Control of Xiaomi/Roborock vacuum cleaner
This adapter allows control Xiaomi vacuum cleaner
Current Release
6.1.0
bluefox, iobroker-community-adapters
Deutsche Dokumentation
The mihome-vacuum adapter connects ioBroker to compatible Xiaomi ecosystem robot vacuum cleaners. It supports local control through the robot's IP address and token, optional Xiaomi Cloud device discovery and maps, room cleaning, timers, cleaning history, consumable information, and dedicated VIS 1 and VIS 2 widgets.
Supported device families include Roborock/rockrobo, Viomi, and Dreame. The exact commands, map functions, rooms, mop controls, dock controls, and consumable states depend on the model and firmware.
Installation
Install and update the adapter through ioBroker Admin using a published npm version. Direct installation from GitHub is not supported and is disabled in Admin. The source repository does not contain the generated runtime, Admin UI or VIS 2 bundles; published packages include them.
Supported devices and features
The following models are explicitly documented as supported. Other models from the same device families may work with the matching manager, but are not guaranteed until they have been tested. Available functions can also vary with the installed firmware.
DeviceBasic controlCleaning historyRoom cleaningMap
viomi.vacuum.v6
viomi.vacuum.v7
viomi.vacuum.v8
viomi.vacuum.v19
rockrobo.vacuum.v1
roborock.vacuum.s4
roborock.vacuum.s5
roborock.vacuum.s5e
roborock.vacuum.m1s
roborock.vacuum.a10
roborock.vacuum.a15
dreame.vacuum.r2205
dreame.vacuum.r2216o
dreame.vacuum.r2228o
dreame.vacuum.p2008
dreame.vacuum.p2009
dreame.vacuum.p2027
dreame.vacuum.p2028
dreame.vacuum.p2029
dreame.vacuum.p2036
dreame.vacuum.p2041o
dreame.vacuum.p2114a
dreame.vacuum.p2148o
dreame.vacuum.p2156o
means that the function is supported for the documented model. means that the adapter does not currently provide that function for the model.
Requesting support for a new model
The adapter picks its device library from the first part of the model id, the part before the first dot: roborock and rockrobo use the Roborock library, viomi the Viomi library, dreame and xiaomi the Dreame/MIOT library. A model of one of these families that is not listed above usually works with the same library: basic control, status, battery, consumables and cleaning history are available when the robot uses the standard properties, and properties the robot does not expose stay empty. If such a model works for you, open an issue with the model id and firmware version so it can be added to the table.
If the log shows Model <id> not supported! You can try to setup manually a library in settings., the model id starts with a prefix the adapter does not know (for example ijai or xtl). The adapter then creates no states although the instance is running. You can force one of the libraries with the Manager option in the instance settings; devices that use the MIOT protocol sometimes work with the Dreame library. A library of its own for a new vendor needs the MIOT specification of the model (https://home.miot-spec.com/spec/<model id>) and someone who owns the device and can test.
Every request or bug report should contain the model id and firmware (deviceInfo.model, deviceInfo.fw_ver), the adapter, js-controller and Node.js versions, which states work and which do not, and the debug log around the problem, especially the lines containing Device model detected, MIIO request and Status update:. For map problems add the value of auth.status and the output of npm ls canvas from the ioBroker directory. Remove tokens, login links, cloud sessions and IP addresses before posting.
Disclaimer
All product and company names, logos, and trademarks mentioned in this project belong to their respective owners. Xiaomi, Mi Home, Roborock, Viomi, Dreame, and their associated names, logos, and trademarks are the property of their respective owners. Their use is solely for identification and does not imply any affiliation, sponsorship, or endorsement. This is a private, non-commercial open-source project developed for recreational purposes.
Sentry
This adapter uses Sentry libraries to automatically report exceptions and code errors to the developers. For more details and instructions on disabling error reporting, please refer to the Sentry Plugin documentation. Sentry reporting is available with js-controller 3.0 and newer.
Requirements
  • Node.js 22.13 or newer
  • js-controller 7.2.2 or newer
  • Admin 7.8.23 or newer
  • The ioBroker host and robot should be reachable through the same local network
  • A valid local device token is required for local UDP control
Xiaomi Cloud is optional for normal local control. It is used for convenient device discovery and Xiaomi Cloud maps.
