation | 14 px |
Data points
The adapter creates data points under pwned-check.<instance>.
Passwords
| Data point | Type | Description |
passwords.<id>.isPwned | boolean | true if found in a breach |
passwords.<id>.leakCount | number | Number of times found in breach databases |
passwords.<id>.lastCheck | string | ISO timestamp of last successful check |
E-Mails
emails.<id>.isPwned | boolean | true if found in a breach |
emails.<id>.lastCheck | string | ISO timestamp of last successful check |
emails.<id>.leaks.<service> | boolean | true for each breach source found |
Other
visualisation | string | HTML snippet for use in VIS or ioBroker.vis-2 |
info.connection | boolean | true while a check is running |
Privacy
- Passwords are never stored in plaintext — only their SHA-1 hash
- Password hashes are checked using the HIBP k-anonymity method: only the first 5 hex characters of the hash are transmitted; the full hash never leaves your system
- E-mail addresses are sent to the XposedOrNot API over HTTPS
0.0.10 (2026-07-19)
- (ipod86) fix: validate checkInterval bounds (clamp to 1–596 h) and switch to setTimeout loop to prevent concurrent check runs
- (ipod86) fix: remove redundant safeTextColor alias in updateVisualisation
- (ipod86) fix: correct JSDoc on loadPrevState method
0.0.9 (2026-07-01)
- (ipod86) fix: update adapter-core to 3.4.1, clarify malware scanner description in README (W0034)
- (ipod86) fix: update admin dependency to >= 7.8.23 and fix dependabot cooldown format (W8917)
0.0.8 (2026-06-09)
- (ipod86) fix: robust language detection for widget (toLowerCase + language fallback)
- (ipod86) fix: translate all widget strings to system language (SAFE/PWNED/section headers/last check)
0.0.7 (2026-06-08)
- (ipod86) fix: translate all object names and widget texts to English/system language
- (ipod86) fix: malware notification now only sent on new detection, not on every check
- (ipod86) fix: malware check skipped on non-Linux platforms (Windows/macOS)
- (ipod86) fix: i18n description key corrected in 9 language files
0.0.6 (2026-06-06)
- (ipod86) fix: add missing intermediate folder/channel objects for emails, passwords, system, leaks (E3009)
- (ipod86) fix: update @alcalzone/release-script to >=5.2.1 (E0036)
Older changelogs are available in CHANGELOG_OLD.md.
Copyright (c) 2026 ipod86
