Philips TV-Adapter für ioBroker
Adapter zur Steuerung von Philips-Fernsehern über das Netzwerk
Haftungsausschluss
Die Entwickler dieses Moduls stehen in keiner Verbindung zu Koninklijke Philips NV oder deren Tochtergesellschaften, Logos oder Marken und werden von diesen auch nicht unterstützt.
0.5.4 (2024-07-29)
- (foxriver76) fixed the pairing process due to changes in json config
- (foxriver76) stability improvements
0.5.3 (2023-02-27)
- (foxriver76) update lib
0.5.2 (2022-10-26)
- (foxriver76) we renamed
customAmbilightCommandtocurrentAmbilightConfigurationand update the state on polling (closes #431) Please deletecustomAmbilightCommandmanually
0.5.1 (2022-10-17)
- (foxriver76) fix
ESOCKETTIMEDOUTon post requests
0.5.0 (2022-10-17)
- (foxriver76) added new state
hdmiInputwithout relying on Google Assistant
0.4.5 (2022-10-06)
- (foxriver76) fixed communication with API
0.4.4 (2022-10-06)
- (foxriver76) fix build
0.4.3 (2022-10-06)
- (foxriver76) try to fix
ESOCKETTIMEDOUT
0.4.0 (2022-09-17)
- (foxriver76) marked state definitions of launch commands to be read-only
- (foxriver76) we now use the real device name for the device object
- (foxriver76) workaround to switch hdmi input via Google Assistant
0.3.2 (2022-09-17)
- (foxriver76) corrected button
PlayPauseto lowercaseplayPause
0.3.1 (2022-09-16)
- (foxriver76) added admin v5 dependency
0.3.0 (2022-09-12)
- (foxriver76) adapter rework to support Android and JointSpace V6 API
- BREAKING: Please use the adapter config to configure this instance properly
0.2.0
- (AlCalzone) Support sending key presses
0.1.0
- (AlCalzone) Initial release
Copyright (c) 2022 Moritz Heusinger moritz.heusinger@gmail.com