Quick start
  1. Install the adapter and create an instance.
  2. Open the instance configuration and select the Connection tab.
  3. Select the Xiaomi region in which the vacuum is registered.
  4. Click Create Xiaomi login link.
  5. Open the displayed link and confirm the Xiaomi login in the browser.
  6. Return to ioBroker after the cloud status changes to Authenticated.
  7. Click Get devices and select the vacuum from the device list.
  8. Check the automatically filled token, IP address, model, and manager.
  9. Save the configuration and verify that info.connection becomes true.
Connection and Xiaomi Cloud login
The login is performed through a Xiaomi login link. No QR image is generated by the adapter. The link expires after a short time; create a new link if the status changes to expired or error.
The selected device normally supplies the local token, IP address, and model automatically. The token is encrypted in the ioBroker instance configuration and masked in the UI. Use the eye button only when you intentionally need to view or copy it.
Never publish a device token, Xiaomi login link, cookie, cloud session, or unredacted debug response in an issue or forum post.
Local setup without Xiaomi Cloud
Local control does not depend on an active Xiaomi Cloud session. If the local token, IP address, and model are already known, enter them in Manual settings:
  • Token: local hexadecimal device token
  • IP address: current local address of the robot
  • Model: model identifier such as roborock.vacuum.s5
  • Manager: normally detected automatically; manually choose Roborock, Viomi, or Dreame only when necessary
  • Vacuum port: normally 54321
  • Own port: local UDP port used by this adapter instance, normally 53421
Assign a fixed DHCP lease to the robot so its IP address does not change.
Obtaining the token manually
Obtaining the local device token manually can be the most difficult part of a setup without Xiaomi Cloud discovery. The following external guide describes one possible procedure for several Xiaomi and Roborock models:
Token extraction guide (German)
This is a third-party guide and may not work with every model, firmware, or current Mi Home app version. Treat the token like a password: store it securely and never publish it in logs, screenshots, issues, or forum posts.
Configuration
Connection
The Connection tab contains Xiaomi Cloud authentication, device discovery, and the local settings used to communicate directly with the vacuum.
  • A successful cloud login is stored as a protected, encrypted session.
  • Get devices only becomes available after authentication.
  • Selecting a detected vacuum fills missing local settings and replaces an outdated token when necessary.
  • The login link is cleared after a successful login or after it expires.
  • Deleting the stored token takes effect when the configuration is saved.
General settings
General settings
  • Request status interval: how often the current robot status is requested. Very short intervals increase network and robot load.
  • Request Wi-Fi status interval: how often signal information is refreshed.
  • Enable map from Xiaomi Cloud: enables Xiaomi Cloud map downloads. Requires an authenticated cloud session.
  • Enable Valetudo: uses a compatible local Valetudo map source.
  • Send own commands: creates the expert states control.X_send_command and control.X_get_response.
  • Add Alexa/IoT states: additionally creates control.pauseResume for voice assistants and IoT integrations. control.clean_home always exists.
  • Send pause before home: sends a pause before the return-to-dock command for models that require it.
  • Resume paused zone cleaning with start button: resumes an interrupted zone cleaning instead of starting a complete cleaning.
  • Advanced diagnostic logging: adds detailed, redacted debug information. Enable it only temporarily while troubleshooting.
Map settings
Map settings
Map support depends on the vacuum model and selected source.
  • Request interval: controls how often the map source is requested.
  • Map save interval: controls how often the generated PNG is written.
  • New map format with room colors: enables segmented room rendering where supported.
  • Floor, wall, and path colors: customize the generated map.
  • Robot icon: selects the symbol displayed at the robot position.
Map stateDescription
cleanmap.map64Base64/data-URL map, recommended for VIS widgets
cleanmap.mapURLPath to the generated PNG file
cleanmap.actualMapActive map identifier
cleanmap.mapStatusCurrent map processing status
cleanmap.loadMapRequests a map refresh
Xiaomi Cloud maps require both Enable map from Xiaomi Cloud and a valid cloud login. Local robot commands continue to work if the cloud session is unavailable.
Timer
Timer configuration
Adapter timers can start selected room channels at a chosen weekday and time.
  1. Load or create the room channels first.
  2. Open Timer and click Add.
  3. Select weekday, hour, minute, rooms and/or room channels.
  4. Enable the timer and click Save timers.
Adapter timers are stored in ioBroker and can therefore also be displayed or controlled from VIS. They are independent of timers configured in the Xiaomi app.
Functions
Basic control
StateFunction
control.startStart a complete cleaning
control.pausePause the current job
control.homeReturn to the charging station
control.findPlay the robot's location sound
control.spotcleanStart spot cleaning
control.fan_powerRead or set suction power
control.zoneCleanClean one or more coordinate-based zones
control.goToMove to map coordinates
control.clearQueueClear the pending cleaning queue
control.clean_hometrue starts cleaning, false returns home
Additional controls for mopping, washing, drying, dust collection, carpet mode, and dock functions are created only when supported by the selected model.
