Unofficial ntfy.sh client adapter for ioBroker
Send and receive notifications via ntfy.sh directly from ioBroker. This adapter is a community project and not affiliated with ntfy LLC.
Features
- Publish notifications with full ntfy parameter support
- Subscribe to topics and receive messages in real-time via SSE (Server-Sent Events)
- Account statistics – view usage stats (messages, emails, calls, attachments, reservations)
- Server version check – detect available updates for self-hosted ntfy instances
- Connection status – monitor the adapter's connection to the ntfy server with dynamic health checks
- Basic authentication and bearer token support
- Custom server URLs (or the standard ntfy.sh instance)
- Integrated
sendToBlockly blocks for graphic scripts (send and manage) - Dismiss (clear) and delete notifications by sequence ID
- File upload attachments via PUT
Supported Notification Parameters
| Parameter | Description |
message | Notification message text (defaults to "triggered" if empty) |
topic | Target topic (falls back to configured default topic) |
title | Notification title |
priority | Priority level: 1 (min), 2 (low), 3 (default), 4 (high), 5 (max) |
tags | Tags or emoji shortcodes (comma-separated string or array) |
click | URL opened when notification is clicked |
attach | URL of file to attach |
attach_file | Local file path to upload as attachment (uses PUT) |
filename | Custom filename for the attachment |
actions | Action buttons (JSON string or object) |
markdown | Enable Markdown formatting (true/false) |
delay | Delay delivery (e.g. "30s", "5m", "2h") |
email | Forward notification to this email address |
call | Phone number to call with TTS (requires ntfy Pro) |
icon | Icon URL displayed next to the notification |
sequence_id | Replace/update an existing notification with the same Sequence-ID |
disable_cache | Set to true/yes to disable server-side caching |
disable_firebase | Set to true/yes to disable forwarding to Firebase Cloud Messaging (Android) |
unified_push | Set to 1 to enable UnifiedPush support |
template | Use true/yes for inline templates, or a name like github for predefined ones |
data | JSON data object or string to be used for the template context |
Topic Subscription (Receive Messages)
Configure topics in the adapter settings under the Topics tab. The adapter subscribes to these topics via SSE and creates states for each topic under ntfy-client.0.topics.<topicName>:
| State | Description |
lastMessage | Last received message text |
lastTitle | Last received title |
lastPriority | Last received priority |
lastTags | Last received tags (comma-separated) |
lastClick | Last received click URL |
lastIcon | Last received icon URL |
lastActions | Last received actions (JSON) |
lastAttachmentUrl | Last received attachment URL |
lastAttachmentName | Last received attachment name |
lastAttachmentType | Last received attachment MIME type |
lastAttachmentSize | Last received attachment size (bytes) |
lastAttachmentExpires | Last received attachment expiry timestamp |
lastTimestamp | Last message timestamp |
lastExpires | Last message expiry timestamp |
lastMessageId | Last message ID |
lastSequenceId | Last sequence ID (for managing messages) |
lastTopic | Last received topic name |
lastEvent | Last received event type |
lastJson | Full JSON of last received message |
subscribed | Whether the subscription is active |
Account Statistics
When authentication is configured, the adapter fetches account statistics every 15 minutes and stores them under ntfy-client.0.stats:
- Messages: published, remaining, limit, expiry duration
- Emails: sent, remaining, limit
- Phone calls: made, remaining, limit
- Reserved topics: count, remaining, limit
- Attachments: storage used/remaining/limit, expiry duration, file size limit, bandwidth limit
- Account: subscription tier
Connection Status & Health Checks
The adapter monitors the connection to the ntfy server via the info.connection state:
info.connection | Connection status to the ntfy server |
info.serverVersion | Current ntfy server version |
info.latestVersion | Latest available version (self-hosted only) |
info.updateAvailable | Whether a server update is available |
The health check runs against the /v1/health endpoint with dynamic intervals:
- Every 6 hours when the server is healthy
- Every 5 minutes when the last check failed (for faster recovery)
Additionally, the connection status is automatically set to connected when:
- A notification is successfully sent
- An SSE subscription connects successfully
- A message is received on a subscribed topic
Blockly Examples
Under the Sendto category, use the following blocks:
1. ntfy-client notification (send)
Dispatch a message with all supported parameters:
- Set the Instance.
- Set the Message.
- Set the Topic (or leave empty to use the default topic).
- Optionally add more parameters via the mutator (gear icon): title, priority, tags, icon, click URL, actions, attachments, delay, email, call, etc.
- Use Sequence ID if you want to update/overwrite an existing notification later.
2. ntfy-client management (manage)
Clear or delete an existing notification:
- Set the Instance.
