Versions
Publish and subscribe ioBroker states to MQTT Brokers
Sentry
Adapter Settings
on connect topic and message
The on connect message is published to the on connect topic every time the client connects or reconnects to the server.
on disconnect topic and message
The on disconnect message is published to the on disconnect topic when the adapter stops gracefully.
last will topic and message
The last will message is published to the last will topic every time the client connects or reconnects to the server.
The Server will store this message and send it to its subscribers when the client disconnects unexpectedly.
subscriptions
Comma separated list of topics that are not covered by existing states. Received messages are converted to states within the adapter's namespace (e.g. mqtt.0) and subscribed. You can remove topics after all states have been created.
split JSON into states for topics
Comma separated list of MQTT topic filters (without prefix, + and # are allowed), e.g. zigbee2mqtt/+.
A JSON object received on a matching topic is not stored as text, but split into a channel with one state per value.
zigbee2mqtt/sensor = {"battery":100,"occupancy":false,"color":{"x":0.3}} creates the channel mqtt-client.0.zigbee2mqtt.sensor
with the states battery (number), occupancy (boolean) and the channel color with the state x (number).
- Nested objects become channels (up to 5 levels), arrays are stored as JSON text.
- Dots, whitespace and characters that are not allowed in IDs are replaced by
_in the IDs. - Values written in ioBroker (
ack=false) are sent as JSON to<topic>/set, e.g.{"color":{"x":0.5}}- this is the convention of zigbee2mqtt. The device confirms the new value with its next message. - Payloads that are no JSON object (arrays, numbers, text) are handled as before.
The topics still have to be subscribed, e.g. with zigbee2mqtt/# in the additional subscriptions.
States that older versions created as text for these topics are not changed and can be deleted.
publish prefix
When publishing this will be prepended to all topics. Default is empty (no prefix).
subscribe prefix
When subscribing this will be prepended to all topics. Default is empty (no prefix).
State Settings
enabled
Enables or disables the mqtt-client functionality for this state. Disabling will delete any mqtt-client settings from this state.
topic
The topic this state is published to and subscribed from. default: state-ID converted to a mqtt topic.
When the topic is derived from the state-ID, dots are converted to topic level separators (/) and the
following characters are replaced by _:
- the mqtt wildcards
+and#- they are not allowed in topic names (used e.g. by shelly IDs likeshelly.0.SHSW-1#B96701#1) - slashes contained in the ID itself - they would create additional topic levels
- whitespace - it must not end up in object IDs when the topic is converted back
So shelly.0.SHSW-1#B96701#1.Relay0.Switch becomes shelly/0/SHSW-1_B96701_1/Relay0/Switch.
If two state-IDs derive to the same topic (e.g. a#b and a+b), a warning is logged. Configure an explicit topic for one of them in this case.
publish
enablestate will be publishedchanges onlystate will only be published when its value changesas objectwhole state will be published as objectqossee http://www.hivemq.com/blog/mqtt-essentials-part-6-mqtt-quality-of-service-levelsretainsee http://www.hivemq.com/blog/mqtt-essentials-part-8-retained-messages
subscribe
enabletopic will be subscribed and state will be updated accordinglychanges onlystate will only be written when the value changedas objectmessages will be interpreted as objectsqossee http://www.hivemq.com/blog/mqtt-essentials-part-6-mqtt-quality-of-service-levelsackon state updates the ack flag will be set accordingly
Note
- when ack is set to true it will overwrite objects ack, see
as object - to prevent message loops, if both publish and subscribe are enabled
changes onlyis always on for subscribe
4.1.0 (2026-09-15)
- (@GermanBluefox) Adapter requires node.js >= 22.19 now
- (@Tarvion) Automatically derived topics no longer contain the mqtt wildcards
+and#(as used by shelly IDs), slashes or whitespace taken from the state-ID. These characters are replaced by_now - (@GermanBluefox) A warning is logged if two states derive to the same topic
- (@GermanBluefox) Adapter icon converted to SVG
- (@GermanBluefox) The adapter was refactored to TypeScript
- (@GermanBluefox) Fixed: stopping the adapter waited for the timeout when no broker was configured or after
stopInstance - (@GermanBluefox) Fixed: states created from received topics now have
common.roleinstead of aroleoutside ofcommon - (@GermanBluefox) Fixed: with "subscribe as object", the loop protection and "changes only" skipped changed values instead of unchanged ones
- (@GermanBluefox) Fixed: deleting a state that was published with retain now also removes the retained message from the broker
- (@GermanBluefox) Fixed: MQTT version 3 connects with the protocol name
MQIsdp, so MQTT 3.1 brokers accept the connection. The versions are labeled 3.1, 3.1.1 and 5.0 in the settings (#169) - (@GermanBluefox) Fixed: special characters like
%or:in the user name, password or client ID broke the connection (#200) - (@GermanBluefox) New option "split JSON into states for topics": JSON objects, e.g. from zigbee2mqtt, become a channel with one state per value; written values are sent to
<topic>/set(#322) - (@GermanBluefox) Fixed: a subscribed state was not updated after a restart when an object of the adapter's namespace had the same topic. Changing the topic of a state now also unsubscribes the old topic, and no copy of a state is created for an old topic anymore (#418)
- (@GermanBluefox) Fixed: every change of an object (e.g.
extendObjectby another adapter) published the current value of the state again, which could overwrite a newer value on the same topic. The value is now published once only when publishing starts or the topic changes (#467)
4.0.0 (2026-05-05)
- (copilot) Adapter requires js-controller >= 6.0.11 now
- (@klein0r) Updated dependencies
3.0.0 (2025-01-24)
- (@klein0r) Breaking change: Underscores are not replaced by spaces in the corresponding topic anymore
2.1.0 (2024-11-12)
- (mcm1957) Adapter requires node.js 20 now.
- (mcm1957) Adapter requires js-controller 5.0.19 and admin 6.17.14 now.
- (simatec) Adapter changed to meet Responsive Design rules.
- (mcm1957) Dependencies have been updated.
2.0.1 (2024-09-23)
- (@klein0r) Added missing information in configuration dialog
- (@klein0r) Fixed type of port configuration to avoid conflicts
The MIT License (MIT)
Copyright (c) 2025-2026 iobroker-community-adapters iobroker-community-adapters@gmx.de
Copyright (c) 2016-2023 Pmant