Rooms
The adapter creates channels below rooms when the robot exposes room or segment information.
  • Use rooms.loadRooms to reload rooms from the robot.
  • A room channel contains its map index or zone coordinates and a start command.
  • Assign room channels to ioBroker enum.rooms entries to use readable room assignments.
  • Set the desired room suction level before starting that room.
  • rooms.multiRoomClean can start several assigned rooms together.
  • rooms.addRoom can create a room manually from a map index or zone coordinates.
Room names and capabilities come from the robot and may differ between models and firmware versions.
Cleaning history
The history channel contains the total cleaning time, total area, number of cleanups, and recent cleaning records in JSON and HTML form. History is also displayed in both supplied widgets.
Consumables and maintenance
Supported maintenance values are created below consumable, for example filter, main brush, side brush, sensors, water filter, mop pad, strainer, cleaning brush, and dust collection counters.
Reset a lifetime only after the corresponding component has been cleaned or replaced. Unsupported consumables are not shown by the widgets.
Advanced custom commands
When Send own commands is enabled, commands can be written to control.X_send_command; responses appear in control.X_get_response. This is intended for experienced users. Invalid or model-incompatible commands can cause unexpected robot behavior.
Important states
ChannelPurpose
info.connectionLocal connection status
info.stateNumeric robot state with readable state labels
info.errorNumeric error code with readable error labels
info.batteryBattery level in percent
info.cleanedareaArea cleaned during the current/latest job
info.cleanedtimeCleaning duration
info.wifi_signalRobot Wi-Fi signal strength
deviceInfo.modelDetected model
deviceInfo.fw_verFirmware version
auth.statusXiaomi Cloud authentication status
auth.loginUrlTemporary login link; cleared after completion/expiry
auth.lastErrorLast safe authentication error message
auth.expiresAtLogin-link expiration time
info.state and info.error provide enumerated text in the ioBroker object definition. Unknown codes remain visible so they can be reported without losing the original value.
Both included widgets provide a responsive dashboard with the map, connection and robot status, battery, area, duration, error information, suction-level selection, quick controls, up to six rooms, maintenance actions, and a separate history view.
VIS 1
Select the widget set mihome-vacuum and add Vacuum dashboard with map, maintenance and history. Select the status state (info.state) of your instance first: the widget fills every other empty state attribute from that instance, including the Viomi and Dreame variants of the water level, mop mode and dock states.
The VIS 1 widget offers the same sections as the VIS 2 widget: water level, mop mode and carpet mode, the dock station with its actions, a map selector with reload for multi-map robots, the do-not-disturb state with the next timer, and a configurable number of history entries. Each section appears only when its state is assigned, so leave the states of features your robot does not have empty. Timers can only be switched in VIS 2; VIS 1 shows the next scheduled run.
VIS 1 vacuum widget
VIS 2
Select the widget set Mi Home Vacuum and add Vacuum control with map. Its settings are grouped into general options, states and controls, maintenance, rooms, and history.
  • Instance selection: choose the status state (info.state) of the adapter instance you want to display. All empty state attributes are filled from that instance automatically, so switching from mihome-vacuum.0 to another instance takes one click.
  • Theme: the widget follows the light or dark theme and the primary color of your VIS 2 project. An optional accent color overrides the primary color.
  • Suction levels: the selectable levels come from the control.fan_power state of your robot, so every model shows its own levels. The three numeric fallback values are only used when the state has no level catalogue.
  • Status and error texts: taken from the adapter's state definitions and translated where a translation exists.
  • History: the number of shown cleaning runs is configurable.
  • Cleaning settings: water level, mop mode and carpet mode appear as controls when your robot provides the matching states. The instance selection also finds the Viomi and Dreame variants of these states.
  • Dock station: shows the dock status and offers emptying the dust bin as well as washing and drying the mop for robots with such a station.
  • Maps: robots with several maps get a map selector on the map image, and Reload map fetches the current map from the robot.
  • Schedule: shows the do-not-disturb state, the next timer and every timer created in the adapter configuration. A timer can be switched on or off, skipped once or started immediately from the widget. The section can be hidden with Show schedule.
Every control appears only when the adapter created the matching state for your robot, so the widget adapts to the feature set of the model. Widgets created with an earlier adapter version pick up the new states of their instance automatically; the attributes in the widget settings only need to be changed when a state should point somewhere else.