- Set the Action (mark as read and dismiss, or delete).
- Set the Topic.
- Set the Sequence ID of the message you want to manage.
Note on IDs: Each notification is assigned a unique
id(Message ID) by the server.
- If you provide a
sequence_idwhen sending, you must use thissequence_idfor all management actions (dismiss, delete).- If you do not provide a
sequence_id, the server-generatedid(Message ID) serves as thesequence_idfor management.Multiple messages sharing the same
sequence_idform a sequence — only the latest message in a sequence is displayed.
JavaScript Examples
Send a notification
sendTo("ntfy-client.0", "send", {
message: "Motion detected in the backyard!",
title: "Security Alert",
topic: "home_alerts_xyz",
priority: "high",
tags: "warning,motion",
click: "https://example.com",
markdown: true,
Send with email forwarding and icon
message: "Temperature above threshold!",
email: "admin@example.com",
icon: "https://example.com/icon.png",
priority: "4",
Send with file attachment
message: "Security camera snapshot",
attach_file: "/tmp/snapshot.jpg",
filename: "camera_snapshot.jpg",
Send with action buttons
message: "Doorbell rang!",
actions: [
{ action: "view", label: "Open Camera", url: "https://camera.example.com" },
action: "http",
label: "Turn on Light",
url: "https://ha.example.com/api/light/on",
method: "POST",
Send with template (Inline / Manual)
Use the message field as your template string and provide the JSON context in the data field:
template: true,
message: "Current temperature is {{.temp}}°C from {{.sensor}}",
data: { temp: 42, sensor: "living_room" },
Send with template (Predefined / e.g. GitHub)
For predefined templates like github, provide the original webhook JSON data in the data field. The data structure must match what the original service sends (see template source):
topic: "github_webhooks",
template: "github",
data: {
action: "opened",
issue: {
number: 42,
title: "Found a bug",
html_url: "https://github.com/my/repo/issues/42",
user: { html_url: "https://github.com/octocat" },
repository: {
full_name: "my/repo",
html_url: "https://github.com/my/repo",
Note: Predefined templates expect the exact data structure from the original service. Missing or misnamed fields will show as
<no value>. For full control over formatting, use an inline template (template: true) instead.
Dismiss a notification
sendTo("ntfy-client.0", "dismiss", {
sequence_id: "abc123",
Delete a notification
sendTo("ntfy-client.0", "delete", {
Authentication
Ntfy supports a few variations:
- None: Suitable for standard ntfy.sh servers (topics are public!).
- Basic Auth: Setup a local server with Username and Password.
- Access Token: Create tokens and use Bearer token validation for your topic.
Commands
| Command | Description |
send / publish | Send a notification |
dismiss / clear | Dismiss (mark as read) a notification by sequence_id |
delete | Delete a notification by sequence_id |
- (ioBroker-Bot) Adapter requires admin >= 7.8.23 now.
0.1.4 (2026-06-07)
- (lubepi) FIXED: Adapter now creates missing parent folder objects (stats, topics) so they appear correctly in the object tree
- (lubepi) FIXED: Corrected state roles for attachment-related states (storage, file size, bandwidth)
- (lubepi) ENHANCED: Hardened error handling throughout the adapter and extracted reusable helper methods
- (lubepi) ENHANCED: Cleaned up orphaned translation keys from all language files
0.1.3 (2026-04-12)
- (lubepi) Refactor: Move internal config signature to local file storage (remove useless object from tree)
0.1.2 (2026-04-12)
- (lubepi) Update axios due to critical security fixes (SSRF, Header Injection)
0.1.1 (2026-04-12)
- (lubepi) Reset runtime states on server or account configuration changes
- (lubepi) Mask credentials in logs and only log the configured authentication type
0.1.0 (2026-04-12)
- (lubepi) Initial release with full ntfy.sh support
- Subscribe to topics via SSE (receive messages in real-time)
- Publish notifications with all ntfy parameters (title, priority, tags, click, attach, actions, markdown, delay, email, call, icon, sequence_id, disable_cache, disable_firebase, unified_push, template)
- Dismiss and delete notifications by sequence_id
- Account statistics (messages, emails, calls, attachments, reservations)
- Server version check for self-hosted instances
- Dynamic connection status monitoring with health checks
- Blockly blocks for sending and managing notifications
- Full i18n support (en, de, ru, pt, nl, fr, it, es, pl, uk, zh-cn)
Legal Notice
This adapter is NOT an official product of ntfy LLC. The name ntfy, the logo and branding are trademarks of ntfy LLC. This adapter is a community project to provide integration into ioBroker.
Copyright (c) 2026 lubepi
