Philips TV
Adapter to control Philips TVs
Current Release
0.5.4
AlCalzone, Moritz Heusinger
Philips TV adapter for ioBroker
Adapter to control Philips TVs via network
Disclaimer
The developers of this module are in no way endorsed by or affiliated with Koninklijke Philips N.V., or any associated subsidiaries, logos or trademarks.
0.5.4 (2024-07-29)
  • (foxriver76) fixed the pairing process due to changes in json config
  • (foxriver76) stability improvements
0.5.3 (2023-02-27)
  • (foxriver76) update lib
0.5.2 (2022-10-26)
  • (foxriver76) we renamed customAmbilightCommand to currentAmbilightConfiguration and update the state on polling (closes #431) Please delete customAmbilightCommand manually
0.5.1 (2022-10-17)
  • (foxriver76) fix ESOCKETTIMEDOUT on post requests
0.5.0 (2022-10-17)
  • (foxriver76) added new state hdmiInput without relying on Google Assistant
0.4.5 (2022-10-06)
  • (foxriver76) fixed communication with API
0.4.4 (2022-10-06)
  • (foxriver76) fix build
0.4.3 (2022-10-06)
  • (foxriver76) try to fix ESOCKETTIMEDOUT
0.4.0 (2022-09-17)
  • (foxriver76) marked state definitions of launch commands to be read-only
  • (foxriver76) we now use the real device name for the device object
  • (foxriver76) workaround to switch hdmi input via Google Assistant
0.3.2 (2022-09-17)
  • (foxriver76) corrected button PlayPause to lowercase playPause
0.3.1 (2022-09-16)
  • (foxriver76) added admin v5 dependency
0.3.0 (2022-09-12)
  • (foxriver76) adapter rework to support Android and JointSpace V6 API
  • BREAKING: Please use the adapter config to configure this instance properly
0.2.0
  • (AlCalzone) Support sending key presses
0.1.0
  • (AlCalzone) Initial release
Copyright (c) 2022 Moritz Heusinger moritz.heusinger@gmail.com