VIS 2 vacuum widget
Rooms, suction levels, and layout
With Detect rooms automatically (default) the VIS 2 widget shows every room the adapter created below rooms.*, including its own suction level where the robot supports it. Disable the option to configure up to six rooms manually with a displayed name, start state, and fan-power state. The VIS 1 widget always uses the manual room configuration.
The widgets preserve the complete map aspect ratio and adapt their layout to their own width, not to the browser window. If a widget is too small, its content scrolls instead of allowing the map to overlap controls or maintenance cards. Resetting a consumable counter asks for confirmation first.
Widget history
The History tab displays total cleanups, total area, total time, and recent cleaning results.
VIS 1 and VIS 2 cleaning history
Troubleshooting
The robot does not connect
  • Verify info.connection, the robot IP address, token, and selected model.
  • Ensure the robot and ioBroker host can communicate through the local network. Some models require the same subnet.
  • Reserve the robot's IP address in the DHCP server.
  • Keep the vacuum port at 54321 unless the device explicitly uses another port.
  • Make sure another adapter instance is not using the same own UDP port.
Cloud login or device discovery fails
  • Select the same Xiaomi region used by the robot.
  • Create a fresh login link if the previous one expired.
  • Complete the browser login before pressing Get devices.
  • A Xiaomi 401 or 403 response invalidates the stored session and requires a new explicit login.
No map is displayed
  • Confirm that the connected model supports map retrieval.
  • Enable either Xiaomi Cloud maps or Valetudo.
  • For Xiaomi maps, verify that auth.status is authenticated.
  • Check cleanmap.mapStatus, cleanmap.map64, and the adapter debug log.
Installation fails while building canvas
The map renderer uses the optional native canvas package. When no prebuilt binary is available on Linux, install the required system packages before reinstalling:
sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
Do not manually install an old canvas 2.x version into the adapter directory.
Multiple robots
Create one adapter instance per robot. Every instance must use a different Own port, for example 53421, 53422, and so on.
Support and bug reports
When reporting a problem, include the adapter version, Node.js version, js-controller version, model identifier, relevant log lines, and the action that triggered the issue. Remove tokens, login links, cookies, cloud sessions, IP addresses, and other private data before publishing logs.
Use the GitHub issue tracker for reproducible bugs and feature requests.
  • (xXBJXx) Documented how new models are supported and rewrote the GitHub issue templates as English forms
6.1.0 (2026-09-08)
  • (xXBJXx) VIS 1 widget: added the cleaning settings, dock station, map selection, do-not-disturb and next-timer sections of the VIS 2 widget, a configurable history length, manager-specific auto-fill of the state attributes, translated state and error texts in all languages, SVG icons instead of Unicode symbols, and a layout that follows the widget width
  • (xXBJXx) Removed 115 unused duplicate translation keys of the widget texts
  • (xXBJXx) Completed the Spanish, French, Italian, Dutch, Polish, Portuguese, Russian, Ukrainian and Chinese translations of the Admin configuration and both widgets; they previously showed English texts
  • (xXBJXx) VIS 2 widget: added water level, mop mode and carpet mode controls, dock station status and actions, map selection and reload, and a schedule section with do-not-disturb, next timer and timer switches; every control appears only when the robot provides the matching state, and the instance selection also finds the Viomi and Dreame state names
  • (xXBJXx) Reworked the VIS 2 widget: it follows the VIS 2 theme with an optional accent color, lays itself out by its own width, fills all state attributes from the selected instance, detects rooms automatically, takes suction levels and status texts from the adapter states, confirms resets in a dialog, and has a configurable history length
  • (xXBJXx) VIS 1 widget: respect the configured widget size instead of forcing 1280x800 and label the map image correctly
  • (xXBJXx) Upgraded the Admin configuration and the VIS 2 widget to React 19, MUI 9, and @iobroker/gui-components 10 so the widget keeps working with upcoming VIS 2 releases while staying compatible with the current VIS 2
  • (xXBJXx) Updated qs to 6.16 and the VIS 2 type definitions and Module Federation tooling to their current versions
6.0.1 (2026-09-07)
  • (xXBJXx) Remove install-time and prepublish build hooks, build explicitly in CI, and disable unsupported GitHub installations (#1223)
