legrand-ecocompteur adapter for ioBroker
Adapter for the Legrand Ecocompteur module (aka. Legrand Measurement Concentrator EMDX³ 412000).
This is a power measurement device with it's own web interface. The adapter utilises that web interface by:
- Polling for instantaneous power readings (read in a JSON response).
- Polling the device's index page to read the TIC interface. TIC stands for Télé-Information Client which is a French construct. This value is generally read from a utility billing meter connected to the Ecocompteur.
These objects are created for each of the 5 circuits the Ecocompteur reads plus overall total:
- Instantaneous power (in Watts).
- Total cumulated energy measured while the adapter was running (in kWh).
A further object is created to store the TIC interface value.
Note the Ecocompteur's Fragile IP Stack
Through testing it has been noted that the Ecocompteur has a rather fragile IP stack. Sometimes the stack can 'hang' and stop responding to requests, although in the author's experience, that was tracked to non-RFC compliant requests coming from another home automation device.
Nevertheless, it would be prudent to mitigate for this risk by placing the device behind a simple Nginx micro-caching reverse proxy. Example Nginx configuration for an Ecocompteur at http://192.168.0.10/ (hence set BaseURL settings for this adapter to http://<Nginx address>:8080/le/):
proxy_cache_path /tmp/cache keys_zone=cache:32k levels=1 inactive=10s max_size=256k;
server {
listen 8080;
proxy_cache cache;
proxy_cache_valid 200 1s;
location /le/ {
proxy_pass http://192.168.0.10/;
Configuration
The following configuration is required:
- Base URL of device.
- JSON polling interval (in seconds).
- Index polling interval (in seconds).
- Validation: maximum circuit reading (in Watts).
- (copilot) Adapter requires js-controller >= 6.0.11 now
- (copilot) Adapter requires admin >= 7.6.17 now
1.0.0
- (Robin Rainton) Stable release.
0.0.6
- (Robin Rainton) Change IP address setting to base URL. Settings will need to be updated.
- (Robin Rainton) Fixed timeout handling. Parse readings from index HTML. Refactor to use more promises & single interval timer.
0.0.4
- (Robin Rainton) Added reading validation filter.
0.0.3
- (Robin Rainton) initial clean release.
Copyright (c) 2026 iobroker-community-adapters iobroker-community-adapters@gmx.de
Copyright (c) 2020 Robin Rainton robin@rainton.com