  • (xXBJXx) Start directly from build/main.js and generate Admin/VIS bundles for npm packages instead of tracking build output in Git
  • (xXBJXx) Verify script-free package installation, generated UI assets, direct startup, and Compact Mode
  • (xXBJXx) Remove unused Chai test plugins, add VS Code metadata schema support, and annotate the optional Canvas dependency for the repository checker (#1222)
  • (xXBJXx) Allow Dependabot updates of GitHub Actions and dependency versions without failing the package policy tests (#1235)
  • (xXBJXx) Restore the "Add Alexa/IoT states" option in the Admin configuration so control.pauseResume is no longer deleted on every start
  • (xXBJXx) Fix the getCleaningSummary message, which sent a consumable reset instead of requesting the cleaning summary
  • (xXBJXx) Answer the legacy send message only once and no longer forward it to the device manager
  • (xXBJXx) Reject map updates with a clear error when neither the Xiaomi Cloud map nor Valetudo is enabled instead of leaving the request pending
  • (xXBJXx) Track every pending internal delay separately so all of them are cancelled on unload, and remove a duplicated control.goTo definition
  • (kosmix1980) Apply the room fan, water and mop settings through miIO before queued and repeated room cleanings start instead of racing them against the start command (#1231)
  • (kosmix1980) Keep the native multi-pass segment cleaning lockout only for the current run instead of persisting it after a single error (#1231)
  • (xXBJXx) Continue starting the cleaning with a warning when a fan, water or mop parameter command fails
6.0.0 (2026-08-26)
  • (xXBJXx) Align the Admin requirement with stable Admin 7.8.23 and remove the invalid empty instance-object declaration
  • (xXBJXx) Add the official ioBroker adapter development toolchain and allow compatible qs patch updates
  • (xXBJXx) Require Node.js 22.13 or newer, js-controller 7.2.2 or newer, and Admin 7.8.23 or newer
  • (xXBJXx) Build the productive runtime from TypeScript and start it through a Git-install-compatible bootstrap
  • (xXBJXx) Added a responsive React, Vite and TypeScript configuration UI with connection, general, map and timer settings
  • (xXBJXx) Added Xiaomi login-link authentication and the auth.status, auth.loginUrl, auth.lastError, and auth.expiresAt states
  • (xXBJXx) Added encrypted and protected persistence for the local device token and reusable Xiaomi Cloud session
  • (xXBJXx) Added opt-in advanced diagnostic logging with credential and personal-data redaction
  • (xXBJXx) Added TypeScript, protocol, lifecycle, multi-instance, admin-security, package and integration test coverage
  • (xXBJXx) Added clean package builds and a packed-runtime installation smoke test
  • (xXBJXx) Added redesigned VIS 1 and VIS 2 widgets with maps, rooms, maintenance and history
  • (xXBJXx) Added shared ioBroker/Weblate translations for Admin, VIS 1 and VIS 2
  • (xXBJXx) Completed all shipped translations and migrated Admin and VIS 2 to ioBroker's short i18n format
  • (xXBJXx) Migrated the adapter runtime and its Roborock, Viomi and Dreame managers from JavaScript to TypeScript
  • (xXBJXx) Updated the local UDP startup, request dispatching, timeout handling and shutdown lifecycle
  • (xXBJXx) Migrated runtime callbacks to unload-aware ioBroker timers and deprecated object writes to supported APIs
  • (xXBJXx) Isolated runtime state per adapter and manager instance for Compact Mode and multiple instances
  • (xXBJXx) Kept local IP/token control independent from Xiaomi Cloud authentication
  • (xXBJXx) Updated runtime and development dependencies, including canvas 3.2.3, qs 6.15.3 and the current ioBroker tooling
  • (xXBJXx) Updated CI to build and test the backend, admin UI and installation package on supported Node.js versions
  • (xXBJXx) Always create control.clean_home, independently of optional Alexa/IoT configuration
  • (xXBJXx) Prevent the first miIO.info request from being lost directly after the UDP connection event
  • (xXBJXx) Prevent timers and pending requests from writing states after adapter shutdown
  • (xXBJXx) Prevent delayed status callbacks from losing their manager context and terminating the adapter
  • (xXBJXx) Validate cloud sessions, cloud responses, room objects and optional configuration values before use
  • (xXBJXx) Redact device tokens, cloud sessions, cookies, login URLs and complete API payloads from normal logs
5.3.0 (2025-07-24)
  • (dirkhe) update dependecies
  • (dirkhe) replace request with axios
  • (dirkhe) fix login issues by replacing and moving code to XiaomiCloudConnector
5.2.0 (2025-01-22)
  • (dirkhe) add IP Adress to info
  • (dirkhe) assign rockrobo (valetudo) to roborock Manager
Copyright (c) 2023-2026 iobroker-community-adapters iobroker-community-adapters@gmx.de
Copyright (c) 2017-2023 bluefox dogafox@gmail.com
See LICENSE for the complete license text.
